Furquan Shaikh has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/42739 )
Change subject: mb/google/zork: Move PCIE_RST0_L configuration to early GPIO table ......................................................................
This change moves the configuration of PCIE_RST0_L as native function to happen in early GPIO table. This ensures that the PERST# signal is deasserted as soon as possible when the system comes out of sleep state in case the sleep path asserted/deasserted the PERST# as GPIO out.
A big difference in functionality with this change is that PCIE_RST0_L signal is now configured as part of RO, which should be fine since all PCIe devices have a second AUX_RESET_L signal or use PCIE_RST1_L to control the actual reset to the device.
Signed-off-by: Furquan Shaikh furquan@google.com Change-Id: I21a9c25b5a8a6d502cdb79cbe0dbad6ef98d6d63 --- M src/mainboard/google/zork/variants/baseboard/gpio_baseboard_common.c M src/mainboard/google/zork/variants/baseboard/gpio_baseboard_dalboz.c M src/mainboard/google/zork/variants/baseboard/gpio_baseboard_trembyle.c 3 files changed, 2 insertions(+), 12 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/39/42739/1
diff --git a/src/mainboard/google/zork/variants/baseboard/gpio_baseboard_common.c b/src/mainboard/google/zork/variants/baseboard/gpio_baseboard_common.c index e903700..a4e8648 100644 --- a/src/mainboard/google/zork/variants/baseboard/gpio_baseboard_common.c +++ b/src/mainboard/google/zork/variants/baseboard/gpio_baseboard_common.c @@ -13,6 +13,8 @@ PAD_NF(GPIO_19, I2C3_SCL, PULL_UP), /* I2C3_SDA - H1 */ PAD_NF(GPIO_20, I2C3_SDA, PULL_UP), + /* PCIE_RST0_L - Fixed timings */ + PAD_NF(GPIO_26, PCIE_RST_L, PULL_NONE), /* FCH_ESPI_EC_CS_L */ PAD_NF(GPIO_30, ESPI_CS_L, PULL_NONE), /* ESPI_ALERT_L (may be unused) */ diff --git a/src/mainboard/google/zork/variants/baseboard/gpio_baseboard_dalboz.c b/src/mainboard/google/zork/variants/baseboard/gpio_baseboard_dalboz.c index d4ed86e..d6343a6 100644 --- a/src/mainboard/google/zork/variants/baseboard/gpio_baseboard_dalboz.c +++ b/src/mainboard/google/zork/variants/baseboard/gpio_baseboard_dalboz.c @@ -15,9 +15,6 @@ /* EC_FCH_WAKE_L */ PAD_GPI(GPIO_24, PULL_UP), PAD_WAKE(GPIO_24, PULL_UP, EDGE_LOW, S3_S4_S5), - /* PCIE_RST0_L - Fixed timings */ - /* TODO: Make sure this gets locked at end of post */ - PAD_NF(GPIO_26, PCIE_RST_L, PULL_NONE), /* PCIE_RST1_L - Variable timings (May remove) */ PAD_NF(GPIO_27, PCIE_RST1_L, PULL_NONE), /* NVME_AUX_RESET_L */ @@ -52,9 +49,6 @@ /* EC_FCH_WAKE_L */ PAD_GPI(GPIO_24, PULL_UP), PAD_WAKE(GPIO_24, PULL_UP, EDGE_LOW, S3_S4_S5), - /* PCIE_RST0_L - Fixed timings */ - /* TODO: Make sure this gets locked at end of post */ - PAD_NF(GPIO_26, PCIE_RST_L, PULL_NONE), /* PCIE_RST1_L - Variable timings (May remove) */ PAD_NF(GPIO_27, PCIE_RST1_L, PULL_NONE), /* NVME_AUX_RESET_L */ diff --git a/src/mainboard/google/zork/variants/baseboard/gpio_baseboard_trembyle.c b/src/mainboard/google/zork/variants/baseboard/gpio_baseboard_trembyle.c index abee520..f93309d 100644 --- a/src/mainboard/google/zork/variants/baseboard/gpio_baseboard_trembyle.c +++ b/src/mainboard/google/zork/variants/baseboard/gpio_baseboard_trembyle.c @@ -15,9 +15,6 @@ /* EC_FCH_WAKE_L */ PAD_GPI(GPIO_24, PULL_UP), PAD_WAKE(GPIO_24, PULL_UP, EDGE_LOW, S3_S4_S5), - /* PCIE_RST0_L - Fixed timings */ - /* TODO: Make sure this gets locked at end of post */ - PAD_NF(GPIO_26, PCIE_RST_L, PULL_NONE), /* PCIE_RST1_L - Variable timings (May remove) */ PAD_NF(GPIO_27, PCIE_RST1_L, PULL_NONE), /* NVME_AUX_RESET_L */ @@ -50,9 +47,6 @@ /* EC_FCH_WAKE_L */ PAD_GPI(GPIO_24, PULL_UP), PAD_WAKE(GPIO_24, PULL_UP, EDGE_LOW, S3_S4_S5), - /* PCIE_RST0_L - Fixed timings */ - /* TODO: Make sure this gets locked at end of post */ - PAD_NF(GPIO_26, PCIE_RST_L, PULL_NONE), /* PCIE_RST1_L - Variable timings (May remove) */ PAD_NF(GPIO_27, PCIE_RST1_L, PULL_NONE), /* NVME_AUX_RESET_L */
Aaron Durbin has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/42739 )
Patch Set 2: Code-Review+2
Furquan Shaikh has submitted this change. ( https://review.coreboot.org/c/coreboot/+/42739 )
Signed-off-by: Furquan Shaikh furquan@google.com Change-Id: I21a9c25b5a8a6d502cdb79cbe0dbad6ef98d6d63 Reviewed-on: https://review.coreboot.org/c/coreboot/+/42739 Reviewed-by: Aaron Durbin adurbin@chromium.org Tested-by: build bot (Jenkins) no-reply@coreboot.org --- M src/mainboard/google/zork/variants/baseboard/gpio_baseboard_common.c M src/mainboard/google/zork/variants/baseboard/gpio_baseboard_dalboz.c M src/mainboard/google/zork/variants/baseboard/gpio_baseboard_trembyle.c 3 files changed, 2 insertions(+), 12 deletions(-)
Approvals: build bot (Jenkins): Verified Aaron Durbin: Looks good to me, approved
diff --git a/src/mainboard/google/zork/variants/baseboard/gpio_baseboard_common.c b/src/mainboard/google/zork/variants/baseboard/gpio_baseboard_common.c index e903700..a4e8648 100644 --- a/src/mainboard/google/zork/variants/baseboard/gpio_baseboard_common.c +++ b/src/mainboard/google/zork/variants/baseboard/gpio_baseboard_common.c @@ -13,6 +13,8 @@ PAD_NF(GPIO_19, I2C3_SCL, PULL_UP), /* I2C3_SDA - H1 */ PAD_NF(GPIO_20, I2C3_SDA, PULL_UP), + /* PCIE_RST0_L - Fixed timings */ + PAD_NF(GPIO_26, PCIE_RST_L, PULL_NONE), /* FCH_ESPI_EC_CS_L */ PAD_NF(GPIO_30, ESPI_CS_L, PULL_NONE), /* ESPI_ALERT_L (may be unused) */ diff --git a/src/mainboard/google/zork/variants/baseboard/gpio_baseboard_dalboz.c b/src/mainboard/google/zork/variants/baseboard/gpio_baseboard_dalboz.c index 35e1829..ba50362 100644 --- a/src/mainboard/google/zork/variants/baseboard/gpio_baseboard_dalboz.c +++ b/src/mainboard/google/zork/variants/baseboard/gpio_baseboard_dalboz.c @@ -15,9 +15,6 @@ /* EC_FCH_WAKE_L */ PAD_GPI(GPIO_24, PULL_UP), PAD_WAKE(GPIO_24, PULL_UP, EDGE_LOW, S3_S4_S5), - /* PCIE_RST0_L - Fixed timings */ - /* TODO: Make sure this gets locked at end of post */ - PAD_NF(GPIO_26, PCIE_RST_L, PULL_NONE), /* PCIE_RST1_L - Variable timings (May remove) */ PAD_NF(GPIO_27, PCIE_RST1_L, PULL_NONE), /* NVME_AUX_RESET_L */ @@ -52,9 +49,6 @@ /* EC_FCH_WAKE_L */ PAD_GPI(GPIO_24, PULL_UP), PAD_WAKE(GPIO_24, PULL_UP, EDGE_LOW, S3_S4_S5), - /* PCIE_RST0_L - Fixed timings */ - /* TODO: Make sure this gets locked at end of post */ - PAD_NF(GPIO_26, PCIE_RST_L, PULL_NONE), /* PCIE_RST1_L - Variable timings (May remove) */ PAD_NF(GPIO_27, PCIE_RST1_L, PULL_NONE), /* NVME_AUX_RESET_L */ diff --git a/src/mainboard/google/zork/variants/baseboard/gpio_baseboard_trembyle.c b/src/mainboard/google/zork/variants/baseboard/gpio_baseboard_trembyle.c index 3f02f00..01aef2b 100644 --- a/src/mainboard/google/zork/variants/baseboard/gpio_baseboard_trembyle.c +++ b/src/mainboard/google/zork/variants/baseboard/gpio_baseboard_trembyle.c @@ -15,9 +15,6 @@ /* EC_FCH_WAKE_L */ PAD_GPI(GPIO_24, PULL_UP), PAD_WAKE(GPIO_24, PULL_UP, EDGE_LOW, S3_S4_S5), - /* PCIE_RST0_L - Fixed timings */ - /* TODO: Make sure this gets locked at end of post */ - PAD_NF(GPIO_26, PCIE_RST_L, PULL_NONE), /* PCIE_RST1_L - Variable timings (May remove) */ PAD_NF(GPIO_27, PCIE_RST1_L, PULL_NONE), /* NVME_AUX_RESET_L */ @@ -50,9 +47,6 @@ /* EC_FCH_WAKE_L */ PAD_GPI(GPIO_24, PULL_UP), PAD_WAKE(GPIO_24, PULL_UP, EDGE_LOW, S3_S4_S5), - /* PCIE_RST0_L - Fixed timings */ - /* TODO: Make sure this gets locked at end of post */ - PAD_NF(GPIO_26, PCIE_RST_L, PULL_NONE), /* PCIE_RST1_L - Variable timings (May remove) */ PAD_NF(GPIO_27, PCIE_RST1_L, PULL_NONE), /* NVME_AUX_RESET_L */
