Felix Held has submitted this change. ( https://review.coreboot.org/c/coreboot/+/84237?usp=email )
Change subject: mb/google/zork: Add Kconfig to set IGD UMA allocation via APCB ......................................................................
Add a Kconfig choice to select the IGD UMA allocation, which selects a precompiled ACPB binary with the corresponding UMA value set. Default to the previous value (128MB) for non-ChromeOS builds, and 64MB for ChromeOS as that is the value used there.
TEST=build/boot google/morphius, verify UMA size changes with selection via dxdiag tool under Windows.
Change-Id: I6debd10527c33ce37ef3ada20955c8f7b7500039 Signed-off-by: Matt DeVillier matt.devillier@gmail.com Reviewed-on: https://review.coreboot.org/c/coreboot/+/84237 Reviewed-by: Felix Held felix-coreboot@felixheld.de Tested-by: build bot (Jenkins) no-reply@coreboot.org --- M src/mainboard/google/zork/Kconfig D src/mainboard/google/zork/data.apcb M src/mainboard/google/zork/spd/Makefile.mk A src/mainboard/google/zork/uma_128.apcb A src/mainboard/google/zork/uma_256.apcb A src/mainboard/google/zork/uma_512.apcb A src/mainboard/google/zork/uma_64.apcb 7 files changed, 31 insertions(+), 1 deletion(-)
diff --git a/src/mainboard/google/zork/Kconfig b/src/mainboard/google/zork/Kconfig index 1fcd06b..1b38d27 100644 --- a/src/mainboard/google/zork/Kconfig +++ b/src/mainboard/google/zork/Kconfig @@ -301,4 +301,25 @@ select SAR_ENABLE select USE_SAR
+choice + prompt "UMA Memory Allocation" + default ZORK_UMA_SIZE_64MB if CHROMEOS + default ZORK_UMA_SIZE_128MB + help + The amount of system memory allocated for the integrated GPU. + +config ZORK_UMA_SIZE_64MB + bool "64MB" + +config ZORK_UMA_SIZE_128MB + bool "128MB" + +config ZORK_UMA_SIZE_256MB + bool "256MB" + +config ZORK_UMA_SIZE_512MB + bool "512MB" + +endchoice + endif # BOARD_GOOGLE_BASEBOARD_TREMBYLE || BOARD_GOOGLE_BASEBOARD_DALBOZ diff --git a/src/mainboard/google/zork/spd/Makefile.mk b/src/mainboard/google/zork/spd/Makefile.mk index 3e6509d..1f0b20c 100644 --- a/src/mainboard/google/zork/spd/Makefile.mk +++ b/src/mainboard/google/zork/spd/Makefile.mk @@ -5,7 +5,16 @@ APCB_SOURCES=$(foreach f, $(basename $(notdir $(SPD_SOURCES))), $(obj)/APCB_$(f).gen)
# APCB binary with magic numbers to be replaced by apcb_edit tool -APCB_NAME=data.apcb +ifeq ($(CONFIG_ZORK_UMA_SIZE_64MB),y) +APCB_NAME=uma_64.apcb +else ifeq ($(CONFIG_ZORK_UMA_SIZE_128MB),y) +APCB_NAME=uma_128.apcb +else ifeq ($(CONFIG_ZORK_UMA_SIZE_256MB),y) +APCB_NAME=uma_256.apcb +else ifeq ($(CONFIG_ZORK_UMA_SIZE_512MB),y) +APCB_NAME=uma_512.apcb +endif + APCB_PATH=$(src)/mainboard/$(MAINBOARDDIR)
$(obj)/APCB_%.gen: $(SPD_SOURCES_DIR)%.hex \ diff --git a/src/mainboard/google/zork/data.apcb b/src/mainboard/google/zork/uma_128.apcb similarity index 97% rename from src/mainboard/google/zork/data.apcb rename to src/mainboard/google/zork/uma_128.apcb index ee12694..fd605b4 100644 --- a/src/mainboard/google/zork/data.apcb +++ b/src/mainboard/google/zork/uma_128.apcb Binary files differ diff --git a/src/mainboard/google/zork/data.apcb b/src/mainboard/google/zork/uma_256.apcb similarity index 93% copy from src/mainboard/google/zork/data.apcb copy to src/mainboard/google/zork/uma_256.apcb index ee12694..f3bd14f 100644 --- a/src/mainboard/google/zork/data.apcb +++ b/src/mainboard/google/zork/uma_256.apcb Binary files differ diff --git a/src/mainboard/google/zork/data.apcb b/src/mainboard/google/zork/uma_512.apcb similarity index 93% copy from src/mainboard/google/zork/data.apcb copy to src/mainboard/google/zork/uma_512.apcb index ee12694..0914c2a 100644 --- a/src/mainboard/google/zork/data.apcb +++ b/src/mainboard/google/zork/uma_512.apcb Binary files differ diff --git a/src/mainboard/google/zork/data.apcb b/src/mainboard/google/zork/uma_64.apcb similarity index 93% copy from src/mainboard/google/zork/data.apcb copy to src/mainboard/google/zork/uma_64.apcb index ee12694..99abf34 100644 --- a/src/mainboard/google/zork/data.apcb +++ b/src/mainboard/google/zork/uma_64.apcb Binary files differ
