Patrick Georgi has submitted this change and it was merged. ( https://review.coreboot.org/c/coreboot/+/31986 )
Change subject: sb/intel/lynxpoint: Remove PCI bridge function ......................................................................
Legacy PCI-to-PCI (parallel) bridge 0:1e.0 is no longer supported in these SKUs.
Change-Id: I954ee9cf8228c6352743cae968a0dd665865496c Signed-off-by: Kyösti Mälkki kyosti.malkki@gmail.com Reviewed-on: https://review.coreboot.org/c/coreboot/+/31986 Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: Subrata Banik subrata.banik@intel.com --- M src/southbridge/intel/lynxpoint/Makefile.inc D src/southbridge/intel/lynxpoint/pci.c 2 files changed, 0 insertions(+), 138 deletions(-)
Approvals: build bot (Jenkins): Verified Subrata Banik: Looks good to me, approved
diff --git a/src/southbridge/intel/lynxpoint/Makefile.inc b/src/southbridge/intel/lynxpoint/Makefile.inc index c2a49fd..b18e6da 100644 --- a/src/southbridge/intel/lynxpoint/Makefile.inc +++ b/src/southbridge/intel/lynxpoint/Makefile.inc @@ -18,7 +18,6 @@ ramstage-y += pch.c ramstage-y += azalia.c ramstage-y += lpc.c -ramstage-y += pci.c ramstage-y += pcie.c ramstage-y += sata.c ramstage-y += usb_ehci.c diff --git a/src/southbridge/intel/lynxpoint/pci.c b/src/southbridge/intel/lynxpoint/pci.c deleted file mode 100644 index 6c26bb8..0000000 --- a/src/southbridge/intel/lynxpoint/pci.c +++ /dev/null @@ -1,137 +0,0 @@ -/* - * This file is part of the coreboot project. - * - * Copyright (C) 2008-2009 coresystems GmbH - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; version 2 of - * the License. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - */ - -#include <console/console.h> -#include <device/device.h> -#include <device/pci.h> -#include <device/pci_ops.h> -#include <device/pci_ids.h> -#include "pch.h" - -static void pci_init(struct device *dev) -{ - u16 reg16; - u8 reg8; - - printk(BIOS_DEBUG, "PCI init.\n"); - /* Enable Bus Master */ - reg16 = pci_read_config16(dev, PCI_COMMAND); - reg16 |= PCI_COMMAND_MASTER; - pci_write_config16(dev, PCI_COMMAND, reg16); - - /* This device has no interrupt */ - pci_write_config8(dev, INTR, 0xff); - - /* disable parity error response and SERR */ - reg16 = pci_read_config16(dev, BCTRL); - reg16 &= ~(1 << 0); - reg16 &= ~(1 << 1); - pci_write_config16(dev, BCTRL, reg16); - - /* Master Latency Count must be set to 0x04! */ - reg8 = pci_read_config8(dev, SMLT); - reg8 &= 0x07; - reg8 |= (0x04 << 3); - pci_write_config8(dev, SMLT, reg8); - - /* Will this improve throughput of bus masters? */ - pci_write_config8(dev, PCI_MIN_GNT, 0x06); - - /* Clear errors in status registers */ - reg16 = pci_read_config16(dev, PSTS); - //reg16 |= 0xf900; - pci_write_config16(dev, PSTS, reg16); - - reg16 = pci_read_config16(dev, SECSTS); - // reg16 |= 0xf900; - pci_write_config16(dev, SECSTS, reg16); -} - -static void ich_pci_dev_enable_resources(struct device *dev) -{ - const struct pci_operations *ops; - uint16_t command; - - /* Set the subsystem vendor and device id for mainboard devices */ - ops = ops_pci(dev); - if (dev->on_mainboard && ops && ops->set_subsystem) { - printk(BIOS_DEBUG, "%s subsystem <- %02x/%02x\n", - dev_path(dev), - CONFIG_MAINBOARD_PCI_SUBSYSTEM_VENDOR_ID, - CONFIG_MAINBOARD_PCI_SUBSYSTEM_DEVICE_ID); - ops->set_subsystem(dev, - CONFIG_MAINBOARD_PCI_SUBSYSTEM_VENDOR_ID, - CONFIG_MAINBOARD_PCI_SUBSYSTEM_DEVICE_ID); - } - - command = pci_read_config16(dev, PCI_COMMAND); - command |= dev->command; - /* If we write to PCI_COMMAND, on some systems - * this will cause the ROM and APICs not being visible - * anymore. - */ - printk(BIOS_DEBUG, "%s cmd <- %02x\n", dev_path(dev), command); - pci_write_config16(dev, PCI_COMMAND, command); -} - -static void ich_pci_bus_enable_resources(struct device *dev) -{ - uint16_t ctrl; - /* enable IO in command register if there is VGA card - * connected with (even it does not claim IO resource) - */ - if (dev->link_list->bridge_ctrl & PCI_BRIDGE_CTL_VGA) - dev->command |= PCI_COMMAND_IO; - ctrl = pci_read_config16(dev, PCI_BRIDGE_CONTROL); - ctrl |= dev->link_list->bridge_ctrl; - ctrl |= (PCI_BRIDGE_CTL_PARITY + PCI_BRIDGE_CTL_SERR); /* error check */ - printk(BIOS_DEBUG, "%s bridge ctrl <- %04x\n", dev_path(dev), ctrl); - pci_write_config16(dev, PCI_BRIDGE_CONTROL, ctrl); - - /* This is the reason we need our own pci_bus_enable_resources */ - ich_pci_dev_enable_resources(dev); -} - -static void set_subsystem(struct device *dev, unsigned vendor, unsigned device) -{ - /* NOTE: This is not the default position! */ - if (!vendor || !device) { - pci_write_config32(dev, 0x54, - pci_read_config32(dev, PCI_VENDOR_ID)); - } else { - pci_write_config32(dev, 0x54, - ((device & 0xffff) << 16) | (vendor & 0xffff)); - } -} - -static struct pci_operations pci_ops = { - .set_subsystem = set_subsystem, -}; - -static struct device_operations device_ops = { - .read_resources = pci_bus_read_resources, - .set_resources = pci_dev_set_resources, - .enable_resources = ich_pci_bus_enable_resources, - .init = pci_init, - .scan_bus = pci_scan_bridge, - .ops_pci = &pci_ops, -}; - -static const struct pci_driver pch_pci __pci_driver = { - .ops = &device_ops, - .vendor = PCI_VENDOR_ID_INTEL, - .device = 0x2448, -};
