Timothy Pearson (tpearson@raptorengineeringinc.com) just uploaded a new patch set to gerrit, which you can find at http://review.coreboot.org/12289
commit 62d320df70ef2aca2a0227e39f229efdff07da43 Author: Timothy Pearson tpearson@raptorengineeringinc.com Date: Sun Nov 1 02:13:17 2015 -0600
drivers/pc80: Rework normal / fallback selector code
Per IRC and Gerrit discussion, the normal / fallback selector code is a rather weak spot in coreboot, and did not function correctly for certain use cases.
Rework the selector to more clearly indicate proper operation, and also remove dead code. Also tentatively abandon use of RTC bit 385; a follow-up patch will remove said bit from all affected mainboards.
The correct operation of the fallback code selector approximates that of a power line recloser, with a user option to attempt normal boot that can be cleared by firmware, but never set by firmware. Additionally, if cleared by user, the fallback path should always be used on the next reboot.
Change-Id: I753ae9f0710c524875a85354ac2547df0c305569 Signed-off-by: Timothy Pearson tpearson@raptorengineeringinc.com --- src/drivers/pc80/mc146818rtc_early.c | 56 +++++++++++++++++++----------------- src/include/pc80/mc146818rtc.h | 2 ++ src/lib/fallback_boot.c | 25 +++++++++------- 3 files changed, 46 insertions(+), 37 deletions(-)
diff --git a/src/drivers/pc80/mc146818rtc_early.c b/src/drivers/pc80/mc146818rtc_early.c index 421af2f..1de920e 100644 --- a/src/drivers/pc80/mc146818rtc_early.c +++ b/src/drivers/pc80/mc146818rtc_early.c @@ -41,12 +41,24 @@ static int cmos_chksum_valid(void) #endif }
+static inline __attribute__((unused)) int boot_count(uint8_t rtc_byte) +{ + return rtc_byte >> 4; +}
-static inline __attribute__((unused)) int last_boot_normal(void) +static inline __attribute__((unused)) uint8_t increment_boot_count(uint8_t rtc_byte) { - unsigned char byte; - byte = cmos_read(RTC_BOOT_BYTE); - return (byte & (1 << 1)); + return rtc_byte + (1 << 4); +} + +static inline __attribute__((unused)) uint8_t boot_use_fallback(uint8_t rtc_byte) +{ + return rtc_byte & ~RTC_BOOT_NORMAL; +} + +static inline __attribute__((unused)) int boot_use_normal(uint8_t rtc_byte) +{ + return rtc_byte & RTC_BOOT_NORMAL; }
static inline __attribute__((unused)) int do_normal_boot(void) @@ -54,42 +66,32 @@ static inline __attribute__((unused)) int do_normal_boot(void) unsigned char byte;
if (cmos_error() || !cmos_chksum_valid()) { - /* There are no impossible values, no checksums so just - * trust whatever value we have in the the cmos, - * but clear the fallback bit. + /* Invalid CMOS checksum detected! + * Force fallback boot... */ byte = cmos_read(RTC_BOOT_BYTE); - byte &= 0x0c; - byte |= CONFIG_MAX_REBOOT_CNT << 4; + byte &= boot_use_fallback(byte) & 0x0f; + byte |= 0xf << 4; cmos_write(byte, RTC_BOOT_BYTE); }
/* The RTC_BOOT_BYTE is now o.k. see where to go. */ byte = cmos_read(RTC_BOOT_BYTE);
- if (!IS_ENABLED(CONFIG_SKIP_MAX_REBOOT_CNT_CLEAR)) - /* Are we in normal mode? */ - if (byte & 1) - byte &= 0x0f; /* yes, clear the boot count */ - - /* Properly set the last boot flag */ - byte &= 0xfc; - if ((byte >> 4) < CONFIG_MAX_REBOOT_CNT) { - byte |= (1<<1); - } - - /* Are we already at the max count? */ - if ((byte >> 4) < CONFIG_MAX_REBOOT_CNT) { - byte += 1 << 4; /* No, add 1 to the count */ - } - else { - byte &= 0xfc; /* Yes, put in fallback mode */ + /* Are we attempting to boot normally? */ + if (byte & RTC_BOOT_NORMAL) { + /* Are we already at the max count? */ + if (boot_count(byte) < CONFIG_MAX_REBOOT_CNT) + byte = increment_boot_count(byte); + else + byte = boot_use_fallback(byte); }
/* Save the boot byte */ cmos_write(byte, RTC_BOOT_BYTE);
- return (byte & (1<<1)); + /* Return selected code path for this boot attempt */ + return (byte & RTC_BOOT_NORMAL); }
unsigned read_option_lowlevel(unsigned start, unsigned size, unsigned def) diff --git a/src/include/pc80/mc146818rtc.h b/src/include/pc80/mc146818rtc.h index 0e15273..38f2ad0 100644 --- a/src/include/pc80/mc146818rtc.h +++ b/src/include/pc80/mc146818rtc.h @@ -25,6 +25,8 @@ **********************************************************************/ #define RTC_FREQ_SELECT RTC_REG_A
+#define RTC_BOOT_NORMAL 0x1 + /* update-in-progress - set to "1" 244 microsecs before RTC goes off the bus, * reset after update (may take 1.984ms @ 32768Hz RefClock) is complete, * totaling to a max high interval of 2.228 ms. diff --git a/src/lib/fallback_boot.c b/src/lib/fallback_boot.c index 74572df..b1b37a7 100644 --- a/src/lib/fallback_boot.c +++ b/src/lib/fallback_boot.c @@ -8,23 +8,28 @@
static void set_boot_successful(void) { - /* Remember I successfully booted by setting - * the initial boot direction - * to the direction that I booted. - */ - unsigned char index, byte; + uint8_t index, byte; + index = inb(RTC_PORT(0)) & 0x80; index |= RTC_BOOT_BYTE; outb(index, RTC_PORT(0));
byte = inb(RTC_PORT(1)); - byte &= 0xfe; - byte |= (byte & (1 << 1)) >> 1;
- /* If we are in normal mode set the boot count to 0 */ - if (!IS_ENABLED(CONFIG_SKIP_MAX_REBOOT_CNT_CLEAR)) - if(byte & 1) + if (IS_ENABLED(CONFIG_SKIP_MAX_REBOOT_CNT_CLEAR)) { + /* Set the fallback boot bit to allow for recovery if + * the payload fails to boot. + * It is the responsibility of the payload to reset + * the normal boot bit to 1 if desired + */ + byte &= ~RTC_BOOT_NORMAL; + } else { + /* If we are in normal mode set the boot count to 0 */ + if(byte & RTC_BOOT_NORMAL) byte &= 0x0f; + + } + outb(byte, RTC_PORT(1)); } #else
