Attention is currently required from: Eric Lai, Subrata Banik, YH Lin, dinesh.sharma@intel.com.
Hello Eric Lai, Subrata Banik, YH Lin, build bot (Jenkins), dinesh.sharma@intel.com,
https://review.coreboot.org/c/coreboot/+/83200?usp=email
Change subject: drivers/wifi: Support Bluetooth Regulator Domain Settings ......................................................................
The 'Bluetooth Increased Power Mode - SAR Limitation' feature provides ability to utilize increased device Transmit power capability for Bluetooth applications in coordination with Wi-Fi adhering to product SAR limit when Bluetooth and Wi-Fi run together.
This commit introduces a `bluetooth_companion' field to the generic Wi-Fi drivers chip data. This field can be set in the board design device tree to supply the bluetooth device for which the BRDS function must be created.
This feature is required for Meteor Lake rex karis variant.
The implementation follows document 559910 Intel Connectivity Platforms BIOS Guideline revision 8.3 specification.
BUG=b:348345301 BRANCH=firmware-rex-15709.B TEST=BRDS method is added to the CNVW device and return the data supplied by the SAR binary blob
Change-Id: Iebe95815c944d045f4cf686abcd1874a8a45e209 Signed-off-by: Jeremy Compostella jeremy.compostella@intel.com --- M src/drivers/wifi/generic/acpi.c M src/drivers/wifi/generic/chip.h M src/include/sar.h M src/vendorcode/google/chromeos/sar.c 4 files changed, 105 insertions(+), 5 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/00/83200/9
