Attention is currently required from: Sean Rhodes.
Hello build bot (Jenkins),
https://review.coreboot.org/c/coreboot/+/83716?usp=email
The following approvals got outdated and were removed: Verified-1 by build bot (Jenkins)
Change subject: soc/inte/cnvi: Add AOLX Method ......................................................................
Add Audio Offload Method which is only supported on integrated solutions. This should be called by the Bluetooth companion device, i.e. HS10, to report when Audio Offload is enabled.
Change-Id: Ibeafb2b6e8a702430dcf10eb28bfeb9f77aa29b4 Signed-off-by: Sean Rhodes sean@starlabs.systems --- M src/soc/intel/common/block/cnvi/cnvi.c 1 file changed, 29 insertions(+), 0 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/16/83716/9
