the following patch was just integrated into master: commit aef586548a2443f40a49f9f1f5d99c522a89480f Author: Aaron Durbin adurbin@chromium.org Date: Fri Apr 29 12:34:01 2016 -0500
arch/x86/assembly_entry: allow early post CAR stages to use common code
The skylake-based Chromebooks use a separate verstage which runs just after bootblock and prior to romstage. The normal path for romstage would be to reload the gdt, however in the previously described scenario has verstage performing that work. Therefore, provide that path under those conditions. The only difference from the C_ENVIRONMENT_BOOTBLOCK scenario is that the stack should not be reloaded since there's no way to know the top of the stack.
Change-Id: Ic39ab52a856233d3042ac02a15ae4816ddfe07c7 Signed-off-by: Aaron Durbin adurbin@chromium.org Reviewed-on: https://review.coreboot.org/14548 Reviewed-by: Furquan Shaikh furquan@google.com Tested-by: build bot (Jenkins) Reviewed-by: Andrey Petrov andrey.petrov@intel.com Reviewed-by: Leroy P Leahy leroy.p.leahy@intel.com
See https://review.coreboot.org/14548 for details.
