Stefan Reinauer (stefan.reinauer@coreboot.org) just uploaded a new patch set to gerrit, which you can find at http://review.coreboot.org/3231
commit 3bdfbf1a212f81dab67be0731b76bbee2994d201 Author: Duncan Laurie dlaurie@chromium.org Date: Tue Apr 23 08:42:09 2013 -0700
Remove the wtm1 mainboard.
This was an early bring-up reference board for ULT but it is no longer being worked on and was never complete enough to be useful and I no longer have a board so it is already stale and untested.
All ULT bring-up work has moved to the wtm2 mainboard instead.
Change-Id: If64d61bf7a3fc8c9e16096ffc28fa4128aa99477 Signed-off-by: Duncan Laurie dlaurie@chromium.org Reviewed-on: https://gerrit.chromium.org/gerrit/48897 Reviewed-by: Aaron Durbin adurbin@chromium.org --- src/mainboard/intel/Kconfig | 3 - src/mainboard/intel/wtm1/Kconfig | 43 --- src/mainboard/intel/wtm1/Makefile.inc | 23 -- src/mainboard/intel/wtm1/acpi/chromeos.asl | 23 -- src/mainboard/intel/wtm1/acpi/ec.asl | 0 src/mainboard/intel/wtm1/acpi/haswell_pci_irqs.asl | 76 ----- src/mainboard/intel/wtm1/acpi/mainboard.asl | 28 -- src/mainboard/intel/wtm1/acpi/platform.asl | 73 ---- src/mainboard/intel/wtm1/acpi/superio.asl | 20 -- src/mainboard/intel/wtm1/acpi/thermal.asl | 246 -------------- src/mainboard/intel/wtm1/acpi/video.asl | 43 --- src/mainboard/intel/wtm1/acpi_tables.c | 291 ---------------- src/mainboard/intel/wtm1/chromeos.c | 78 ----- src/mainboard/intel/wtm1/cmos.layout | 139 -------- src/mainboard/intel/wtm1/devicetree.cb | 84 ----- src/mainboard/intel/wtm1/dsdt.asl | 58 ---- src/mainboard/intel/wtm1/fadt.c | 156 --------- src/mainboard/intel/wtm1/gpio.h | 371 --------------------- src/mainboard/intel/wtm1/hda_verb.h | 99 ------ src/mainboard/intel/wtm1/mainboard.c | 243 -------------- src/mainboard/intel/wtm1/mainboard_smi.c | 72 ---- src/mainboard/intel/wtm1/romstage.c | 128 ------- src/mainboard/intel/wtm1/thermal.h | 57 ---- 23 files changed, 2354 deletions(-)
diff --git a/src/mainboard/intel/Kconfig b/src/mainboard/intel/Kconfig index 3594a30..bb15bc1 100644 --- a/src/mainboard/intel/Kconfig +++ b/src/mainboard/intel/Kconfig @@ -21,8 +21,6 @@ config BOARD_INTEL_XE7501DEVKIT bool "XE7501devkit" config BOARD_INTEL_BASKING_RIDGE bool "Basking Ridge CRB" -config BOARD_INTEL_WTM1 - bool "Whitetip Mountain 1 CRB" config BOARD_INTEL_WTM2 bool "Whitetip Mountain 2 CRB"
@@ -37,7 +35,6 @@ source "src/mainboard/intel/jarrell/Kconfig" source "src/mainboard/intel/mtarvon/Kconfig" source "src/mainboard/intel/truxton/Kconfig" source "src/mainboard/intel/xe7501devkit/Kconfig" -source "src/mainboard/intel/wtm1/Kconfig" source "src/mainboard/intel/wtm2/Kconfig"
config MAINBOARD_VENDOR diff --git a/src/mainboard/intel/wtm1/Kconfig b/src/mainboard/intel/wtm1/Kconfig deleted file mode 100644 index 65db03f..0000000 --- a/src/mainboard/intel/wtm1/Kconfig +++ /dev/null @@ -1,43 +0,0 @@ -if BOARD_INTEL_WTM1 - -config BOARD_SPECIFIC_OPTIONS # dummy - def_bool y - select ARCH_X86 - select CPU_INTEL_SOCKET_RPGA989 - select NORTHBRIDGE_INTEL_HASWELL - select SOUTHBRIDGE_INTEL_LYNXPOINT - select INTEL_LYNXPOINT_LP - select BOARD_ROMSIZE_KB_8192 - select HAVE_ACPI_TABLES - select HAVE_OPTION_TABLE - select HAVE_ACPI_RESUME - select MMCONF_SUPPORT - select HAVE_SMI_HANDLER - select CHROMEOS - select EXTERNAL_MRC_BLOB - -config MAINBOARD_DIR - string - default intel/wtm1 - -config MAINBOARD_PART_NUMBER - string - default "WHITETIP MOUNTAIN 1" - -config MMCONF_BASE_ADDRESS - hex - default 0xf0000000 - -config IRQ_SLOT_COUNT - int - default 18 - -config MAX_CPUS - int - default 16 - -config VGA_BIOS_FILE - string - default "pci8086,0166.rom" - -endif # BOARD_INTEL_WTM1 diff --git a/src/mainboard/intel/wtm1/Makefile.inc b/src/mainboard/intel/wtm1/Makefile.inc deleted file mode 100644 index 658c96c..0000000 --- a/src/mainboard/intel/wtm1/Makefile.inc +++ /dev/null @@ -1,23 +0,0 @@ -## -## This file is part of the coreboot project. -## -## Copyright (C) 2011 Google Inc. -## -## This program is free software; you can redistribute it and/or modify -## it under the terms of the GNU General Public License as published by -## the Free Software Foundation; version 2 of the License. -## -## This program is distributed in the hope that it will be useful, -## but WITHOUT ANY WARRANTY; without even the implied warranty of -## MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the -## GNU General Public License for more details. -## -## You should have received a copy of the GNU General Public License -## along with this program; if not, write to the Free Software -## Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA -## - -romstage-$(CONFIG_CHROMEOS) += chromeos.c -ramstage-$(CONFIG_CHROMEOS) += chromeos.c - -smm-$(CONFIG_HAVE_SMI_HANDLER) += mainboard_smi.c diff --git a/src/mainboard/intel/wtm1/acpi/chromeos.asl b/src/mainboard/intel/wtm1/acpi/chromeos.asl deleted file mode 100644 index c6b258b..0000000 --- a/src/mainboard/intel/wtm1/acpi/chromeos.asl +++ /dev/null @@ -1,23 +0,0 @@ -/* - * This file is part of the coreboot project. - * - * Copyright (C) 2011 Google Inc. - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License as published by - * the Free Software Foundation; version 2 of the License. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA - */ - -Name(OIPG, Package() { - // This GPIO is not available but the package cannot be empty - Package () { 0x0001, 0, 0, "LynxPoint" }, // recovery -}) diff --git a/src/mainboard/intel/wtm1/acpi/ec.asl b/src/mainboard/intel/wtm1/acpi/ec.asl deleted file mode 100644 index e69de29..0000000 diff --git a/src/mainboard/intel/wtm1/acpi/haswell_pci_irqs.asl b/src/mainboard/intel/wtm1/acpi/haswell_pci_irqs.asl deleted file mode 100644 index a8b6b5f..0000000 --- a/src/mainboard/intel/wtm1/acpi/haswell_pci_irqs.asl +++ /dev/null @@ -1,76 +0,0 @@ -/* - * This file is part of the coreboot project. - * - * Copyright (C) 2007-2009 coresystems GmbH - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License as published by - * the Free Software Foundation; version 2 of the License. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA - */ - -/* This is board specific information: IRQ routing for IvyBridge */ - -// PCI Interrupt Routing -Method(_PRT) -{ - If (PICM) { - Return (Package() { - // Onboard graphics (IGD) 0:2.0 - Package() { 0x0002ffff, 0, 0, 16 }, - // High Definition Audio 0:1b.0 - Package() { 0x001bffff, 0, 0, 22 }, - // PCIe Root Ports 0:1c.x - Package() { 0x001cffff, 0, 0, 17 }, - Package() { 0x001cffff, 1, 0, 18 }, - Package() { 0x001cffff, 2, 0, 19 }, - Package() { 0x001cffff, 3, 0, 20 }, - // EHCI 0:1d.0 - Package() { 0x001dffff, 0, 0, 19 }, - // XHCI 0:14.0 - Package() { 0x0014ffff, 0, 0, 16 }, - // LPC devices 0:1f.0 - Package() { 0x001fffff, 0, 0, 21 }, - Package() { 0x001fffff, 1, 0, 22 }, - Package() { 0x001fffff, 2, 0, 23 }, - Package() { 0x001fffff, 3, 0, 16 }, - // Serial IO 0:15.0 - Package() { 0x0015ffff, 0, 0, 16 }, - Package() { 0x0015ffff, 1, 0, 17 }, - Package() { 0x0015ffff, 2, 0, 18 }, - Package() { 0x0015ffff, 3, 0, 19 }, - // SDIO 0:17.0 - Package() { 0x0017ffff, 0, 0, 16 }, - }) - } Else { - Return (Package() { - // Onboard graphics (IGD) 0:2.0 - Package() { 0x0002ffff, 0, _SB.PCI0.LPCB.LNKA, 0 }, - // High Definition Audio 0:1b.0 - Package() { 0x001bffff, 0, _SB.PCI0.LPCB.LNKG, 0 }, - // PCIe Root Ports 0:1c.x - Package() { 0x001cffff, 0, _SB.PCI0.LPCB.LNKB, 0 }, - Package() { 0x001cffff, 1, _SB.PCI0.LPCB.LNKC, 0 }, - Package() { 0x001cffff, 2, _SB.PCI0.LPCB.LNKD, 0 }, - Package() { 0x001cffff, 3, _SB.PCI0.LPCB.LNKE, 0 }, - // EHCI #1 0:1d.0 - Package() { 0x001dffff, 0, _SB.PCI0.LPCB.LNKD, 0 }, - // EHCI #2 0:1a.0 - Package() { 0x001affff, 0, _SB.PCI0.LPCB.LNKE, 0 }, - // LPC device 0:1f.0 - Package() { 0x001fffff, 0, _SB.PCI0.LPCB.LNKF, 0 }, - Package() { 0x001fffff, 1, _SB.PCI0.LPCB.LNKG, 0 }, - Package() { 0x001fffff, 2, _SB.PCI0.LPCB.LNKH, 0 }, - Package() { 0x001fffff, 3, _SB.PCI0.LPCB.LNKA, 0 }, - }) - } -} - diff --git a/src/mainboard/intel/wtm1/acpi/mainboard.asl b/src/mainboard/intel/wtm1/acpi/mainboard.asl deleted file mode 100644 index 6b15331..0000000 --- a/src/mainboard/intel/wtm1/acpi/mainboard.asl +++ /dev/null @@ -1,28 +0,0 @@ -/* - * This file is part of the coreboot project. - * - * Copyright (C) 2011 Google Inc. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; version 2 of - * the License. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, - * MA 02110-1301 USA - */ - -Device (PWRB) -{ - Name(_HID, EisaId("PNP0C0C")) - - // Wake - Name(_PRW, Package(){0x1d, 0x05}) -} diff --git a/src/mainboard/intel/wtm1/acpi/platform.asl b/src/mainboard/intel/wtm1/acpi/platform.asl deleted file mode 100644 index e069392..0000000 --- a/src/mainboard/intel/wtm1/acpi/platform.asl +++ /dev/null @@ -1,73 +0,0 @@ -/* - * This file is part of the coreboot project. - * - * Copyright (C) 2007-2009 coresystems GmbH - * Copyright (C) 2012 Google Inc. - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License as published by - * the Free Software Foundation; version 2 of the License. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA - */ - -/* The APM port can be used for generating software SMIs */ - -OperationRegion (APMP, SystemIO, 0xb2, 2) -Field (APMP, ByteAcc, NoLock, Preserve) -{ - APMC, 8, // APM command - APMS, 8 // APM status -} - -/* Port 80 POST */ - -OperationRegion (POST, SystemIO, 0x80, 1) -Field (POST, ByteAcc, Lock, Preserve) -{ - DBG0, 8 -} - -/* SMI I/O Trap */ -Method(TRAP, 1, Serialized) -{ - Store (Arg0, SMIF) // SMI Function - Store (0, TRP0) // Generate trap - Return (SMIF) // Return value of SMI handler -} - -/* The _PIC method is called by the OS to choose between interrupt - * routing via the i8259 interrupt controller or the APIC. - * - * _PIC is called with a parameter of 0 for i8259 configuration and - * with a parameter of 1 for Local Apic/IOAPIC configuration. - */ - -Method(_PIC, 1) -{ - // Remember the OS' IRQ routing choice. - Store(Arg0, PICM) -} - -/* The _PTS method (Prepare To Sleep) is called before the OS is - * entering a sleep state. The sleep state number is passed in Arg0 - */ - -Method(_PTS,1) -{ -} - -/* The _WAK method is called on system wakeup */ - -Method(_WAK,1) -{ - Return(Package(){0,0}) -} - diff --git a/src/mainboard/intel/wtm1/acpi/superio.asl b/src/mainboard/intel/wtm1/acpi/superio.asl deleted file mode 100644 index 9092a6c..0000000 --- a/src/mainboard/intel/wtm1/acpi/superio.asl +++ /dev/null @@ -1,20 +0,0 @@ -/* - * This file is part of the coreboot project. - * - * Copyright (C) 2011 Google Inc. - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License as published by - * the Free Software Foundation; version 2 of the License. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA - */ - -/* Values should match those defined in devicetree.cb */ diff --git a/src/mainboard/intel/wtm1/acpi/thermal.asl b/src/mainboard/intel/wtm1/acpi/thermal.asl deleted file mode 100644 index 00a8750..0000000 --- a/src/mainboard/intel/wtm1/acpi/thermal.asl +++ /dev/null @@ -1,246 +0,0 @@ -/* - * This file is part of the coreboot project. - * - * Copyright (C) 2011 Google Inc. - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License as published by - * the Free Software Foundation; version 2 of the License. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA - */ - -// Thermal Zone - -Scope (_TZ) -{ - ThermalZone (THRM) - { - Name (_TC1, 0x02) - Name (_TC2, 0x05) - - // Thermal zone polling frequency: 0 seconds - Name (_TZP, 0) - - // Thermal sampling period for passive cooling: 2 seconds - Name (_TSP, 20) - - // Convert from Degrees C to 1/10 Kelvin for ACPI - Method (CTOK, 1) { - // 10th of Degrees C - Multiply (Arg0, 10, Local0) - - // Convert to Kelvin - Add (Local0, 2732, Local0) - - Return (Local0) - } - - // Threshold for OS to shutdown - Method (_CRT, 0, Serialized) - { - Return (CTOK (\TCRT)) - } - - // Threshold for passive cooling - Method (_PSV, 0, Serialized) - { - Return (CTOK (\TPSV)) - } - - // Processors used for passive cooling - Method (_PSL, 0, Serialized) - { - Return (\PPKG ()) - } - - Method (_TMP, 0, Serialized) - { - Return (CTOK (30)) - } - - Method (_AC0) { - If (LLessEqual (\FLVL, 0)) { - Return (CTOK (\F0OF)) - } Else { - Return (CTOK (\F0ON)) - } - } - - Method (_AC1) { - If (LLessEqual (\FLVL, 1)) { - Return (CTOK (\F1OF)) - } Else { - Return (CTOK (\F1ON)) - } - } - - Method (_AC2) { - If (LLessEqual (\FLVL, 2)) { - Return (CTOK (\F2OF)) - } Else { - Return (CTOK (\F2ON)) - } - } - - Method (_AC3) { - If (LLessEqual (\FLVL, 3)) { - Return (CTOK (\F3OF)) - } Else { - Return (CTOK (\F3ON)) - } - } - - Method (_AC4) { - If (LLessEqual (\FLVL, 4)) { - Return (CTOK (\F4OF)) - } Else { - Return (CTOK (\F4ON)) - } - } - - Name (_AL0, Package () { FAN0 }) - Name (_AL1, Package () { FAN1 }) - Name (_AL2, Package () { FAN2 }) - Name (_AL3, Package () { FAN3 }) - Name (_AL4, Package () { FAN4 }) - - PowerResource (FNP0, 0, 0) - { - Method (_STA) { - If (LLessEqual (\FLVL, 0)) { - Return (One) - } Else { - Return (Zero) - } - } - Method (_ON) { - Store (0, \FLVL) - Notify (_TZ.THRM, 0x81) - } - Method (_OFF) { - Store (1, \FLVL) - Notify (_TZ.THRM, 0x81) - } - } - - PowerResource (FNP1, 0, 0) - { - Method (_STA) { - If (LLessEqual (\FLVL, 1)) { - Return (One) - } Else { - Return (Zero) - } - } - Method (_ON) { - Store (1, \FLVL) - Notify (_TZ.THRM, 0x81) - } - Method (_OFF) { - Store (2, \FLVL) - Notify (_TZ.THRM, 0x81) - } - } - - PowerResource (FNP2, 0, 0) - { - Method (_STA) { - If (LLessEqual (\FLVL, 2)) { - Return (One) - } Else { - Return (Zero) - } - } - Method (_ON) { - Store (2, \FLVL) - Notify (_TZ.THRM, 0x81) - } - Method (_OFF) { - Store (3, \FLVL) - Notify (_TZ.THRM, 0x81) - } - } - - PowerResource (FNP3, 0, 0) - { - Method (_STA) { - If (LLessEqual (\FLVL, 3)) { - Return (One) - } Else { - Return (Zero) - } - } - Method (_ON) { - Store (3, \FLVL) - Notify (_TZ.THRM, 0x81) - } - Method (_OFF) { - Store (4, \FLVL) - Notify (_TZ.THRM, 0x81) - } - } - - PowerResource (FNP4, 0, 0) - { - Method (_STA) { - If (LLessEqual (\FLVL, 4)) { - Return (One) - } Else { - Return (Zero) - } - } - Method (_ON) { - Store (4, \FLVL) - Notify (_TZ.THRM, 0x81) - } - Method (_OFF) { - Store (4, \FLVL) - Notify (_TZ.THRM, 0x81) - } - } - - Device (FAN0) - { - Name (_HID, EISAID ("PNP0C0B")) - Name (_UID, 0) - Name (_PR0, Package () { FNP0 }) - } - - Device (FAN1) - { - Name (_HID, EISAID ("PNP0C0B")) - Name (_UID, 1) - Name (_PR0, Package () { FNP1 }) - } - - Device (FAN2) - { - Name (_HID, EISAID ("PNP0C0B")) - Name (_UID, 2) - Name (_PR0, Package () { FNP2 }) - } - - Device (FAN3) - { - Name (_HID, EISAID ("PNP0C0B")) - Name (_UID, 3) - Name (_PR0, Package () { FNP3 }) - } - - Device (FAN4) - { - Name (_HID, EISAID ("PNP0C0B")) - Name (_UID, 4) - Name (_PR0, Package () { FNP4 }) - } - } -} - diff --git a/src/mainboard/intel/wtm1/acpi/video.asl b/src/mainboard/intel/wtm1/acpi/video.asl deleted file mode 100644 index 3ececa9..0000000 --- a/src/mainboard/intel/wtm1/acpi/video.asl +++ /dev/null @@ -1,43 +0,0 @@ -/* - * This file is part of the coreboot project. - * - * Copyright (C) 2007-2009 coresystems GmbH - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License as published by - * the Free Software Foundation; version 2 of the License. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA - */ - -// Brightness write -Method (BRTW, 1, Serialized) -{ - // TODO -} - -// Hot Key Display Switch -Method (HKDS, 1, Serialized) -{ - // TODO -} - -// Lid Switch Display Switch -Method (LSDS, 1, Serialized) -{ - // TODO -} - -// Brightness Notification -Method(BRTN,1,Serialized) -{ - // TODO (no displays defined yet) -} - diff --git a/src/mainboard/intel/wtm1/acpi_tables.c b/src/mainboard/intel/wtm1/acpi_tables.c deleted file mode 100644 index 16a1c6a..0000000 --- a/src/mainboard/intel/wtm1/acpi_tables.c +++ /dev/null @@ -1,291 +0,0 @@ -/* - * This file is part of the coreboot project. - * - * Copyright (C) 2012 Google Inc. - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License as published by - * the Free Software Foundation; version 2 of the License. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA - */ - -#include <types.h> -#include <string.h> -#include <cbmem.h> -#include <console/console.h> -#include <arch/acpi.h> -#include <arch/ioapic.h> -#include <arch/acpigen.h> -#include <arch/smp/mpspec.h> -#include <device/device.h> -#include <device/pci.h> -#include <device/pci_ids.h> -#include <cpu/cpu.h> -#include <cpu/x86/msr.h> -#include <vendorcode/google/chromeos/gnvs.h> - -extern const unsigned char AmlCode[]; -#if CONFIG_HAVE_ACPI_SLIC -unsigned long acpi_create_slic(unsigned long current); -#endif - -#include <southbridge/intel/lynxpoint/pch.h> -#include <southbridge/intel/lynxpoint/nvs.h> -#include "thermal.h" - -static void acpi_update_thermal_table(global_nvs_t *gnvs) -{ - gnvs->f4of = FAN4_THRESHOLD_OFF; - gnvs->f4on = FAN4_THRESHOLD_ON; - gnvs->f4pw = FAN4_PWM; - - gnvs->f3of = FAN3_THRESHOLD_OFF; - gnvs->f3on = FAN3_THRESHOLD_ON; - gnvs->f3pw = FAN3_PWM; - - gnvs->f2of = FAN2_THRESHOLD_OFF; - gnvs->f2on = FAN2_THRESHOLD_ON; - gnvs->f2pw = FAN2_PWM; - - gnvs->f1of = FAN1_THRESHOLD_OFF; - gnvs->f1on = FAN1_THRESHOLD_ON; - gnvs->f1pw = FAN1_PWM; - - gnvs->f0of = FAN0_THRESHOLD_OFF; - gnvs->f0on = FAN0_THRESHOLD_ON; - gnvs->f0pw = FAN0_PWM; - - gnvs->tcrt = CRITICAL_TEMPERATURE; - gnvs->tpsv = PASSIVE_TEMPERATURE; - gnvs->tmax = MAX_TEMPERATURE; -} - -static void acpi_create_gnvs(global_nvs_t *gnvs) -{ - gnvs->apic = 1; - gnvs->mpen = 1; /* Enable Multi Processing */ - gnvs->pcnt = dev_count_cpu(); - - /* Enable USB ports in S3 */ - gnvs->s3u0 = 1; - gnvs->s3u1 = 1; - - /* Disable USB ports in S5 */ - gnvs->s5u0 = 0; - gnvs->s5u1 = 0; - - /* CBMEM TOC */ - gnvs->cmem = 0; - - /* TPM Present */ - gnvs->tpmp = 1; - - /* IGD Displays */ - gnvs->ndid = 3; - gnvs->did[0] = 0x80000100; - gnvs->did[1] = 0x80000240; - gnvs->did[2] = 0x80000410; - gnvs->did[3] = 0x80000410; - gnvs->did[4] = 0x00000005; - -#if CONFIG_CHROMEOS - // TODO(reinauer) this could move elsewhere? - chromeos_init_vboot(&(gnvs->chromeos)); - /* Emerald Lake has no EC (?) */ - gnvs->chromeos.vbt2 = ACTIVE_ECFW_RO; -#endif - - acpi_update_thermal_table(gnvs); -} - -unsigned long acpi_fill_madt(unsigned long current) -{ - /* Local APICs */ - current = acpi_create_madt_lapics(current); - - /* IOAPIC */ - current += acpi_create_madt_ioapic((acpi_madt_ioapic_t *) current, - 2, IO_APIC_ADDR, 0); - - /* INT_SRC_OVR */ - current += acpi_create_madt_irqoverride((acpi_madt_irqoverride_t *) - current, 0, 0, 2, 0); - current += acpi_create_madt_irqoverride((acpi_madt_irqoverride_t *) - current, 0, 9, 9, MP_IRQ_TRIGGER_LEVEL | MP_IRQ_POLARITY_HIGH); - - return current; -} - -unsigned long acpi_fill_ssdt_generator(unsigned long current, - const char *oem_table_id) -{ - generate_cpu_entries(); - return (unsigned long) (acpigen_get_current()); -} - -unsigned long acpi_fill_slit(unsigned long current) -{ - // Not implemented - return current; -} - -unsigned long acpi_fill_srat(unsigned long current) -{ - /* No NUMA, no SRAT */ - return current; -} - -#define ALIGN_CURRENT current = (ALIGN(current, 16)) -unsigned long write_acpi_tables(unsigned long start) -{ - unsigned long current; - int i; - acpi_rsdp_t *rsdp; - acpi_rsdt_t *rsdt; - acpi_xsdt_t *xsdt; - acpi_hpet_t *hpet; - acpi_madt_t *madt; - acpi_mcfg_t *mcfg; - acpi_fadt_t *fadt; - acpi_facs_t *facs; -#if CONFIG_HAVE_ACPI_SLIC - acpi_header_t *slic; -#endif - acpi_header_t *ssdt; - acpi_header_t *dsdt; - global_nvs_t *gnvs; - - current = start; - - /* Align ACPI tables to 16byte */ - ALIGN_CURRENT; - - printk(BIOS_INFO, "ACPI: Writing ACPI tables at %lx.\n", start); - - /* We need at least an RSDP and an RSDT Table */ - rsdp = (acpi_rsdp_t *) current; - current += sizeof(acpi_rsdp_t); - ALIGN_CURRENT; - rsdt = (acpi_rsdt_t *) current; - current += sizeof(acpi_rsdt_t); - ALIGN_CURRENT; - xsdt = (acpi_xsdt_t *) current; - current += sizeof(acpi_xsdt_t); - ALIGN_CURRENT; - - /* clear all table memory */ - memset((void *) start, 0, current - start); - - acpi_write_rsdp(rsdp, rsdt, xsdt); - acpi_write_rsdt(rsdt); - acpi_write_xsdt(xsdt); - - printk(BIOS_DEBUG, "ACPI: * FACS\n"); - facs = (acpi_facs_t *) current; - current += sizeof(acpi_facs_t); - ALIGN_CURRENT; - acpi_create_facs(facs); - - printk(BIOS_DEBUG, "ACPI: * DSDT\n"); - dsdt = (acpi_header_t *) current; - memcpy(dsdt, &AmlCode, sizeof(acpi_header_t)); - current += dsdt->length; - memcpy(dsdt, &AmlCode, dsdt->length); - - ALIGN_CURRENT; - - printk(BIOS_DEBUG, "ACPI: * FADT\n"); - fadt = (acpi_fadt_t *) current; - current += sizeof(acpi_fadt_t); - ALIGN_CURRENT; - - acpi_create_fadt(fadt, facs, dsdt); - acpi_add_table(rsdp, fadt); - - /* - * We explicitly add these tables later on: - */ - printk(BIOS_DEBUG, "ACPI: * HPET\n"); - - hpet = (acpi_hpet_t *) current; - current += sizeof(acpi_hpet_t); - ALIGN_CURRENT; - acpi_create_intel_hpet(hpet); - acpi_add_table(rsdp, hpet); - - /* If we want to use HPET Timers Linux wants an MADT */ - printk(BIOS_DEBUG, "ACPI: * MADT\n"); - - madt = (acpi_madt_t *) current; - acpi_create_madt(madt); - current += madt->header.length; - ALIGN_CURRENT; - acpi_add_table(rsdp, madt); - - printk(BIOS_DEBUG, "ACPI: * MCFG\n"); - mcfg = (acpi_mcfg_t *) current; - acpi_create_mcfg(mcfg); - current += mcfg->header.length; - ALIGN_CURRENT; - acpi_add_table(rsdp, mcfg); - - /* Update GNVS pointer into CBMEM */ - gnvs = cbmem_find(CBMEM_ID_ACPI_GNVS); - if (!gnvs) { - printk(BIOS_DEBUG, "ACPI: Could not find CBMEM GNVS\n"); - gnvs = (global_nvs_t *)current; - } - - for (i=0; i < dsdt->length; i++) { - if (*(u32*)(((u32)dsdt) + i) == 0xC0DEBABE) { - printk(BIOS_DEBUG, "ACPI: Patching up global NVS in " - "DSDT at offset 0x%04x -> %p\n", i, gnvs); - *(u32*)(((u32)dsdt) + i) = (unsigned long)gnvs; - acpi_save_gnvs((unsigned long)gnvs); - break; - } - } - - /* And fill it */ - acpi_create_gnvs(gnvs); - - /* And tell SMI about it */ - smm_setup_structures(gnvs, NULL, NULL); - - current += sizeof(global_nvs_t); - ALIGN_CURRENT; - - /* We patched up the DSDT, so we need to recalculate the checksum */ - dsdt->checksum = 0; - dsdt->checksum = acpi_checksum((void *)dsdt, dsdt->length); - - printk(BIOS_DEBUG, "ACPI: * DSDT @ %p Length %x\n", dsdt, - dsdt->length); - -#if CONFIG_HAVE_ACPI_SLIC - printk(BIOS_DEBUG, "ACPI: * SLIC\n"); - slic = (acpi_header_t *)current; - current += acpi_create_slic(current); - ALIGN_CURRENT; - acpi_add_table(rsdp, slic); -#endif - - printk(BIOS_DEBUG, "ACPI: * SSDT\n"); - ssdt = (acpi_header_t *)current; - acpi_create_ssdt_generator(ssdt, ACPI_TABLE_CREATOR); - current += ssdt->length; - acpi_add_table(rsdp, ssdt); - ALIGN_CURRENT; - - printk(BIOS_DEBUG, "current = %lx\n", current); - printk(BIOS_INFO, "ACPI: done.\n"); - return current; -} diff --git a/src/mainboard/intel/wtm1/chromeos.c b/src/mainboard/intel/wtm1/chromeos.c deleted file mode 100644 index f896076..0000000 --- a/src/mainboard/intel/wtm1/chromeos.c +++ /dev/null @@ -1,78 +0,0 @@ -/* - * This file is part of the coreboot project. - * - * Copyright (C) 2012 Google Inc. - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License as published by - * the Free Software Foundation; version 2 of the License. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA - */ - -#include <string.h> -#include <vendorcode/google/chromeos/chromeos.h> -#include <arch/io.h> -#include <device/device.h> -#include <device/pci.h> -#include <southbridge/intel/lynxpoint/pch.h> - -#ifndef __PRE_RAM__ -#include <boot/coreboot_tables.h> - -#define GPIO_COUNT 6 -#define ACTIVE_LOW 0 -#define ACTIVE_HIGH 1 - -static void fill_lb_gpio(struct lb_gpio *gpio, int num, - int polarity, const char *name, int force) -{ - memset(gpio, 0, sizeof(*gpio)); - gpio->port = num; - gpio->polarity = polarity; - if (force >= 0) - gpio->value = force; - else if (num >= 0) - gpio->value = get_gpio(num); - strncpy((char *)gpio->name, name, GPIO_MAX_NAME_LENGTH); -} - -void fill_lb_gpios(struct lb_gpios *gpios) -{ - struct lb_gpio *gpio; - - gpios->size = sizeof(*gpios) + (GPIO_COUNT * sizeof(struct lb_gpio)); - gpios->count = GPIO_COUNT; - - gpio = gpios->gpios; - fill_lb_gpio(gpio++, -1, ACTIVE_HIGH, "write protect", 0); - fill_lb_gpio(gpio++, -1, ACTIVE_HIGH, "recovery", 0); // force off - fill_lb_gpio(gpio++, -1, ACTIVE_HIGH, "developer", 1); // force on - fill_lb_gpio(gpio++, -1, ACTIVE_HIGH, "lid", 1); // force open - fill_lb_gpio(gpio++, -1, ACTIVE_HIGH, "power", 0); - fill_lb_gpio(gpio++, -1, ACTIVE_HIGH, "oprom", oprom_is_loaded); -} -#endif - -int get_developer_mode_switch(void) -{ - return 1; // force on -} - -int get_recovery_mode_switch(void) -{ - return 0; // force off -} - -int get_write_protect_state(void) -{ - return 0; -} - diff --git a/src/mainboard/intel/wtm1/cmos.layout b/src/mainboard/intel/wtm1/cmos.layout deleted file mode 100644 index afdd3c6..0000000 --- a/src/mainboard/intel/wtm1/cmos.layout +++ /dev/null @@ -1,139 +0,0 @@ -## -## This file is part of the coreboot project. -## -## Copyright (C) 2007-2008 coresystems GmbH -## -## This program is free software; you can redistribute it and/or modify -## it under the terms of the GNU General Public License as published by -## the Free Software Foundation; version 2 of the License. -## -## This program is distributed in the hope that it will be useful, -## but WITHOUT ANY WARRANTY; without even the implied warranty of -## MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the -## GNU General Public License for more details. -## -## You should have received a copy of the GNU General Public License -## along with this program; if not, write to the Free Software -## Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA -## - -# ----------------------------------------------------------------- -entries - -#start-bit length config config-ID name -#0 8 r 0 seconds -#8 8 r 0 alarm_seconds -#16 8 r 0 minutes -#24 8 r 0 alarm_minutes -#32 8 r 0 hours -#40 8 r 0 alarm_hours -#48 8 r 0 day_of_week -#56 8 r 0 day_of_month -#64 8 r 0 month -#72 8 r 0 year -# ----------------------------------------------------------------- -# Status Register A -#80 4 r 0 rate_select -#84 3 r 0 REF_Clock -#87 1 r 0 UIP -# ----------------------------------------------------------------- -# Status Register B -#88 1 r 0 auto_switch_DST -#89 1 r 0 24_hour_mode -#90 1 r 0 binary_values_enable -#91 1 r 0 square-wave_out_enable -#92 1 r 0 update_finished_enable -#93 1 r 0 alarm_interrupt_enable -#94 1 r 0 periodic_interrupt_enable -#95 1 r 0 disable_clock_updates -# ----------------------------------------------------------------- -# Status Register C -#96 4 r 0 status_c_rsvd -#100 1 r 0 uf_flag -#101 1 r 0 af_flag -#102 1 r 0 pf_flag -#103 1 r 0 irqf_flag -# ----------------------------------------------------------------- -# Status Register D -#104 7 r 0 status_d_rsvd -#111 1 r 0 valid_cmos_ram -# ----------------------------------------------------------------- -# Diagnostic Status Register -#112 8 r 0 diag_rsvd1 - -# ----------------------------------------------------------------- -0 120 r 0 reserved_memory -#120 264 r 0 unused - -# ----------------------------------------------------------------- -# RTC_BOOT_BYTE (coreboot hardcoded) -384 1 e 4 boot_option -385 1 e 4 last_boot -388 4 r 0 reboot_bits -#390 2 r 0 unused? - -# ----------------------------------------------------------------- -# coreboot config options: console -392 3 e 5 baud_rate -395 4 e 6 debug_level -#399 1 r 0 unused - -# coreboot config options: cpu -400 1 e 2 hyper_threading -#401 7 r 0 unused - -# coreboot config options: southbridge -408 1 e 1 nmi -409 2 e 7 power_on_after_fail -#411 5 r 0 unused - -# coreboot config options: bootloader -#Used by ChromeOS: -416 128 r 0 vbnv -#544 440 r 0 unused - -# SandyBridge MRC Scrambler Seed values -896 32 r 0 mrc_scrambler_seed -928 32 r 0 mrc_scrambler_seed_s3 - -# coreboot config options: check sums -984 16 h 0 check_sum -#1000 24 r 0 amd_reserved - -# ----------------------------------------------------------------- - -enumerations - -#ID value text -1 0 Disable -1 1 Enable -2 0 Enable -2 1 Disable -4 0 Fallback -4 1 Normal -5 0 115200 -5 1 57600 -5 2 38400 -5 3 19200 -5 4 9600 -5 5 4800 -5 6 2400 -5 7 1200 -6 1 Emergency -6 2 Alert -6 3 Critical -6 4 Error -6 5 Warning -6 6 Notice -6 7 Info -6 8 Debug -6 9 Spew -7 0 Disable -7 1 Enable -7 2 Keep -# ----------------------------------------------------------------- -checksums - -checksum 392 415 984 - - diff --git a/src/mainboard/intel/wtm1/devicetree.cb b/src/mainboard/intel/wtm1/devicetree.cb deleted file mode 100644 index be4fe51..0000000 --- a/src/mainboard/intel/wtm1/devicetree.cb +++ /dev/null @@ -1,84 +0,0 @@ -chip northbridge/intel/haswell - - # Enable DisplayPort 1 Hotplug with 6ms pulse - register "gpu_dp_d_hotplug" = "0x06" - - # Enable DisplayPort 0 Hotplug with 6ms pulse - register "gpu_dp_c_hotplug" = "0x06" - - # Enable DVI Hotplug with 6ms pulse - register "gpu_dp_b_hotplug" = "0x06" - - device cpu_cluster 0 on - chip cpu/intel/socket_rPGA989 - device lapic 0 on end - end - chip cpu/intel/haswell - # Magic APIC ID to locate this chip - device lapic 0xACAC off end - - register "c1_battery" = "3" # ACPI(C1) = MWAIT(C3) - register "c2_battery" = "4" # ACPI(C2) = MWAIT(C6) - register "c3_battery" = "5" # ACPI(C3) = MWAIT(C7) - - register "c1_acpower" = "3" # ACPI(C1) = MWAIT(C3) - register "c2_acpower" = "4" # ACPI(C2) = MWAIT(C6) - register "c3_acpower" = "5" # ACPI(C3) = MWAIT(C7) - end - end - - device domain 0 on - device pci 00.0 on end # host bridge - device pci 02.0 on end # vga controller - - chip southbridge/intel/lynxpoint # Intel Series 8 Lynx Point PCH - register "pirqa_routing" = "0x8b" - register "pirqb_routing" = "0x8a" - register "pirqc_routing" = "0x8b" - register "pirqd_routing" = "0x8b" - register "pirqe_routing" = "0x80" - register "pirqf_routing" = "0x80" - register "pirqg_routing" = "0x80" - register "pirqh_routing" = "0x80" - - register "alt_gp_smi_en" = "0x0000" - register "gpe0_en_1" = "0x00000000" - register "gpe0_en_2" = "0x00000000" - register "gpe0_en_3" = "0x00000000" - register "gpe0_en_4" = "0x00000000" - - register "ide_legacy_combined" = "0x0" - register "sata_ahci" = "0x1" - register "sata_port_map" = "0x2" - - device pci 13.0 on end # Smart Sound Audio DSP - device pci 14.0 on end # USB3 XHCI - device pci 15.0 off end # Serial I/O DMA - device pci 15.1 off end # I2C0 - device pci 15.2 off end # I2C1 - device pci 15.3 off end # GSPI0 - device pci 15.4 off end # GSPI1 - device pci 15.5 off end # UART0 - device pci 15.6 off end # UART1 - device pci 16.0 on end # Management Engine Interface 1 - device pci 16.1 off end # Management Engine Interface 2 - device pci 16.2 off end # Management Engine IDE-R - device pci 16.3 off end # Management Engine KT - device pci 17.0 off end # SDIO - device pci 19.0 on end # GbE - device pci 1b.0 on end # High Definition Audio - device pci 1c.0 on end # PCIe Port #1 - device pci 1c.1 on end # PCIe Port #2 - device pci 1c.2 on end # PCIe Port #3 - device pci 1c.3 on end # PCIe Port #4 - device pci 1c.4 on end # PCIe Port #5 - device pci 1c.5 on end # PCIe Port #6 - device pci 1d.0 on end # USB2 EHCI - device pci 1e.0 off end # PCI bridge - device pci 1f.0 on end # LPC bridge - device pci 1f.2 on end # SATA Controller - device pci 1f.3 on end # SMBus - device pci 1f.6 on end # Thermal - end - end -end diff --git a/src/mainboard/intel/wtm1/dsdt.asl b/src/mainboard/intel/wtm1/dsdt.asl deleted file mode 100644 index 81e39c3..0000000 --- a/src/mainboard/intel/wtm1/dsdt.asl +++ /dev/null @@ -1,58 +0,0 @@ -/* - * This file is part of the coreboot project. - * - * Copyright (C) 2007-2009 coresystems GmbH - * Copyright (C) 2011 Google Inc. - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License as published by - * the Free Software Foundation; version 2 of the License. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA - */ - -#define ENABLE_TPM - -DefinitionBlock( - "dsdt.aml", - "DSDT", - 0x02, // DSDT revision: ACPI v2.0 - "COREv4", // OEM id - "COREBOOT", // OEM table id - 0x20110725 // OEM revision -) -{ - // Some generic macros - #include "acpi/platform.asl" - - // global NVS and variables - #include <southbridge/intel/lynxpoint/acpi/globalnvs.asl> - - // General Purpose Events - //#include "acpi/gpe.asl" - - #include "acpi/thermal.asl" - - #include "../../../cpu/intel/haswell/acpi/cpu.asl" - - Scope (_SB) { - Device (PCI0) - { - #include <northbridge/intel/haswell/acpi/haswell.asl> - #include <southbridge/intel/lynxpoint/acpi/pch.asl> - } - } - - #include "acpi/chromeos.asl" - #include <vendorcode/google/chromeos/acpi/chromeos.asl> - - /* Chipset specific sleep states */ - #include <southbridge/intel/lynxpoint/acpi/sleepstates.asl> -} diff --git a/src/mainboard/intel/wtm1/fadt.c b/src/mainboard/intel/wtm1/fadt.c deleted file mode 100644 index 7afbbfa..0000000 --- a/src/mainboard/intel/wtm1/fadt.c +++ /dev/null @@ -1,156 +0,0 @@ -/* - * This file is part of the coreboot project. - * - * Copyright (C) 2007-2009 coresystems GmbH - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License as published by - * the Free Software Foundation; version 2 of the License. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA - */ - -#include <string.h> -#include <device/pci.h> -#include <arch/acpi.h> -#include <cpu/x86/smm.h> -#include <southbridge/intel/lynxpoint/pch.h> - -void acpi_create_fadt(acpi_fadt_t * fadt, acpi_facs_t * facs, void *dsdt) -{ - acpi_header_t *header = &(fadt->header); - u16 pmbase = get_pmbase(); - - memset((void *) fadt, 0, sizeof(acpi_fadt_t)); - memcpy(header->signature, "FACP", 4); - header->length = sizeof(acpi_fadt_t); - header->revision = 3; - memcpy(header->oem_id, OEM_ID, 6); - memcpy(header->oem_table_id, ACPI_TABLE_CREATOR, 8); - memcpy(header->asl_compiler_id, ASLC, 4); - header->asl_compiler_revision = 1; - - fadt->firmware_ctrl = (unsigned long) facs; - fadt->dsdt = (unsigned long) dsdt; - fadt->model = 1; - fadt->preferred_pm_profile = PM_MOBILE; - - fadt->sci_int = 0x9; - fadt->smi_cmd = APM_CNT; - fadt->acpi_enable = APM_CNT_ACPI_ENABLE; - fadt->acpi_disable = APM_CNT_ACPI_DISABLE; - fadt->s4bios_req = 0x0; - fadt->pstate_cnt = 0; - - fadt->pm1a_evt_blk = pmbase; - fadt->pm1b_evt_blk = 0x0; - fadt->pm1a_cnt_blk = pmbase + 0x4; - fadt->pm1b_cnt_blk = 0x0; - fadt->pm2_cnt_blk = pmbase + 0x50; - fadt->pm_tmr_blk = pmbase + 0x8; - fadt->gpe0_blk = pmbase + 0x80; - fadt->gpe1_blk = 0; - - fadt->pm1_evt_len = 4; - fadt->pm1_cnt_len = 2; - fadt->pm2_cnt_len = 1; - fadt->pm_tmr_len = 4; - fadt->gpe0_blk_len = 32; - fadt->gpe1_blk_len = 0; - fadt->gpe1_base = 0; - fadt->cst_cnt = 0; - fadt->p_lvl2_lat = 1; - fadt->p_lvl3_lat = 87; - fadt->flush_size = 1024; - fadt->flush_stride = 16; - fadt->duty_offset = 1; - fadt->duty_width = 0; - fadt->day_alrm = 0xd; - fadt->mon_alrm = 0x00; - fadt->century = 0x00; - fadt->iapc_boot_arch = ACPI_FADT_LEGACY_DEVICES | ACPI_FADT_8042; - - fadt->flags = ACPI_FADT_WBINVD | ACPI_FADT_C1_SUPPORTED | - ACPI_FADT_C2_MP_SUPPORTED | ACPI_FADT_SLEEP_BUTTON | - ACPI_FADT_RESET_REGISTER | ACPI_FADT_SEALED_CASE | - ACPI_FADT_S4_RTC_WAKE | ACPI_FADT_PLATFORM_CLOCK; - - fadt->reset_reg.space_id = 1; - fadt->reset_reg.bit_width = 8; - fadt->reset_reg.bit_offset = 0; - fadt->reset_reg.resv = 0; - fadt->reset_reg.addrl = 0xcf9; - fadt->reset_reg.addrh = 0; - - fadt->reset_value = 6; - fadt->x_firmware_ctl_l = (unsigned long)facs; - fadt->x_firmware_ctl_h = 0; - fadt->x_dsdt_l = (unsigned long)dsdt; - fadt->x_dsdt_h = 0; - - fadt->x_pm1a_evt_blk.space_id = 1; - fadt->x_pm1a_evt_blk.bit_width = 32; - fadt->x_pm1a_evt_blk.bit_offset = 0; - fadt->x_pm1a_evt_blk.resv = 0; - fadt->x_pm1a_evt_blk.addrl = pmbase; - fadt->x_pm1a_evt_blk.addrh = 0x0; - - fadt->x_pm1b_evt_blk.space_id = 1; - fadt->x_pm1b_evt_blk.bit_width = 0; - fadt->x_pm1b_evt_blk.bit_offset = 0; - fadt->x_pm1b_evt_blk.resv = 0; - fadt->x_pm1b_evt_blk.addrl = 0x0; - fadt->x_pm1b_evt_blk.addrh = 0x0; - - fadt->x_pm1a_cnt_blk.space_id = 1; - fadt->x_pm1a_cnt_blk.bit_width = 16; - fadt->x_pm1a_cnt_blk.bit_offset = 0; - fadt->x_pm1a_cnt_blk.resv = 0; - fadt->x_pm1a_cnt_blk.addrl = pmbase + 0x4; - fadt->x_pm1a_cnt_blk.addrh = 0x0; - - fadt->x_pm1b_cnt_blk.space_id = 1; - fadt->x_pm1b_cnt_blk.bit_width = 0; - fadt->x_pm1b_cnt_blk.bit_offset = 0; - fadt->x_pm1b_cnt_blk.resv = 0; - fadt->x_pm1b_cnt_blk.addrl = 0x0; - fadt->x_pm1b_cnt_blk.addrh = 0x0; - - fadt->x_pm2_cnt_blk.space_id = 1; - fadt->x_pm2_cnt_blk.bit_width = 8; - fadt->x_pm2_cnt_blk.bit_offset = 0; - fadt->x_pm2_cnt_blk.resv = 0; - fadt->x_pm2_cnt_blk.addrl = pmbase + 0x50; - fadt->x_pm2_cnt_blk.addrh = 0x0; - - fadt->x_pm_tmr_blk.space_id = 1; - fadt->x_pm_tmr_blk.bit_width = 32; - fadt->x_pm_tmr_blk.bit_offset = 0; - fadt->x_pm_tmr_blk.resv = 0; - fadt->x_pm_tmr_blk.addrl = pmbase + 0x8; - fadt->x_pm_tmr_blk.addrh = 0x0; - - fadt->x_gpe0_blk.space_id = 0; - fadt->x_gpe0_blk.bit_width = 0; - fadt->x_gpe0_blk.bit_offset = 0; - fadt->x_gpe0_blk.resv = 0; - fadt->x_gpe0_blk.addrl = 0; - fadt->x_gpe0_blk.addrh = 0x0; - - fadt->x_gpe1_blk.space_id = 1; - fadt->x_gpe1_blk.bit_width = 0; - fadt->x_gpe1_blk.bit_offset = 0; - fadt->x_gpe1_blk.resv = 0; - fadt->x_gpe1_blk.addrl = 0x0; - fadt->x_gpe1_blk.addrh = 0x0; - - header->checksum = - acpi_checksum((void *) fadt, header->length); -} diff --git a/src/mainboard/intel/wtm1/gpio.h b/src/mainboard/intel/wtm1/gpio.h deleted file mode 100644 index 9f813d6..0000000 --- a/src/mainboard/intel/wtm1/gpio.h +++ /dev/null @@ -1,371 +0,0 @@ -/* - * This file is part of the coreboot project. - * - * Copyright (C) 2012 Google Inc. - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License as published by - * the Free Software Foundation; version 2 of the License. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA - */ - -#ifndef INTEL_WTM1_GPIO_H -#define INTEL_WTM1_GPIO_H - -#include "southbridge/intel/lynxpoint/lp_gpio.h" - -const struct pch_lp_gpio_map mainboard_gpio_map[] = { - /* UART1_RXD */ - { .gpio = 0, - .conf0 = GPIO_MODE_NATIVE }, - /* UART1_TXD */ - { .gpio = 1, - .conf0 = GPIO_MODE_NATIVE }, - /* UART1_RTSD */ - { .gpio = 2, - .conf0 = GPIO_MODE_NATIVE }, - /* UART1_CTSB */ - { .gpio = 3, - .conf0 = GPIO_MODE_NATIVE }, - /* I2C0_SDA */ - { .gpio = 4, - .conf0 = GPIO_MODE_NATIVE }, - /* I2C0_SCL */ - { .gpio = 5, - .conf0 = GPIO_MODE_NATIVE }, - /* I2C1_SDA */ - { .gpio = 6, - .conf0 = GPIO_MODE_NATIVE }, - /* I2C1_SCL */ - { .gpio = 7, - .conf0 = GPIO_MODE_NATIVE }, - /* PCIE_SLOT3_WAKE_R_N / ICC_EN_N */ - { .gpio = 8, - .conf0 = GPIO_MODE_GPIO | GPIO_DIR_INPUT, - .conf1 = GPIO_SENSE_DISABLE }, - /* PCH_GPIO9 / XDP_FN5 */ - { .gpio = 9, - .conf0 = GPIO_MODE_GPIO | GPIO_DIR_INPUT, - .conf1 = GPIO_SENSE_DISABLE }, - /* PCH_GPIO10 / XDP_FN6 */ - { .gpio = 10, - .conf0 = GPIO_MODE_GPIO | GPIO_DIR_INPUT, - .conf1 = GPIO_SENSE_DISABLE }, - /* SMBALERTB / PCH_GPIO11 / AMB_THRM_R_N */ - { .gpio = 11, - .conf0 = GPIO_MODE_NATIVE }, - /* PM_LANPHY_ENABLE */ - { .gpio = 12, - .conf0 = GPIO_MODE_NATIVE }, - /* USB30_P0_PWREN */ - { .gpio = 13, - .conf0 = GPIO_MODE_GPIO | GPIO_DIR_OUTPUT | GPO_LEVEL_HIGH, - .conf1 = GPIO_SENSE_DISABLE }, - /* SENSOR_HUB_INT_R_N */ - { .gpio = 14, - .conf0 = GPIO_MODE_GPIO | GPIO_DIR_INPUT | GPIO_IRQ_EDGE, - .conf1 = GPIO_SENSE_ENABLE, - .owner = GPIO_OWNER_GPIO, - .irqen = GPIO_IRQ_ENABLE }, - /* HOST_ALERT1_R_N */ - { .gpio = 15, - .conf0 = GPIO_MODE_GPIO | GPIO_DIR_OUTPUT | GPO_LEVEL_LOW, - .conf1 = GPIO_SENSE_DISABLE }, - /* LAN_RST_N */ - { .gpio = 16, - .conf0 = GPIO_MODE_GPIO | GPIO_DIR_OUTPUT | GPO_LEVEL_HIGH, - .conf1 = GPIO_SENSE_DISABLE }, - /* CRIT_TEMP_REP_N */ - { .gpio = 17, - .conf0 = GPIO_MODE_GPIO | GPIO_DIR_OUTPUT | GPO_LEVEL_LOW }, - /* SRC0CLKRQB */ - { .gpio = 18, - .conf0 = GPIO_MODE_NATIVE }, - /* SRC1CLKRQB */ - { .gpio = 19, - .conf0 = GPIO_MODE_NATIVE }, - /* SRC2CLKRQB */ - { .gpio = 20, - .conf0 = GPIO_MODE_NATIVE }, - /* SRC3CLKRQB */ - { .gpio = 21, - .conf0 = GPIO_MODE_NATIVE }, - /* SRC4CLKRQB_TRST2 */ - { .gpio = 22, - .conf0 = GPIO_MODE_GPIO | GPIO_DIR_OUTPUT | GPO_LEVEL_LOW, - .conf1 = GPIO_SENSE_DISABLE }, - /* SRC5CLKRQB_TDI2 */ - { .gpio = 23, - .conf0 = GPIO_MODE_NATIVE }, - /* BT_ALERT_ME_LED */ - { .gpio = 24, - .conf0 = GPIO_MODE_GPIO | GPIO_DIR_INPUT }, - /* USB_WAKEOUT_N / USB2_4_5_PWREN */ - { .gpio = 25, - .conf0 = GPIO_MODE_GPIO | GPIO_DIR_OUTPUT | GPO_LEVEL_HIGH, - .conf1 = GPIO_SENSE_DISABLE }, - /* NFC_IRQ_MGP5 */ - { .gpio = 26, - .conf0 = GPIO_MODE_GPIO | GPIO_DIR_INPUT | GPIO_IRQ_EDGE, - .conf1 = GPIO_SENSE_ENABLE, - .owner = GPIO_OWNER_GPIO, - .irqen = GPIO_IRQ_ENABLE }, - /* SMC_WAKE_SCI_N */ - { .gpio = 27, - .conf0 = GPIO_MODE_GPIO | GPIO_DIR_INPUT, - .conf1 = GPIO_SENSE_ENABLE }, - /* PCH_NFC_RESET_CMNHDR */ - { .gpio = 28, - .conf0 = GPIO_MODE_GPIO | GPIO_DIR_OUTPUT | GPO_LEVEL_LOW, - .conf1 = GPIO_SENSE_DISABLE }, - /* SLP_WLANB */ - { .gpio = 29, - .conf0 = GPIO_MODE_NATIVE }, - /* SUSWARNB_SUSPWRDNACK_MGPIO1 */ - { .gpio = 30, - .conf0 = GPIO_MODE_NATIVE }, - /* ACPRESENT_MGPIO2 */ - { .gpio = 31, - .conf0 = GPIO_MODE_NATIVE }, - /* CLKRUNB */ - { .gpio = 32, - .conf0 = GPIO_MODE_NATIVE }, - /* SATA0_PHYSLP */ - { .gpio = 33, - .conf0 = GPIO_MODE_NATIVE }, - /* SMC_EXTSMI_R_N */ - { .gpio = 34, - .conf0 = GPIO_MODE_GPIO | GPIO_DIR_INPUT }, - /* SATA_DIRECT_ODD_PRSNT_R_N */ - { .gpio = 35, - .conf0 = GPIO_MODE_GPIO | GPIO_DIR_INPUT, - .conf1 = GPIO_SENSE_DISABLE }, - /* CMNHDR_PEDET2 */ - { .gpio = 36, - .conf0 = GPIO_MODE_GPIO | GPIO_DIR_INPUT }, - /* MSATA_MPCIE_DET_N */ - { .gpio = 37, - .conf0 = GPIO_MODE_NATIVE }, - /* SATA1_PHYSLP_DIRECT */ - { .gpio = 38, - .conf0 = GPIO_MODE_NATIVE }, - /* SATA2_PHYSLP_CMNHDR */ - { .gpio = 39, - .conf0 = GPIO_MODE_NATIVE }, - /* USB_OC_0_1_R_N */ - { .gpio = 40, - .conf0 = GPIO_MODE_NATIVE }, - /* USB_OC_6_7_R_N */ - { .gpio = 41, - .conf0 = GPIO_MODE_NATIVE }, - /* USB_OC_4_5_R_N */ - { .gpio = 42, - .conf0 = GPIO_MODE_NATIVE }, - /* USB32_P1_PWREN */ - { .gpio = 43, - .conf0 = GPIO_MODE_GPIO | GPIO_DIR_OUTPUT | GPO_LEVEL_HIGH, - .conf1 = GPIO_SENSE_DISABLE }, - /* SNSR_HUB_RST_N */ - { .gpio = 44, - .conf0 = GPIO_MODE_GPIO | GPIO_DIR_OUTPUT | GPO_LEVEL_HIGH, - .conf1 = GPIO_SENSE_DISABLE }, - /* PCIE_SLOT4_WAKE_N */ - { .gpio = 45, - .conf0 = GPIO_MODE_GPIO | GPIO_DIR_INPUT }, - /* SNSR_HUB_PWREN_N */ - { .gpio = 46, - .conf0 = GPIO_MODE_GPIO | GPIO_DIR_OUTPUT | GPO_LEVEL_HIGH, - .conf1 = GPIO_SENSE_DISABLE }, - /* SPI_TPM_HDR_IRQ_N */ - { .gpio = 47, - .conf0 = GPIO_MODE_GPIO | GPIO_DIR_INPUT, - .conf1 = GPIO_SENSE_ENABLE, - .owner = GPIO_OWNER_GPIO, - .irqen = GPIO_IRQ_ENABLE }, - /* SLOT5_RST_GYRO_INT2_N */ - { .gpio = 48, - .conf0 = GPIO_MODE_GPIO | GPIO_DIR_OUTPUT | GPO_LEVEL_HIGH, - .conf1 = GPIO_SENSE_DISABLE }, - /* GPS_EN_NGFF_ALS_INT_N */ - { .gpio = 49, - .conf0 = GPIO_MODE_GPIO | GPIO_DIR_INPUT, - .conf1 = GPIO_SENSE_ENABLE, - .owner = GPIO_OWNER_GPIO, - .irqen = GPIO_IRQ_ENABLE }, - /* TOUCH_PANEL_INTR_N */ - { .gpio = 50, - .conf0 = GPIO_MODE_GPIO | GPIO_DIR_INPUT, - .conf1 = GPIO_SENSE_ENABLE, - .owner = GPIO_OWNER_GPIO, - .irqen = GPIO_IRQ_ENABLE }, - /* PCIE_SLOT5_WAKE_R_N */ - { .gpio = 51, - .conf0 = GPIO_MODE_GPIO | GPIO_DIR_INPUT }, - /* GYRO_INT1_CLV / TOUCH_RST_N */ - { .gpio = 52, - .conf0 = GPIO_MODE_GPIO | GPIO_DIR_OUTPUT | GPO_LEVEL_HIGH, - .conf1 = GPIO_SENSE_DISABLE }, - /* CODEC_IRQ */ - { .gpio = 53, - .conf0 = GPIO_MODE_GPIO | GPIO_DIR_INPUT, - .conf1 = GPIO_SENSE_ENABLE, - .owner = GPIO_OWNER_GPIO, - .irqen = GPIO_IRQ_ENABLE }, - /* PCH_MC_WAKE_R_N */ - { .gpio = 54, - .conf0 = GPIO_MODE_GPIO | GPIO_DIR_INPUT }, - /* THCP_INTR_N */ - { .gpio = 55, - .conf0 = GPIO_MODE_GPIO | GPIO_DIR_INPUT, - .conf1 = GPIO_SENSE_ENABLE, - .owner = GPIO_OWNER_GPIO, - .irqen = GPIO_IRQ_ENABLE }, - /* PCIE_SLOT4_RST_N */ - { .gpio = 56, - .conf0 = GPIO_MODE_GPIO | GPIO_DIR_OUTPUT | GPO_LEVEL_HIGH, - .conf1 = GPIO_SENSE_DISABLE }, - /* PCIE_SLOT4_PWREN_N */ - { .gpio = 57, - .conf0 = GPIO_MODE_GPIO | GPIO_DIR_OUTPUT | GPO_LEVEL_LOW, - .conf1 = GPIO_SENSE_DISABLE }, - /* SPI_TPM_HDR_PWREN_N */ - { .gpio = 58, - .conf0 = GPIO_MODE_GPIO | GPIO_DIR_INPUT, - .conf1 = GPIO_SENSE_DISABLE }, - /* PCIE_SLOT3_RST_N */ - { .gpio = 59, - .conf0 = GPIO_MODE_GPIO | GPIO_DIR_OUTPUT | GPO_LEVEL_HIGH, - .conf1 = GPIO_SENSE_DISABLE }, - /* PCIE_SLOT3_PWREN_N */ - { .gpio = 60, - .conf0 = GPIO_MODE_GPIO | GPIO_DIR_OUTPUT | GPO_LEVEL_LOW, - .conf1 = GPIO_SENSE_DISABLE }, - /* SUS_STATB */ - { .gpio = 61, - .conf0 = GPIO_MODE_NATIVE }, - /* SUSCLK */ - { .gpio = 62, - .conf0 = GPIO_MODE_NATIVE }, - /* SLP_S5B */ - { .gpio = 63, - .conf0 = GPIO_MODE_NATIVE }, - /* SDIO_CLK */ - { .gpio = 64, - .conf0 = GPIO_MODE_NATIVE }, - /* SDIO_CMD */ - { .gpio = 65, - .conf0 = GPIO_MODE_NATIVE }, - /* SDIO_D0 */ - { .gpio = 66, - .conf0 = GPIO_MODE_NATIVE }, - /* SDIO_D1 */ - { .gpio = 67, - .conf0 = GPIO_MODE_NATIVE }, - /* SDIO_D2 */ - { .gpio = 68, - .conf0 = GPIO_MODE_NATIVE }, - /* SDIO_D3 */ - { .gpio = 69, - .conf0 = GPIO_MODE_NATIVE }, - /* LPSS_SDIO_VDD_EN_CMNHDR_R */ - { .gpio = 70, - .conf0 = GPIO_MODE_NATIVE }, - /* MPHY_PWREN */ - { .gpio = 71, - .conf0 = GPIO_MODE_NATIVE }, - /* PM_BATLOW_R_N */ - { .gpio = 72, - .conf0 = GPIO_MODE_NATIVE }, - /* PCH_GP73_MGP8 / PCH_HOT_N */ - { .gpio = 73, - .conf0 = GPIO_MODE_NATIVE }, - /* SML1_DATA */ - { .gpio = 74, - .conf0 = GPIO_MODE_NATIVE }, - /* SML1_DATA */ - { .gpio = 75, - .conf0 = GPIO_MODE_NATIVE }, - /* PCH_AUDIO_PWR_N */ - { .gpio = 76, - .conf0 = GPIO_MODE_GPIO | GPIO_DIR_OUTPUT | GPO_LEVEL_HIGH, - .conf1 = GPIO_SENSE_DISABLE }, - /* MPCIE_RST_N */ - { .gpio = 77, - .conf0 = GPIO_MODE_GPIO | GPIO_DIR_OUTPUT | GPO_LEVEL_HIGH, - .conf1 = GPIO_SENSE_DISABLE }, - /* EXTTS_SNI_DRV0_PCH */ - { .gpio = 78, - .conf0 = GPIO_MODE_GPIO | GPIO_DIR_INPUT }, - /* SIO1007_IRQ_N */ - { .gpio = 79, - .conf0 = GPIO_MODE_GPIO | GPIO_DIR_INPUT | GPIO_IRQ_EDGE, - .conf1 = GPIO_SENSE_ENABLE, - .owner = GPIO_OWNER_ACPI, - .route = GPIO_ROUTE_SCI, - .irqen = GPIO_IRQ_ENABLE }, - /* EXTTS_SNI_DRV1_PCH */ - { .gpio = 80, - .conf0 = GPIO_MODE_GPIO | GPIO_DIR_INPUT }, - /* SPKR */ - { .gpio = 81, - .conf0 = GPIO_MODE_NATIVE }, - /* RCINB */ - { .gpio = 82, - .conf0 = GPIO_MODE_NATIVE }, - /* MC_3.3_PWREN_N */ - { .gpio = 83, - .conf0 = GPIO_MODE_GPIO | GPIO_DIR_OUTPUT | GPO_LEVEL_LOW, - .conf1 = GPIO_SENSE_DISABLE }, - /* PCIE_SLOT5_PWREN_N */ - { .gpio = 84, - .conf0 = GPIO_MODE_GPIO | GPIO_DIR_OUTPUT | GPO_LEVEL_LOW, - .conf1 = GPIO_SENSE_DISABLE }, - /* MC_1.5_PWREN_N */ - { .gpio = 85, - .conf0 = GPIO_MODE_GPIO | GPIO_DIR_OUTPUT | GPO_LEVEL_LOW, - .conf1 = GPIO_SENSE_DISABLE }, - /* SATA_ODD_PWRGT_R */ - { .gpio = 86, - .conf0 = GPIO_MODE_GPIO | GPIO_DIR_OUTPUT | GPO_LEVEL_LOW, - .conf1 = GPIO_SENSE_DISABLE }, - /* PECI_HDR / PCH_RF_KILL_N */ - { .gpio = 87, - .conf0 = GPIO_MODE_GPIO | GPIO_DIR_OUTPUT | GPO_LEVEL_HIGH, - .conf1 = GPIO_SENSE_DISABLE }, - /* TCHP_PWREN_N */ - { .gpio = 88, - .conf0 = GPIO_MODE_GPIO | GPIO_DIR_OUTPUT | GPO_LEVEL_HIGH, - .conf1 = GPIO_SENSE_DISABLE }, - /* TOUCH_PWREN_N */ - { .gpio = 89, - .conf0 = GPIO_MODE_GPIO | GPIO_DIR_OUTPUT | GPO_LEVEL_LOW, - .conf1 = GPIO_SENSE_DISABLE }, - /* SATA1_PWR_EN_N */ - { .gpio = 90, - .conf0 = GPIO_MODE_GPIO | GPIO_DIR_OUTPUT | GPO_LEVEL_LOW, - .conf1 = GPIO_SENSE_DISABLE }, - /* UART0_RXD */ - { .gpio = 91, - .conf0 = GPIO_MODE_NATIVE }, - /* UART0_TXD */ - { .gpio = 92, - .conf0 = GPIO_MODE_NATIVE }, - /* UART0_RTSB */ - { .gpio = 93, - .conf0 = GPIO_MODE_NATIVE }, - /* UART0_CTSB */ - { .gpio = 94, - .conf0 = GPIO_MODE_NATIVE }, - /* END */ - { .gpio = GPIO_LIST_END } -}; - -#endif diff --git a/src/mainboard/intel/wtm1/hda_verb.h b/src/mainboard/intel/wtm1/hda_verb.h deleted file mode 100644 index c34d0f5..0000000 --- a/src/mainboard/intel/wtm1/hda_verb.h +++ /dev/null @@ -1,99 +0,0 @@ -/* - * This file is part of the coreboot project. - * - * Copyright (C) 2011 Google Inc. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; version 2 of the License. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA - */ - -static const u32 mainboard_cim_verb_data[] = { - /* coreboot specific header */ - 0x10134210, // Codec Vendor / Device ID: Cirrus Logic CS4210 - 0x10134210, // Subsystem ID - 0x00000007, // Number of jacks - - /* NID 0x01, HDA Codec Subsystem ID Verb Table: 0x10134210 */ - 0x00172010, - 0x00172142, - 0x00172213, - 0x00172310, - - /* Pin Widget Verb Table */ - - /* Pin Complex (NID 0x05) 1/8 Gray HP Out at Ext Front */ - 0x00571cf0, - 0x00571d20, - 0x00571e21, - 0x00571f02, - - /* Pin Complex (NID 0x06) Analog Unknown Speaker at Int N/A */ - 0x00671c10, - 0x00671d00, - 0x00671e17, - 0x00671f90, - - /* Pin Complex (NID 0x07) 1/8 Grey Line In at Ext Front */ - 0x00771cf0, - 0x00771d20, - 0x00771ea1, - 0x00771f02, - - /* Pin Complex (NID 0x08) Analog Unknown Mic at Oth Mobile-In */ - 0x00871c37, - 0x00871d00, - 0x00871ea7, - 0x00871f77, - - /* Pin Complex (NID 0x09) Digital Unknown Mic at Oth Mobile-In */ - 0x00971c3e, - 0x00971d00, - 0x00971ea6, - 0x00971f77, - - /* Pin Complex (NID 0x0a) Optical Black SPDIF Out at Ext N/A */ - 0x00a71cf0, - 0x00a71d10, - 0x00a71e45, - 0x00a71f43, - - /* coreboot specific header */ - 0x80862805, // Codec Vendor / Device ID: Intel CougarPoint HDMI - 0x80860101, // Subsystem ID - 0x00000004, // Number of jacks - - /* NID 0x01, HDA Codec Subsystem ID Verb Table: 0x80860101 */ - 0x00172001, - 0x00172101, - 0x00172286, - 0x00172380, - - /* Pin Complex (NID 0x05) Digital Out at Int HDMI */ - 0x30571c10, - 0x30571d00, - 0x30571e56, - 0x30571f18, - - /* Pin Complex (NID 0x06) Digital Out at Int HDMI */ - 0x30671c20, - 0x30671d00, - 0x30671e56, - 0x30671f18, - - /* Pin Complex (NID 0x07) Digital Out at Int HDMI */ - 0x30771c30, - 0x30771d00, - 0x30771e56, - 0x30771f18 -}; - diff --git a/src/mainboard/intel/wtm1/mainboard.c b/src/mainboard/intel/wtm1/mainboard.c deleted file mode 100644 index f5b0054..0000000 --- a/src/mainboard/intel/wtm1/mainboard.c +++ /dev/null @@ -1,243 +0,0 @@ -/* - * This file is part of the coreboot project. - * - * Copyright (C) 2007-2009 coresystems GmbH - * Copyright (C) 2011 Google Inc. - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License as published by - * the Free Software Foundation; version 2 of the License. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA - */ - -#include <types.h> -#include <string.h> -#include <device/device.h> -#include <device/device.h> -#include <device/pci_def.h> -#include <device/pci_ops.h> -#include <console/console.h> -#if defined(CONFIG_PCI_OPTION_ROM_RUN_YABEL) && CONFIG_PCI_OPTION_ROM_RUN_YABEL -#include <x86emu/x86emu.h> -#endif -#include <pc80/mc146818rtc.h> -#include <arch/acpi.h> -#include <arch/io.h> -#include <arch/interrupt.h> -#include <boot/coreboot_tables.h> -#include "hda_verb.h" -#include <southbridge/intel/lynxpoint/pch.h> - -void mainboard_suspend_resume(void) -{ - /* Call SMM finalize() handlers before resume */ - outb(0xcb, 0xb2); -} - -#if defined(CONFIG_PCI_OPTION_ROM_RUN_REALMODE) && CONFIG_PCI_OPTION_ROM_RUN_REALMODE -static int int15_handler(struct eregs *regs) -{ - int res=-1; - - printk(BIOS_DEBUG, "%s: INT15 function %04x!\n", - __func__, regs->eax & 0xffff); - - switch(regs->eax & 0xffff) { - case 0x5f34: - /* - * Set Panel Fitting Hook: - * bit 2 = Graphics Stretching - * bit 1 = Text Stretching - * bit 0 = Centering (do not set with bit1 or bit2) - * 0 = video bios default - */ - regs->eax &= 0xffff0000; - regs->eax |= 0x005f; - regs->ecx &= 0xffffff00; - regs->ecx |= 0x01; - res = 0; - break; - case 0x5f35: - /* - * Boot Display Device Hook: - * bit 0 = CRT - * bit 1 = TV (eDP) * - * bit 2 = EFP * - * bit 3 = LFP - * bit 4 = CRT2 - * bit 5 = TV2 (eDP) * - * bit 6 = EFP2 * - * bit 7 = LFP2 - */ - regs->eax &= 0xffff0000; - regs->eax |= 0x005f; - regs->ecx &= 0xffff0000; - regs->ecx |= 0x0000; - res = 0; - break; - case 0x5f51: - /* - * Hook to select active LFP configuration: - * 00h = No LVDS, VBIOS does not enable LVDS - * 01h = Int-LVDS, LFP driven by integrated LVDS decoder - * 02h = SVDO-LVDS, LFP driven by SVDO decoder - * 03h = eDP, LFP Driven by Int-DisplayPort encoder - */ - regs->eax &= 0xffff0000; - regs->eax |= 0x005f; - regs->ecx &= 0xffff0000; - regs->ecx |= 0x0003; - res = 0; - break; - case 0x5f70: - switch ((regs->ecx >> 8) & 0xff) { - case 0: - /* Get Mux */ - regs->eax &= 0xffff0000; - regs->eax |= 0x005f; - regs->ecx &= 0xffff0000; - regs->ecx |= 0x0000; - res = 0; - break; - case 1: - /* Set Mux */ - regs->eax &= 0xffff0000; - regs->eax |= 0x005f; - regs->ecx &= 0xffff0000; - regs->ecx |= 0x0000; - res = 0; - break; - case 2: - /* Get SG/Non-SG mode */ - regs->eax &= 0xffff0000; - regs->eax |= 0x005f; - regs->ecx &= 0xffff0000; - regs->ecx |= 0x0000; - res = 0; - break; - default: - /* Interrupt was not handled */ - printk(BIOS_DEBUG, "Unknown INT15 5f70 function: 0x%02x\n", - ((regs->ecx >> 8) & 0xff)); - return 0; - } - break; - - default: - printk(BIOS_DEBUG, "Unknown INT15 function %04x!\n", - regs->eax & 0xffff); - break; - } - return res; -} -#endif - -#if defined(CONFIG_PCI_OPTION_ROM_RUN_YABEL) && CONFIG_PCI_OPTION_ROM_RUN_YABEL -static int int15_handler(void) -{ - printk(BIOS_DEBUG, "%s: AX=%04x BX=%04x CX=%04x DX=%04x\n", - __func__, M.x86.R_AX, M.x86.R_BX, M.x86.R_CX, M.x86.R_DX); - - switch (M.x86.R_AX) { - case 0x5f34: - /* - * Set Panel Fitting Hook: - * bit 2 = Graphics Stretching - * bit 1 = Text Stretching - * bit 0 = Centering (do not set with bit1 or bit2) - */ - M.x86.R_AX = 0x005f; - M.x86.R_CX = 0x0001; - break; - case 0x5f35: - /* - * Boot Display Device Hook: - * bit 0 = CRT - * bit 1 = TV (eDP) * - * bit 2 = EFP * - * bit 3 = LFP - * bit 4 = CRT2 - * bit 5 = TV2 (eDP) * - * bit 6 = EFP2 * - * bit 7 = LFP2 - */ - M.x86.R_AX = 0x005f; - M.x86.R_CX = 0x0000; - break; - case 0x5f51: - /* - * Hook to select active LFP configuration: - * 00h = No LVDS, VBIOS does not enable LVDS - * 01h = Int-LVDS, LFP driven by integrated LVDS decoder - * 02h = SVDO-LVDS, LFP driven by SVDO decoder - * 03h = eDP, LFP Driven by Int-DisplayPort encoder - */ - M.x86.R_AX = 0x005f; - M.x86.R_CX = 3; - break; - case 0x5f70: - /* Unknown */ - M.x86.R_AX = 0x005f; - M.x86.R_CX = 0; - break; - default: - /* Interrupt was not handled */ - printk(BIOS_DEBUG, "Unknown INT15 function: 0x%04x\n", - M.x86.R_AX); - return 0; - } - - /* Interrupt handled */ - return 1; -} -#endif - -#if CONFIG_PCI_OPTION_ROM_RUN_YABEL || CONFIG_PCI_OPTION_ROM_RUN_REALMODE -static void int15_install(void) -{ -#if CONFIG_PCI_OPTION_ROM_RUN_YABEL - typedef int (* yabel_handleIntFunc)(void); - extern yabel_handleIntFunc yabel_intFuncArray[256]; - yabel_intFuncArray[0x15] = int15_handler; -#endif -#ifdef CONFIG_PCI_OPTION_ROM_RUN_REALMODE - mainboard_interrupt_handlers(0x15, &int15_handler); -#endif -} -#endif - -/* Audio Setup */ - -extern const u32 * cim_verb_data; -extern u32 cim_verb_data_size; - -static void verb_setup(void) -{ - cim_verb_data = mainboard_cim_verb_data; - cim_verb_data_size = sizeof(mainboard_cim_verb_data); -} - -// mainboard_enable is executed as first thing after -// enumerate_buses(). - -static void mainboard_enable(device_t dev) -{ -#if CONFIG_PCI_OPTION_ROM_RUN_YABEL || CONFIG_PCI_OPTION_ROM_RUN_REALMODE - /* Install custom int15 handler for VGA OPROM */ - int15_install(); -#endif - verb_setup(); -} - -struct chip_operations mainboard_ops = { - .enable_dev = mainboard_enable, -}; - diff --git a/src/mainboard/intel/wtm1/mainboard_smi.c b/src/mainboard/intel/wtm1/mainboard_smi.c deleted file mode 100644 index 3ffc684..0000000 --- a/src/mainboard/intel/wtm1/mainboard_smi.c +++ /dev/null @@ -1,72 +0,0 @@ -/* - * This file is part of the coreboot project. - * - * Copyright (C) 2008-2009 coresystems GmbH - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License as published by - * the Free Software Foundation; version 2 of the License. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA - */ - -#include <arch/io.h> -#include <console/console.h> -#include <cpu/x86/smm.h> -#include <southbridge/intel/lynxpoint/nvs.h> -#include <southbridge/intel/lynxpoint/pch.h> -#include <southbridge/intel/lynxpoint/me.h> -#include <northbridge/intel/haswell/haswell.h> -#include <cpu/intel/haswell/haswell.h> - -int mainboard_io_trap_handler(int smif) -{ - switch (smif) { - case 0x99: - printk(BIOS_DEBUG, "Sample\n"); - smm_get_gnvs()->smif = 0; - break; - default: - return 0; - } - - /* On success, the IO Trap Handler returns 0 - * On failure, the IO Trap Handler returns a value != 0 - * - * For now, we force the return value to 0 and log all traps to - * see what's going on. - */ - //gnvs->smif = 0; - return 1; -} - -#define APMC_FINALIZE 0xcb - -static int mainboard_finalized = 0; - -int mainboard_smi_apmc(u8 apmc) -{ - switch (apmc) { - case APMC_FINALIZE: - if (mainboard_finalized) { - printk(BIOS_DEBUG, "SMI#: Already finalized\n"); - return 0; - } - - intel_me_finalize_smm(); - intel_pch_finalize_smm(); - intel_northbridge_haswell_finalize_smm(); - intel_cpu_haswell_finalize_smm(); - - mainboard_finalized = 1; - break; - } - return 0; -} diff --git a/src/mainboard/intel/wtm1/romstage.c b/src/mainboard/intel/wtm1/romstage.c deleted file mode 100644 index 525bd6f..0000000 --- a/src/mainboard/intel/wtm1/romstage.c +++ /dev/null @@ -1,128 +0,0 @@ -/* - * This file is part of the coreboot project. - * - * Copyright (C) 2007-2010 coresystems GmbH - * Copyright (C) 2011 Google Inc. - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License as published by - * the Free Software Foundation; version 2 of the License. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA - */ - -#include <stdint.h> -#include <console/console.h> -#include "cpu/intel/haswell/haswell.h" -#include "northbridge/intel/haswell/haswell.h" -#include "northbridge/intel/haswell/raminit.h" -#include "southbridge/intel/lynxpoint/pch.h" -#include "southbridge/intel/lynxpoint/lp_gpio.h" -#include "gpio.h" - -const struct rcba_config_instruction rcba_config[] = { - - /* - * GFX INTA -> PIRQA (MSI) - * D28IP_P1IP WLAN INTA -> PIRQB - * D28IP_P4IP ETH0 INTB -> PIRQC - * D29IP_E1P EHCI1 INTA -> PIRQD - * D20IP_XHCI XHCI INTA -> PIRQA - * D31IP_SIP SATA INTA -> PIRQF (MSI) - * D31IP_SMIP SMBUS INTB -> PIRQG - * D31IP_TTIP THRT INTC -> PIRQH - * D27IP_ZIP HDA INTA -> PIRQG (MSI) - */ - - /* Device interrupt pin register (board specific) */ - RCBA_SET_REG_32(D31IP, (INTC << D31IP_TTIP) | (NOINT << D31IP_SIP2) | - (INTB << D31IP_SMIP) | (INTA << D31IP_SIP)), - RCBA_SET_REG_32(D29IP, (INTA << D29IP_E1P)), - RCBA_SET_REG_32(D28IP, (INTA << D28IP_P1IP) | (INTC << D28IP_P3IP) | - (INTB << D28IP_P4IP)), - RCBA_SET_REG_32(D27IP, (INTA << D27IP_ZIP)), - RCBA_SET_REG_32(D26IP, (INTA << D26IP_E2P)), - RCBA_SET_REG_32(D25IP, (NOINT << D25IP_LIP)), - RCBA_SET_REG_32(D22IP, (NOINT << D22IP_MEI1IP)), - RCBA_SET_REG_32(D20IR, (INTA << D20IP_XHCI)), - - /* Device interrupt route registers */ - RCBA_SET_REG_32(D31IR, DIR_ROUTE(PIRQF, PIRQG, PIRQH, PIRQA)), - RCBA_SET_REG_32(D29IR, DIR_ROUTE(PIRQD, PIRQE, PIRQF, PIRQG)), - RCBA_SET_REG_32(D28IR, DIR_ROUTE(PIRQB, PIRQC, PIRQD, PIRQE)), - RCBA_SET_REG_32(D27IR, DIR_ROUTE(PIRQG, PIRQH, PIRQA, PIRQB)), - RCBA_SET_REG_32(D26IR, DIR_ROUTE(PIRQE, PIRQF, PIRQG, PIRQH)), - RCBA_SET_REG_32(D25IR, DIR_ROUTE(PIRQA, PIRQB, PIRQC, PIRQD)), - RCBA_SET_REG_32(D22IR, DIR_ROUTE(PIRQA, PIRQB, PIRQC, PIRQD)), - RCBA_SET_REG_32(D21IR, DIR_ROUTE(PIRQA, PIRQB, PIRQC, PIRQD)), - RCBA_SET_REG_32(D20IR, DIR_ROUTE(PIRQA, PIRQB, PIRQC, PIRQD)), - RCBA_SET_REG_32(D23IR, DIR_ROUTE(PIRQA, 0, 0, 0)), - - /* Disable unused devices (board specific) */ - RCBA_RMW_REG_32(FD, ~0, PCH_DISABLE_ALWAYS), - - RCBA_END_CONFIG, -}; - -void mainboard_romstage_entry(unsigned long bist) -{ - struct pei_data pei_data = { - pei_version: PEI_VERSION, - mchbar: DEFAULT_MCHBAR, - dmibar: DEFAULT_DMIBAR, - epbar: DEFAULT_EPBAR, - pciexbar: DEFAULT_PCIEXBAR, - smbusbar: SMBUS_IO_BASE, - wdbbar: 0x4000000, - wdbsize: 0x1000, - hpet_address: HPET_ADDR, - rcba: DEFAULT_RCBA, - pmbase: DEFAULT_PMBASE, - gpiobase: DEFAULT_GPIOBASE, - temp_mmio_base: 0xfed08000, - system_type: 5, /* ULT */ - tseg_size: CONFIG_SMM_TSEG_SIZE, - spd_addresses: { 0xa0, 0xa2, 0xa4, 0xa6 }, - ec_present: 1, - // 0 = leave channel enabled - // 1 = disable dimm 0 on channel - // 2 = disable dimm 1 on channel - // 3 = disable dimm 0+1 on channel - dimm_channel0_disabled: 2, - dimm_channel1_disabled: 2, - max_ddr3_freq: 1600, - usb_port_config: { - { 1, 0, 0x0040 }, /* P0: */ - { 1, 0, 0x0040 }, /* P1: */ - { 1, 0, 0x0040 }, /* P2: */ - { 1, 0, 0x0040 }, /* P3: */ - { 1, 0, 0x0040 }, /* P4: */ - { 1, 0, 0x0040 }, /* P5: */ - { 1, 0, 0x0040 }, /* P6: */ - { 1, 0, 0x0040 }, /* P7: */ - { 1, 0, 0x0040 }, /* P8: */ - { 1, 0, 0x0040 }, /* P9: */ - { 1, 0, 0x0040 }, /* P10: */ - { 1, 0, 0x0000 }, /* P11: */ - { 1, 0, 0x0040 }, /* P12: */ - { 1, 0, 0x0040 }, /* P13: */ - }, - }; - - struct romstage_params romstage_params = { - .pei_data = &pei_data, - .gpio_map = &mainboard_gpio_map, - .rcba_config = &rcba_config[0], - .bist = bist, - }; - - /* Call into the real romstage main with this board's attributes. */ - romstage_common(&romstage_params); -} diff --git a/src/mainboard/intel/wtm1/thermal.h b/src/mainboard/intel/wtm1/thermal.h deleted file mode 100644 index e6116b6..0000000 --- a/src/mainboard/intel/wtm1/thermal.h +++ /dev/null @@ -1,57 +0,0 @@ -/* - * This file is part of the coreboot project. - * - * Copyright (C) 2011 Google Inc. - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License as published by - * the Free Software Foundation; version 2 of the License. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA - */ - -#ifndef WTM2_THERMAL_H -#define WTM2_THERMAL_H - -/* Fan is OFF */ -#define FAN4_THRESHOLD_OFF 0 -#define FAN4_THRESHOLD_ON 0 -#define FAN4_PWM 0x00 - -/* Fan is at LOW speed */ -#define FAN3_THRESHOLD_OFF 48 -#define FAN3_THRESHOLD_ON 55 -#define FAN3_PWM 0x40 - -/* Fan is at MEDIUM speed */ -#define FAN2_THRESHOLD_OFF 52 -#define FAN2_THRESHOLD_ON 64 -#define FAN2_PWM 0x80 - -/* Fan is at HIGH speed */ -#define FAN1_THRESHOLD_OFF 60 -#define FAN1_THRESHOLD_ON 68 -#define FAN1_PWM 0xb0 - -/* Fan is at FULL speed */ -#define FAN0_THRESHOLD_OFF 66 -#define FAN0_THRESHOLD_ON 78 -#define FAN0_PWM 0xff - -/* Temperature which OS will shutdown at */ -#define CRITICAL_TEMPERATURE 100 - -/* Temperature which OS will throttle CPU */ -#define PASSIVE_TEMPERATURE 90 - -/* Tj_max value for calculating PECI CPU temperature */ -#define MAX_TEMPERATURE 100 - -#endif
