Eric Lai has submitted this change. ( https://review.coreboot.org/c/coreboot/+/71743 )
Change subject: mb/google/brya: Allow respective variant to choose NEM config ......................................................................
This patch introduces a new config named `DEFAULT_ADL_NEM` and allows respective brya variants with Alder Lake ESx samples to choose NEM over eNEM as eNEM was fuse disabled till ESx.
TEST=The boot flow related to eNEM and NEM behaviour remains the same with and without this patch.
Signed-off-by: Subrata Banik subratabanik@google.com Change-Id: Ibbd492a3d210739120c7ad16415cb7912f5b70ec Reviewed-on: https://review.coreboot.org/c/coreboot/+/71743 Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: Reka Norman rekanorman@chromium.org Reviewed-by: Eric Lai eric_lai@quanta.corp-partner.google.com --- M src/mainboard/google/brya/Kconfig M src/mainboard/google/brya/Kconfig.name 2 files changed, 37 insertions(+), 1 deletion(-)
Approvals: build bot (Jenkins): Verified Reka Norman: Looks good to me, approved Eric Lai: Looks good to me, approved
diff --git a/src/mainboard/google/brya/Kconfig b/src/mainboard/google/brya/Kconfig index 5429d59..78f0ad5 100644 --- a/src/mainboard/google/brya/Kconfig +++ b/src/mainboard/google/brya/Kconfig @@ -299,9 +299,15 @@ default y if BOARD_GOOGLE_PRIMUS4ES default n
+config DEFAULT_ADL_NEM + bool + help + Brya variants with Alder Lake ESx silicon to choose this config + as eNEM was fuse disable till ESx silicon revision. + choice prompt "Cache as RAM (CAR) setup configuration to use" - default USE_ADL_NEM if BOARD_GOOGLE_PRIMUS4ES || BOARD_GOOGLE_GIMBLE4ES || BOARD_GOOGLE_REDRIX4ES || BOARD_GOOGLE_TAEKO4ES || BOARD_GOOGLE_ANAHERA4ES || BOARD_GOOGLE_TANIKS || BOARD_GOOGLE_SKOLAS || BOARD_GOOGLE_SKOLAS4ES || BOARD_GOOGLE_ZYDRON + default USE_ADL_NEM if DEFAULT_ADL_NEM default USE_ADL_ENEM
config USE_ADL_ENEM diff --git a/src/mainboard/google/brya/Kconfig.name b/src/mainboard/google/brya/Kconfig.name index 37610f3..4b7a045 100644 --- a/src/mainboard/google/brya/Kconfig.name +++ b/src/mainboard/google/brya/Kconfig.name @@ -23,6 +23,7 @@ config BOARD_GOOGLE_ANAHERA4ES bool "-> Anahera4ES" select BOARD_GOOGLE_BASEBOARD_BRYA + select DEFAULT_ADL_NEM select DRIVERS_GENESYSLOGIC_GL9763E select DRIVERS_GENESYSLOGIC_GL9750 select DRIVERS_GFX_GENERIC @@ -66,6 +67,7 @@ select BOARD_GOOGLE_BASEBOARD_BRYA select CHROMEOS_DSM_CALIB if CHROMEOS select CHROMEOS_DSM_PARAM_FILE_NAME if CHROMEOS + select DEFAULT_ADL_NEM select DRIVERS_GENESYSLOGIC_GL9750 select DRIVERS_I2C_MAX98390
@@ -108,6 +110,7 @@ config BOARD_GOOGLE_PRIMUS4ES bool "-> Primus4ES" select BOARD_GOOGLE_BASEBOARD_BRYA + select DEFAULT_ADL_NEM select DRIVERS_GENESYSLOGIC_GL9755 select HAVE_PCIE_WWAN select HAVE_WWAN_POWER_SEQUENCE @@ -129,6 +132,7 @@ select BOARD_GOOGLE_BASEBOARD_BRYA select CHROMEOS_DSM_CALIB if CHROMEOS select CHROMEOS_DSM_PARAM_FILE_NAME if CHROMEOS + select DEFAULT_ADL_NEM select DRIVERS_GENESYSLOGIC_GL9755 select DRIVERS_GFX_GENERIC select DRIVERS_I2C_MAX98390 @@ -139,6 +143,7 @@ config BOARD_GOOGLE_SKOLAS bool "-> Skolas" select BOARD_GOOGLE_BASEBOARD_SKOLAS + select DEFAULT_ADL_NEM select DRIVERS_GENESYSLOGIC_GL9755 select DRIVERS_INTEL_MIPI_CAMERA select DRIVERS_I2C_SX9324 @@ -148,6 +153,7 @@ config BOARD_GOOGLE_SKOLAS4ES bool "-> Skolas4ES" select BOARD_GOOGLE_BASEBOARD_SKOLAS + select DEFAULT_ADL_NEM select DRIVERS_GENESYSLOGIC_GL9755 select DRIVERS_INTEL_MIPI_CAMERA select DRIVERS_I2C_SX9324 @@ -166,6 +172,7 @@ config BOARD_GOOGLE_TAEKO4ES bool "-> Taeko4ES" select BOARD_GOOGLE_BASEBOARD_BRYA + select DEFAULT_ADL_NEM select DRIVERS_GENERIC_BAYHUB_LV2 select DRIVERS_GENESYSLOGIC_GL9750 select DRIVERS_GENESYSLOGIC_GL9763E @@ -174,6 +181,7 @@ config BOARD_GOOGLE_TANIKS bool "-> Taniks" select BOARD_GOOGLE_BASEBOARD_BRYA + select DEFAULT_ADL_NEM select DRIVERS_GENERIC_BAYHUB_LV2 select DRIVERS_GENESYSLOGIC_GL9750 select DRIVERS_GENESYSLOGIC_GL9763E @@ -297,6 +305,7 @@ config BOARD_GOOGLE_ZYDRON bool "-> Zydron" select BOARD_GOOGLE_BASEBOARD_SKOLAS + select DEFAULT_ADL_NEM select DRIVERS_I2C_MAX98373 select DRIVERS_I2C_NAU8825 select DRIVERS_INTEL_MIPI_CAMERA
