Attention is currently required from: Angel Pons, Felix Held, Paul Menzel.
Hello Angel Pons, Felix Held, Paul Menzel, build bot (Jenkins),
https://review.coreboot.org/c/coreboot/+/83196?usp=email
Change subject: util/superiotool: Add extra selectors support ......................................................................
Some chips have specific selectors (in addition to LDN-register) that affect the register space. At the same time, the utility doesn't provide a simple and convenient method for configuring such selectors (as in the case of LDN-selector) to create a dump, because this may be configured by several fields of the register, and the values of its other fields should not change after setting in the BIOS (fintek [1,2]).
Just add a structure with an index, mask, and value for the selector inside the superio_registers chip for the corresponding LDN to switch the register bank:
{FINTEK_F81966_DID, "F81962/F81964/F81966/F81967", {
* * * {NOLDN, "Global", {0x28,0x2a,0x2b,0x2c,EOT}, {0x00,0x00,0x00,0x00,EOT}, {.idx = 0x27, .mask = 0xd, .val = 0x1} /* update extra selector */ }, {0x03, "LPT", {0x30,0x60,0x61,0x70,0x74,0xf0,EOT}, {NANA,0x03,0x78,0x07,0x03,0xc2,EOT} /* without extra selector */ },
Tested with Fintek F81966 on Asrock IMB-1222:
- run superiotool on Ubuntu and dump the registers for the board with the vendor's firmware; - add the superio chip initialization code to the board configuration in coreboot and build the project; - boot Ubuntu on the board with coreboot and re-dump the registers; - the register values from the board configuration code are the same in both dumps.
The changes do not affect the configuration of existing chips, which was tested on the Asrock H110-STX motherboard with Nuvoton NCT5539D (the dump before and after the changes are the same).
[1] CB:83004 [2] CB:83019
Change-Id: If56af9f977381e637245bdd26563f5ba7e6cbead Signed-off-by: Maxim Polyakov max.senia.poliak@gmail.com --- M util/superiotool/superiotool.c M util/superiotool/superiotool.h 2 files changed, 33 insertions(+), 0 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/96/83196/5
