Edward O'Callaghan (eocallaghan@alterapraxis.com) just uploaded a new patch set to gerrit, which you can find at http://review.coreboot.org/4802
commit 913505e990b9bd948db5140deaf88f6d80983f70 Author: Edward O'Callaghan eocallaghan@alterapraxis.com Date: Sun Jan 26 00:19:58 2014 +1100
util/superiotool: Add initial support for Fintek F71869AD.
See gerrit comment for Fintek F71869AD data-sheet.
Change-Id: Ia2ce8214d8b419d0ca0186e6f6b2241097b0847b Signed-off-by: Edward O'Callaghan eocallaghan@alterapraxis.com --- util/superiotool/README | 2 +- util/superiotool/fintek.c | 42 ++++++++++++++++++++++++++++++++++++++++++ 2 files changed, 43 insertions(+), 1 deletion(-)
diff --git a/util/superiotool/README b/util/superiotool/README index dfa6c1c..a7eb3db 100644 --- a/util/superiotool/README +++ b/util/superiotool/README @@ -93,6 +93,7 @@ Bingxun Shi bingxunshi@gmail.com Carl-Daniel Hailfinger c-d.hailfinger.devel.2006@gmx.net David Bartley dtbartle@csclub.uwaterloo.ca David Hendricks david.hendricks@gmail.com +Edward O'Callaghan eocallaghan@alterapraxis.com François-Regis Vuillemin coreboot@miradou.com Frieder Ferlemann Frieder.Ferlemann@web.de Idwer Vollering idwer_v@hotmail.com @@ -113,4 +114,3 @@ Ulf Jordan jordan@chalmers.se Urja Rannikko urjaman@gmail.com Uwe Hermann uwe@hermann-uwe.de Ward Vandewege ward@gnu.org - diff --git a/util/superiotool/fintek.c b/util/superiotool/fintek.c index 6ba962a..a86e4d0 100644 --- a/util/superiotool/fintek.c +++ b/util/superiotool/fintek.c @@ -3,6 +3,7 @@ * * Copyright (C) 2006 coresystems GmbH info@coresystems.de * Copyright (C) 2007-2008 Uwe Hermann uwe@hermann-uwe.de + * Copyright (C) 2014 Edward O'Callaghan eocallaghan@alterapraxis.com * * This program is free software; you can redistribute it and/or modify * it under the terms of the GNU General Public License as published by @@ -76,6 +77,47 @@ static const struct superio_registers reg_table[] = { {0x30,0xf0,0xf1,0xf4,0xf5,0xf7,EOT}, {0x00,0x00,NANA,0x06,0x1c,0x01,EOT}}, {EOT}}}, + {0x0710, "F71869AD", { /* XXX: verify correct product ID?? */ + /* We assume reserved bits are read as 0. */ + {NOLDN, NULL, + {0x20,0x21,0x23,0x24,0x25,0x26,0x27,0x28,0x29,0x2a, + 0x2b,0x2c,0x2d,EOT}, + {0x06,0x01,0x19,0x34,0x00,0x00,MISC,0x00,0x00,0x00, + 0x00,0x00,0x08,EOT}}, + {0x0, "Floppy", + {0x30,0x60,0x61,0x70,0x74,0xf0,0xf2,0xf4,EOT}, + {0x01,0x03,0xf0,0x06,0x02,0x0e,0x03,0x00,EOT}}, + {0x1, "COM1", + {0x30,0x60,0x61,0x70,0xf0,EOT}, + {0x01,0x03,0xf8,0x04,0x00,EOT}}, + {0x2, "COM2", + {0x30,0x60,0x61,0x70,0xf0,0xf1,EOT}, + {0x01,0x02,0xf8,0x03,0x00,0x04,EOT}}, + {0x3, "Parallel port", + {0x30,0x60,0x61,0x70,0x74,0xf0,EOT}, + {0x01,0x03,0x78,0x07,0x03,0x42,EOT}}, + {0x4, "Hardware monitor", + {0x30,0x60,0x61,0x70,EOT}, + {0x01,0x02,0x95,0x00,EOT}}, + {0x5, "Keyboard", + {0x30,0x60,0x61,0x70,0x72,0xf0,0xfe,0xff,EOT}, + {0x01,0x00,0x60,0x01,0x0c,0x83,0x81,0x29,EOT}}, + {0x6, "GPIO", + {0x30,0x60,0x61,0x70,0xf0,0xf1,0xf2,0xf3,0xe0,0xe1, + 0xe2,0xe3,0xe4,0xe5,0xe6,0xd0,0xd1,0xd2,0xd3,0xc0, + 0xc1,0xc2,0xb0,0xb1,0xb2,0xb3,0xa0,0xa1,0xa2,0xa3, + 0x90,0x91,0x92,0x93,EOT}, + {0x00,0x00,0x00,0x00,0x00,0x3f,NANA,0x00,0x00,0xff, + NANA,0x00,0x00,0x00,0x00,0x00,0xff,NANA,0x00,0x00, + 0xff,NANA,0x00,0x0f,NANA,0x00,0x00,0x1f,NANA,0x00, + 0x00,0x3f,NANA,0x00,EOT}}, + {0x7, "BSEL", + {0x30,0x60,0x61,0xf0,0xf2,0xf3,0xf4,0xf5,0xf6,0xf7,EOT}, + {0x00,0x00,0x00,0x01,0x00,0x00,NANA,0x00,0x0a,0x00,EOT}}, + {0xa, "PME, ACPI", + {0x30,0xf0,0xf1,0xf2,0xf3,0xf4,0xf5,0xf6,0xf7,0xf8,0xf9,0xfe,0xff,EOT}, + {0x00,0x00,0x00,NANA,NANA,0x06,0x1c,0x1f,0x86,0x00,0x00,0x00,0x00,EOT}}, + {EOT}}}, {0x2307, "F71889", { /* We assume reserved bits are read as 0. */ {NOLDN, NULL,
