Stefan Reinauer (stefan.reinauer@coreboot.org) just uploaded a new patch set to gerrit, which you can find at http://review.coreboot.org/4236
commit dcf3ec8f2724994dc6a12e8260bcb488270a9411 Author: Stefan Reinauer reinauer@chromium.org Date: Tue May 21 10:46:28 2013 -0700
libpayload: fix wrong endian assumption in sha1.c
Not all platforms !x86 are big endian, hence actually look at the CONFIG_LITTLE_ENDIAN flag instead of CONFIG_ARCH_X86.
Change-Id: Ibbd8f48b377a1121dd1e045834a94a2d67eda2ab Signed-off-by: Stefan Reinauer reinauer@google.com Reviewed-on: https://gerrit.chromium.org/gerrit/56066 Reviewed-by: Patrick Georgi patrick@georgi-clan.de Reviewed-by: Ronald G. Minnich rminnich@chromium.org Commit-Queue: Stefan Reinauer reinauer@chromium.org Tested-by: Stefan Reinauer reinauer@chromium.org --- payloads/libpayload/crypto/sha1.c | 8 +------- 1 file changed, 1 insertion(+), 7 deletions(-)
diff --git a/payloads/libpayload/crypto/sha1.c b/payloads/libpayload/crypto/sha1.c index 3c97bf1..c973e18 100644 --- a/payloads/libpayload/crypto/sha1.c +++ b/payloads/libpayload/crypto/sha1.c @@ -30,18 +30,12 @@ typedef unsigned int u_int;
/* Moved from libpayload.h */
-#ifdef CONFIG_ARCH_X86 +#ifdef CONFIG_LITTLE_ENDIAN #define BYTE_ORDER LITTLE_ENDIAN #else #define BYTE_ORDER BIG_ENDIAN #endif
-#if 0 -#include <sys/param.h> -#include <string.h> -#include <sha1.h> -#endif - #define rol(value, bits) (((value) << (bits)) | ((value) >> (32 - (bits))))
