Attention is currently required from: Felix Held, Fred Reitberger, George Burgess, Martin L Roth, Matt DeVillier.
Hello Felix Held, Fred Reitberger, Martin L Roth, Matt DeVillier, build bot (Jenkins),
https://review.coreboot.org/c/coreboot/+/83412?usp=email
Change subject: amdfwtool: make fields unsigned ......................................................................
The value stored in `gen` is only ever `1` or `0`. Storing `1` causes Clang to warn, since the only valid values for a 1-bit int are -1 and 0: ``` amdfwtool.c:1487:27: error: implicit truncation from 'int' to a one-bit wide bit-field changes value from 1 to -1 [-Werror,-Wsingle-bit-bitfield-constant-conversion] 1487 | amd_romsig->efs_gen.gen = EFS_BEFORE_SECOND_GEN; ```
TEST=Rebuilt coreboot; no warning was emitted.
Change-Id: Ibd83be8302e8a717db7e7dc86a403b5648976586 Signed-off-by: George Burgess IV gbiv@google.com --- M util/amdfwtool/amdfwtool.h 1 file changed, 2 insertions(+), 2 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/12/83412/2
