Attention is currently required from: Hung-Te Lin, Rex-BC Chen, Paul Menzel, Yu-Ping Wu. Hello Hung-Te Lin, build bot (Jenkins), Yu-Ping Wu,
https://review.coreboot.org/c/coreboot/+/57270
Change subject: soc/mediatek: preserve WDT reset reason for debugging ......................................................................
1. Disable external output reset signal in first WDT reset to preserve WDT original reset reason for WDT issue in kernel stage. 2. After preserved WDT reset reason, do fully reset again by sending external output reset signal.
BUG=b:194025005 TEST=boot to kernel ok and function test pass
Signed-off-by: Fengquan Chen fengquan.chen@mediatek.corp-partner.google.com Change-Id: I5887a8312f4daab3cbd0a30fea0195670a932e52 --- M src/soc/mediatek/common/wdt.c 1 file changed, 4 insertions(+), 0 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/70/57270/5
