Christian Walter has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/45869 )
Change subject: soc/intel/xeon_sp/cpx: Add locking of IA32_FEATURE_CONTROL and VMX ......................................................................
Change-Id: Ib329648f77acecccb0ced1806f61be252d03f2f4 Signed-off-by: Christian Walter christian.walter@9elements.com --- M src/soc/intel/xeon_sp/cpx/cpu.c 1 file changed, 4 insertions(+), 0 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/69/45869/1
diff --git a/src/soc/intel/xeon_sp/cpx/cpu.c b/src/soc/intel/xeon_sp/cpx/cpu.c index eb8c0eb..0999f6d 100644 --- a/src/soc/intel/xeon_sp/cpx/cpu.c +++ b/src/soc/intel/xeon_sp/cpx/cpu.c @@ -16,6 +16,7 @@ #include <soc/msr.h> #include <soc/soc_util.h> #include "chip.h" +#include <cpu/intel/common/common.h>
static const void *microcode_patch;
@@ -91,6 +92,9 @@
/* Clear out pending MCEs */ xeon_configure_mca(); + + /* Enable Vmx */ + set_vmx_and_lock(); }
static struct device_operations cpu_dev_ops = {
Patrick Rudolph has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/45869 )
Patch Set 3: Code-Review+2
Angel Pons has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/45869 )
Patch Set 4: Code-Review+2
FSP also has an UPD for VmxEnable or EnableVmx which should be set as well, using the Kconfig setting
Philipp Deppenwiese has submitted this change. ( https://review.coreboot.org/c/coreboot/+/45869 )
Change-Id: Ib329648f77acecccb0ced1806f61be252d03f2f4 Signed-off-by: Christian Walter christian.walter@9elements.com Reviewed-on: https://review.coreboot.org/c/coreboot/+/45869 Reviewed-by: Angel Pons th3fanbus@gmail.com Reviewed-by: Patrick Rudolph siro@das-labor.org Tested-by: build bot (Jenkins) no-reply@coreboot.org --- M src/soc/intel/xeon_sp/cpx/cpu.c 1 file changed, 4 insertions(+), 0 deletions(-)
Approvals: build bot (Jenkins): Verified Patrick Rudolph: Looks good to me, approved Angel Pons: Looks good to me, approved
@@ -91,6 +92,9 @@
