Felix Held has submitted this change. ( https://review.coreboot.org/c/coreboot/+/62607 )
Change subject: ec/starlabs: Write the correct value for TPLE when suspending ......................................................................
The current code will write the raw value from the CMOS, which doesn't match the respective setting in EC.
Switch argument will write the correct value, and prevent the setting being reset.
Signed-off-by: Sean Rhodes sean@starlabs.systems Change-Id: Iabeec47bf492b698f95d86aa2d08ba9caedd75f6 Reviewed-on: https://review.coreboot.org/c/coreboot/+/62607 Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: Angel Pons th3fanbus@gmail.com --- M src/ec/starlabs/merlin/acpi/suspend.asl 1 file changed, 15 insertions(+), 1 deletion(-)
diff --git a/src/ec/starlabs/merlin/acpi/suspend.asl b/src/ec/starlabs/merlin/acpi/suspend.asl index 81ae8d1..0f1c27c 100644 --- a/src/ec/starlabs/merlin/acpi/suspend.asl +++ b/src/ec/starlabs/merlin/acpi/suspend.asl @@ -82,7 +82,21 @@ _SB.PCI0.LPCB.EC.OSFG = 0x01
/* Restore EC settings from CMOS */ - _SB.PCI0.LPCB.EC.TPLE = _SB.PCI0.LPCB.TPLC + Switch (ToInteger (_SB.PCI0.LPCB.TPLC)) + { + // 0x00 == Enabled == 0x00 + // 0x00 == Re-enabled == 0x11 + // 0x01 == Disabled == 0x22 + Case (0x00) + { + _SB.PCI0.LPCB.EC.TPLE = 0x00 + } + Case (0x01) + { + _SB.PCI0.LPCB.EC.TPLE = 0x22 + } + } + _SB.PCI0.LPCB.EC.FLKE = _SB.PCI0.LPCB.FLKC _SB.PCI0.LPCB.EC.KLSE = _SB.PCI0.LPCB.KLSC _SB.PCI0.LPCB.EC.KLBE = _SB.PCI0.LPCB.KLBC
