Patrick Georgi has submitted this change. ( https://review.coreboot.org/c/coreboot/+/51051 )
Change subject: drivers/generic/alc1015: add ALC1015 AMP driver ......................................................................
Add ALC1015 AMP support. ALC1015Q-VB Datasheet Rev 0.1
BUG=b:177971830 TEST: ALC1015P driver can probe properly.
Signed-off-by: Eric Lai ericr_lai@compal.corp-partner.google.com Change-Id: Id93845024aa2cded69acc88d594c222f2f821f79 Reviewed-on: https://review.coreboot.org/c/coreboot/+/51051 Reviewed-by: Furquan Shaikh furquan@google.com Tested-by: build bot (Jenkins) no-reply@coreboot.org --- A src/drivers/generic/alc1015/Kconfig A src/drivers/generic/alc1015/Makefile.inc A src/drivers/generic/alc1015/alc1015.c A src/drivers/generic/alc1015/chip.h 4 files changed, 83 insertions(+), 0 deletions(-)
diff --git a/src/drivers/generic/alc1015/Kconfig b/src/drivers/generic/alc1015/Kconfig new file mode 100644 index 0000000..4b1e25d --- /dev/null +++ b/src/drivers/generic/alc1015/Kconfig @@ -0,0 +1,3 @@ +config DRIVERS_GENERIC_ALC1015 + bool + depends on HAVE_ACPI_TABLES diff --git a/src/drivers/generic/alc1015/Makefile.inc b/src/drivers/generic/alc1015/Makefile.inc new file mode 100644 index 0000000..5f81586 --- /dev/null +++ b/src/drivers/generic/alc1015/Makefile.inc @@ -0,0 +1 @@ +ramstage-$(CONFIG_DRIVERS_GENERIC_ALC1015) += alc1015.c diff --git a/src/drivers/generic/alc1015/alc1015.c b/src/drivers/generic/alc1015/alc1015.c new file mode 100644 index 0000000..afb9b11 --- /dev/null +++ b/src/drivers/generic/alc1015/alc1015.c @@ -0,0 +1,71 @@ +/* SPDX-License-Identifier: GPL-2.0-only */ + +#include <acpi/acpi_device.h> +#include <acpi/acpigen.h> +#include <console/console.h> +#include <device/device.h> +#include <device/path.h> +#include "chip.h" + +static void alc1015_fill_ssdt(const struct device *dev) +{ + struct drivers_generic_alc1015_config *config = dev->chip_info; + const char *path; + struct acpi_dp *dp; + + if (!config) + return; + + const char *scope = acpi_device_scope(dev); + const char *name = acpi_device_name(dev); + if (!scope || !name) + return; + + /* Device */ + acpigen_write_scope(scope); + acpigen_write_device(name); + + acpigen_write_name_string("_HID", "ALCP1015"); + acpigen_write_name_integer("_UID", 0); + acpigen_write_name_string("_DDN", dev->chip_ops->name); + acpigen_write_STA(acpi_device_status(dev)); + + /* Resources */ + acpigen_write_name("_CRS"); + acpigen_write_resourcetemplate_header(); + acpi_device_write_gpio(&config->sdb); + acpigen_write_resourcetemplate_footer(); + + /* _DSD for devicetree properties */ + /* This points to the first pin in the first gpio entry in _CRS */ + path = acpi_device_path(dev); + dp = acpi_dp_new_table("_DSD"); + acpi_dp_add_gpio(dp, "sdb", path, 0, 0, config->sdb.active_low); + + acpigen_pop_len(); /* Device */ + acpigen_pop_len(); /* Scope */ + + printk(BIOS_INFO, "%s: %s\n", path, dev->chip_ops->name); +} + +static const char *alc1015_acpi_name(const struct device *dev) +{ + return "ALCP"; +} + +static struct device_operations alc1015_ops = { + .read_resources = noop_read_resources, + .set_resources = noop_set_resources, + .acpi_name = alc1015_acpi_name, + .acpi_fill_ssdt = alc1015_fill_ssdt, +}; + +static void alc1015_enable(struct device *dev) +{ + dev->ops = &alc1015_ops; +} + +struct chip_operations drivers_generic_alc1015_ops = { + CHIP_NAME("ASoC RT1015P Amplifier driver") + .enable_dev = alc1015_enable +}; diff --git a/src/drivers/generic/alc1015/chip.h b/src/drivers/generic/alc1015/chip.h new file mode 100644 index 0000000..4c01e7c --- /dev/null +++ b/src/drivers/generic/alc1015/chip.h @@ -0,0 +1,8 @@ +/* SPDX-License-Identifier: GPL-2.0-only */ + +#include <acpi/acpi_device.h> + +struct drivers_generic_alc1015_config { + /* SDMODE GPIO */ + struct acpi_gpio sdb; +};
