Attention is currently required from: Arthur Heymans.
Julius Werner has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/74501?usp=email )
Change subject: arch/arm64: Add Clang as supported target ......................................................................
Patch Set 23:
File src/arch/arm64/Kconfig:
https://review.coreboot.org/c/coreboot/+/74501/comment/ec6665c4_6a23f4af : PS23, Line 7: default y if ARCH_ARM64
Should move under the `if` below. […]
Sorry, I don't really understand... I'm pretty sure that should work. This is only a default override for a symbol that was already declared earlier. If you look at `src/mainboard/google/gru/Kconfig`, for example, you see a `config DRIVER_TPM_I2C_ADDR` that overrides the default inside the `if BOARD_GOOGLE_GRU_COMMON` block. How is this case any different?
Can you maybe upload the version that gives you the error so we can make sure we mean the same thing?
