Julius Werner has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/18499 )
Change subject: libpayload: Use interrupt transfers for USB hubs ......................................................................
Patch Set 3: Code-Review+2
(2 comments)
https://review.coreboot.org/c/coreboot/+/18499/3/payloads/libpayload/drivers... File payloads/libpayload/drivers/usb/usbhub.c:
https://review.coreboot.org/c/coreboot/+/18499/3/payloads/libpayload/drivers... PS3, Line 308: div_round_up(desc.bNbrPorts + 1, 8) BTW, Linux says here (hub.c#hub_configure())
/* set up the interrupt endpoint * We use the EP's maxpacket size instead of (PORTS+1+7)/8 * bytes as USB2.0[11.12.3] says because some hubs are known * to send more data (and thus cause overflow).
Not sure if it matters.
https://review.coreboot.org/c/coreboot/+/18499/3/payloads/libpayload/drivers... PS3, Line 310: return; Doesn't this need a usb_detach_device()? (I guess technically that was already wrong for generic_hub_init() in the old code.)
