Aaron Durbin (adurbin@google.com) just uploaded a new patch set to gerrit, which you can find at http://review.coreboot.org/8848
commit 84b0a5dd9e1615d687737529237ad3215e2afa92 Author: Aaron Durbin adurbin@chromium.org Date: Fri Mar 20 16:47:21 2015 -0500
tegra132: implement platform_prog_run()
The tegra132 SoC is currently booting up on the AVP cpu which bootstraps the rest of the SoC. Upon exiting romstage it runs ramstage from its faster armv8 core. Instead of hard coding the stage loading operations use run_ramstage().
Change-Id: Ib9b3eecf376ae022f910295920a085bde6e17f9f Signed-off-by: Aaron Durbin adurbin@chromium.org --- src/soc/nvidia/tegra132/romstage.c | 37 +++++++------------------------------ 1 file changed, 7 insertions(+), 30 deletions(-)
diff --git a/src/soc/nvidia/tegra132/romstage.c b/src/soc/nvidia/tegra132/romstage.c index 9051a81..94fd845 100644 --- a/src/soc/nvidia/tegra132/romstage.c +++ b/src/soc/nvidia/tegra132/romstage.c @@ -24,6 +24,7 @@ #include <console/console.h> #include <timer.h> #include <arch/exception.h> +#include <program_loading.h>
#include <soc/addressmap.h> #include <soc/sdram_configs.h> @@ -38,30 +39,8 @@ void __attribute__((weak)) romstage_mainboard_init(void) /* Default empty implementation. */ }
-static void *load_ramstage(void) -{ - void *entry; - struct stopwatch sw; - - stopwatch_init(&sw); - /* - * This platform does not need to cache a loaded ramstage nor do we - * go down this path on resume. Therefore, no romstage_handoff is - * required. - */ - entry = cbfs_load_stage(CBFS_DEFAULT_MEDIA, - CONFIG_CBFS_PREFIX "/ramstage"); - - printk(BIOS_DEBUG, "Ramstage load time: %ld usecs.\n", - stopwatch_duration_usecs(&sw)); - - return entry; -} - void romstage(void) { - void *entry; - console_init(); exception_init();
@@ -99,16 +78,14 @@ void romstage(void)
romstage_mainboard_init();
- entry = load_ramstage(); - - if (entry == NULL) { - printk(BIOS_INFO, "T132 romstage: error loading ramstage\n"); - clock_halt_avp(); - } - cbmemc_reinit();
- ccplex_cpu_start(entry); + run_ramstage(); +} + +void platform_prog_run(struct prog *prog) +{ + ccplex_cpu_start(prog_entry(prog));
clock_halt_avp(); }
