Leroy P Leahy (leroy.p.leahy@intel.com) just uploaded a new patch set to gerrit, which you can find at https://review.coreboot.org/14553
commit c36e25b0a6af0b72151bf415377046c082ac0099 Author: Lee Leahy leroy.p.leahy@intel.com Date: Fri Apr 29 15:07:19 2016 -0700
lib/reg_script: Add display support
Add the ability to enable the display of the script.
Change-Id: If0d4d61ed8ef48ec20082b327f358fd1987e3fb9 Signed-off-by: Lee Leahy leroy.p.leahy@intel.com --- src/include/reg_script.h | 14 ++++++ src/lib/reg_script.c | 111 ++++++++++++++++++++++++++++++++++++++++++----- 2 files changed, 114 insertions(+), 11 deletions(-)
diff --git a/src/include/reg_script.h b/src/include/reg_script.h index 741641a..639c4fe 100644 --- a/src/include/reg_script.h +++ b/src/include/reg_script.h @@ -48,6 +48,8 @@ enum { REG_SCRIPT_COMMAND_SET_DEV, REG_SCRIPT_COMMAND_NEXT, REG_SCRIPT_COMMAND_END, + REG_SCRIPT_COMMAND_DISPLAY_ON, + REG_SCRIPT_COMMAND_DISPLAY_OFF, };
enum { @@ -130,6 +132,17 @@ const struct reg_script_bus_entry *platform_bus_table(size_t *table_entries); .res_index = res_index_, \ }
+/* Display control */ +#define REG_SCRIPT_DISPLAY_REGISTER 0x00000002 +#define REG_SCRIPT_DISPLAY_VALUE 0x00000001 + +#define REG_SCRIPT_DISPLAY_OFF \ + _REG_SCRIPT_ENCODE_RAW(REG_SCRIPT_COMMAND_DISPLAY_OFF, \ + REG_SCRIPT_TYPE_PCI, 0, 0, 0, 0, 0, 0) +#define REG_SCRIPT_DISPLAY_ON \ + _REG_SCRIPT_ENCODE_RAW(REG_SCRIPT_COMMAND_DISPLAY_ON, \ + REG_SCRIPT_TYPE_PCI, 0, 0, 0, 0, 0, 0) + /* * PCI */ @@ -414,5 +427,6 @@ IS_ENABLED(CONFIG_SOC_INTEL_FSP_BAYTRAIL)
void reg_script_run(const struct reg_script *script); void reg_script_run_on_dev(device_t dev, const struct reg_script *step); +extern uint8_t reg_script_display;
#endif /* REG_SCRIPT_H */ diff --git a/src/lib/reg_script.c b/src/lib/reg_script.c index 7530dc3..cf756ec 100644 --- a/src/lib/reg_script.c +++ b/src/lib/reg_script.c @@ -40,6 +40,8 @@ #define EMPTY_DEV NULL #endif
+uint8_t reg_script_display; + static inline void reg_script_set_dev(struct reg_script_context *ctx, device_t dev) { @@ -425,22 +427,42 @@ static const struct reg_script_bus_entry
static uint64_t reg_script_read(struct reg_script_context *ctx) { + uint8_t display = reg_script_display; const struct reg_script *step = reg_script_get_step(ctx); + uint64_t value = 0;
switch (step->type) { case REG_SCRIPT_TYPE_PCI: - return reg_script_read_pci(ctx); + if (reg_script_display) + printk(BIOS_INFO, "PCI: "); + value = reg_script_read_pci(ctx); + break; case REG_SCRIPT_TYPE_IO: - return reg_script_read_io(ctx); + if (reg_script_display) + printk(BIOS_INFO, "IO: "); + value = reg_script_read_io(ctx); + break; case REG_SCRIPT_TYPE_MMIO: - return reg_script_read_mmio(ctx); + if (reg_script_display) + printk(BIOS_INFO, "MMIO: "); + value = reg_script_read_mmio(ctx); + break; case REG_SCRIPT_TYPE_RES: - return reg_script_read_res(ctx); + if (reg_script_display) + printk(BIOS_INFO, "RES: "); + value = reg_script_read_res(ctx); + break; case REG_SCRIPT_TYPE_MSR: - return reg_script_read_msr(ctx); + if (reg_script_display) + printk(BIOS_INFO, "MSR: "); + value = reg_script_read_msr(ctx); + break; #if HAS_IOSF case REG_SCRIPT_TYPE_IOSF: - return reg_script_read_iosf(ctx); + if (reg_script_display) + printk(BIOS_INFO, "IOSF: "); + value = reg_script_read_iosf(ctx); + break; #endif /* HAS_IOSF */ default: #ifndef __PRE_RAM__ @@ -450,39 +472,74 @@ static uint64_t reg_script_read(struct reg_script_context *ctx) /* Read from the platform specific bus */ bus = find_bus(step); if (NULL != bus) - return bus->reg_script_read(ctx); + value = bus->reg_script_read(ctx); + break; } #endif printk(BIOS_ERR, "Unsupported read type (0x%x) for this device!\n", step->type); - break; + return 0; } - return 0; + if (reg_script_display) { + if (reg_script_display & REG_SCRIPT_DISPLAY_REGISTER) + printk(BIOS_INFO, "0x%08x --> ", step->reg); + if (reg_script_display & REG_SCRIPT_DISPLAY_VALUE) + switch (step->size) { + case REG_SCRIPT_SIZE_8: + printk(BIOS_INFO, "0x%02x\n", (uint8_t)value); + break; + case REG_SCRIPT_SIZE_16: + printk(BIOS_INFO, "0x%04x\n", (int16_t)value); + break; + case REG_SCRIPT_SIZE_32: + printk(BIOS_INFO, "0x%08x\n", (uint32_t)value); + break; + default: + printk(BIOS_INFO, "0x%016llx\n", value); + break; + } + } + reg_script_display = display; + return value; }
static void reg_script_write(struct reg_script_context *ctx) { + uint8_t display = reg_script_display; const struct reg_script *step = reg_script_get_step(ctx); + uint64_t value;
switch (step->type) { case REG_SCRIPT_TYPE_PCI: + if (reg_script_display) + printk(BIOS_INFO, "PCI: "); reg_script_write_pci(ctx); break; case REG_SCRIPT_TYPE_IO: + if (reg_script_display) + printk(BIOS_INFO, "IO: "); reg_script_write_io(ctx); break; case REG_SCRIPT_TYPE_MMIO: + if (reg_script_display) + printk(BIOS_INFO, "MMIO: "); reg_script_write_mmio(ctx); break; case REG_SCRIPT_TYPE_RES: + if (reg_script_display) + printk(BIOS_INFO, "RES: "); reg_script_write_res(ctx); break; case REG_SCRIPT_TYPE_MSR: + if (reg_script_display) + printk(BIOS_INFO, "MSR: "); reg_script_write_msr(ctx); break; #if HAS_IOSF case REG_SCRIPT_TYPE_IOSF: + if (reg_script_display) + printk(BIOS_INFO, "IOSF: "); reg_script_write_iosf(ctx); break; #endif /* HAS_IOSF */ @@ -495,15 +552,36 @@ static void reg_script_write(struct reg_script_context *ctx) bus = find_bus(step); if (NULL != bus) { bus->reg_script_write(ctx); - return; + break; } } #endif printk(BIOS_ERR, "Unsupported write type (0x%x) for this device!\n", step->type); - break; + return; } + if (reg_script_display) { + if (reg_script_display & REG_SCRIPT_DISPLAY_REGISTER) + printk(BIOS_INFO, "0x%08x <-- ", step->reg); + value = step->value; + if (reg_script_display & REG_SCRIPT_DISPLAY_VALUE) + switch (step->size) { + case REG_SCRIPT_SIZE_8: + printk(BIOS_INFO, "0x%02x\n", (uint8_t)value); + break; + case REG_SCRIPT_SIZE_16: + printk(BIOS_INFO, "0x%04x\n", (uint16_t)value); + break; + case REG_SCRIPT_SIZE_32: + printk(BIOS_INFO, "0x%08x\n", (uint32_t)value); + break; + default: + printk(BIOS_INFO, "0x%016llx\n", value); + break; + } + } + reg_script_display = display; }
static void reg_script_rmw(struct reg_script_context *ctx) @@ -601,6 +679,14 @@ static void reg_script_run_step(struct reg_script_context *ctx, case REG_SCRIPT_COMMAND_NEXT: reg_script_run_next(ctx, step->next); break; + case REG_SCRIPT_COMMAND_DISPLAY_ON: + reg_script_display = REG_SCRIPT_DISPLAY_REGISTER + | REG_SCRIPT_DISPLAY_VALUE; + break; + case REG_SCRIPT_COMMAND_DISPLAY_OFF: + reg_script_display = 0; + break; + default: printk(BIOS_WARNING, "Invalid command: %08x\n", step->command); @@ -619,6 +705,9 @@ static void reg_script_run_with_context(struct reg_script_context *ctx) reg_script_run_step(ctx, step); reg_script_set_step(ctx, step + 1); } + + /* Turn off the display at the end of the script */ + reg_script_display = 0; }
static void reg_script_run_next(struct reg_script_context *prev_ctx,
