Attention is currently required from: Fred Reitberger, Jason Glenesk, Varshit Pandya.
Hello Felix Held, Fred Reitberger, Jason Glenesk, Matt DeVillier, build bot (Jenkins),
https://review.coreboot.org/c/coreboot/+/80413?usp=email
Change subject: soc/amd/picasso: Use pcie_gpp_dxio_update_clk_req_config ......................................................................
This function turns off gpp_clk for the devices which are disabled, and adds the code to fix up the clock configuration depending on dxio descriptors. Also this brings picasso in line with cezanne, mendocino and phoenix. This also prepares picasso to use the common function gpp_clk_setup_common.
Change-Id: Ice2e3a5a78359da9a438434c7d4aa1eca878d396 Signed-off-by: Varshit Pandya pandyavarshit@gmail.com --- M src/soc/amd/picasso/Kconfig M src/soc/amd/picasso/chip.h M src/soc/amd/picasso/fch.c 3 files changed, 7 insertions(+), 6 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/13/80413/3
