Felix Held has submitted this change. ( https://review.coreboot.org/c/coreboot/+/84137?usp=email )
Change subject: mb/google/nissa/var/teliks: Force audio mute to avoid screen flick ......................................................................
Panel CSOT MNB601LS1-3 will flicker once during enter Chrome login screen, it is because it inserts 12 blank frames if it receives the unmute in VB-ID.
Always override the mute in VB-ID to avoid Tcon EC detected the audiomute_flag change.
BUG=b:360243615 BRANCH=firmware-nissa-15217.B TEST:Verfied on Teliks and cannot reproduce the issue
Change-Id: Iff488f6844c717ef24069c7176e7b8dfb07d8abc Signed-off-by: Jianeng Ceng cengjianeng@huaqin.corp-partner.google.com Reviewed-on: https://review.coreboot.org/c/coreboot/+/84137 Reviewed-by: Eric Lai ericllai@google.com Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: Subrata Banik subratabanik@google.com Reviewed-by: Qinghong Zeng zengqinghong@huaqin.corp-partner.google.com --- M src/mainboard/google/brya/variants/teliks/variant.c 1 file changed, 18 insertions(+), 0 deletions(-)
Approvals: build bot (Jenkins): Verified Subrata Banik: Looks good to me, approved Eric Lai: Looks good to me, approved Qinghong Zeng: Looks good to me, but someone else must approve
diff --git a/src/mainboard/google/brya/variants/teliks/variant.c b/src/mainboard/google/brya/variants/teliks/variant.c index 7cc4af8..3f7cfd6 100644 --- a/src/mainboard/google/brya/variants/teliks/variant.c +++ b/src/mainboard/google/brya/variants/teliks/variant.c @@ -5,6 +5,11 @@ #include <fw_config.h> #include <sar.h> #include <soc/gpio_soc_defs.h> +#include <intelblocks/graphics.h> + +/* Per-pipe DDI Function Control 2 */ +#define TRANS_DDI_FUNC_CTL2_A 0x60404 +#define TRANS_DDI_AUDIO_MUTE_OVERRIDE_BITS_FIELDS (3 << 6)
const char *get_wifi_sar_cbfs_filename(void) { @@ -36,3 +41,16 @@ ARRAY_SIZE(wifi_pcie_enable_pad)); } } + +void variant_finalize(void) +{ + /* + * Panel CSOT MNB601LS1-3 will flicker once during enter Chrome login screen, + * it is because it inserts 12 blank frames if it receives the unmute in VB-ID. + * + * Always override the mute in VB-ID to avoid Tcon EC detected the + * audiomute_flag change. + */ + graphics_gtt_rmw(TRANS_DDI_FUNC_CTL2_A, ~TRANS_DDI_AUDIO_MUTE_OVERRIDE_BITS_FIELDS, + TRANS_DDI_AUDIO_MUTE_OVERRIDE_BITS_FIELDS); +}
