HAOUAS Elyes has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/36215 )
Change subject: src/include/console: Get rid of unused deprecated POST codes ......................................................................
Change-Id: Id577b7c1421e9ffc3f51e90fcc9330c8f3be9a56 Signed-off-by: Elyes HAOUAS ehaouas@noos.fr --- M src/include/console/post_codes.h 1 file changed, 0 insertions(+), 173 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/15/36215/1
diff --git a/src/include/console/post_codes.h b/src/include/console/post_codes.h index c1917ad..1813c9e 100644 --- a/src/include/console/post_codes.h +++ b/src/include/console/post_codes.h @@ -417,177 +417,4 @@ */ #define POST_DIE 0xff
- -/* - * The following POST codes are taken from src/include/cpu/amd/geode_post_code.h - * They overlap with previous codes, and most are not even used - * Some mainboards still require them, but they are deprecated. We want to - * consolidate our own POST code structure with the codes above. - * - * standard AMD post definitions for the AMD Geode - */ -/* port to write post codes to */ -#define POST_Output_Port (0x080) - -#define POST_preSioInit (0x000) -#define POST_clockInit (0x001) -#define POST_CPURegInit (0x002) -#define POST_UNREAL (0x003) -#define POST_CPUMemRegInit (0x004) -#define POST_CPUTest (0x005) -#define POST_memSetup (0x006) -#define POST_memSetUpStack (0x007) -#define POST_memTest (0x008) -#define POST_shadowRom (0x009) -#define POST_memRAMoptimize (0x00A) -#define POST_cacheInit (0x00B) -#define POST_northBridgeInit (0x00C) -#define POST_chipsetInit (0x00D) -#define POST_sioTest (0x00E) -#define POST_pcATjunk (0x00F) - -#define POST_intTable (0x010) -#define POST_memInfo (0x011) -#define POST_romCopy (0x012) -#define POST_PLLCheck (0x013) -#define POST_keyboardInit (0x014) -#define POST_cpuCacheOff (0x015) -#define POST_BDAInit (0x016) -#define POST_pciScan (0x017) -#define POST_optionRomInit (0x018) -#define POST_ResetLimits (0x019) -#define POST_summary_screen (0x01A) -#define POST_Boot (0x01B) -#define POST_SystemPreInit (0x01C) -#define POST_ClearRebootFlag (0x01D) -#define POST_GLIUInit (0x01E) -#define POST_BootFailed (0x01F) - -#define POST_CPU_ID (0x020) -#define POST_COUNTERBROKEN (0x021) -#define POST_DIFF_DIMMS (0x022) -#define POST_WIGGLE_MEM_LINES (0x023) -#define POST_NO_GLIU_DESC (0x024) -#define POST_CPU_LCD_CHECK (0x025) -#define POST_CPU_LCD_PASS (0x026) -#define POST_CPU_LCD_FAIL (0x027) -#define POST_CPU_STEPPING (0x028) -#define POST_CPU_DM_BIST_FAILURE (0x029) -#define POST_CPU_FLAGS (0x02A) -#define POST_CHIPSET_ID (0x02B) -#define POST_CHIPSET_ID_PASS (0x02C) -#define POST_CHIPSET_ID_FAIL (0x02D) -#define POST_CPU_ID_GOOD (0x02E) -#define POST_CPU_ID_FAIL (0x02F) - -/* PCI config*/ -#define P80_PCICFG (0x030) - -/* PCI io*/ -#define P80_PCIIO (0x040) - -/* PCI memory*/ -#define P80_PCIMEM (0x050) - -/* SIO*/ -#define P80_SIO (0x060) - -/* Memory Setp*/ -#define P80_MEM_SETUP (0x070) -#define POST_MEM_SETUP (0x070) -#define ERROR_32BIT_DIMMS (0x071) -#define POST_MEM_SETUP2 (0x072) -#define POST_MEM_SETUP3 (0x073) -#define POST_MEM_SETUP4 (0x074) -#define POST_MEM_SETUP5 (0x075) -#define POST_MEM_ENABLE (0x076) -#define ERROR_NO_DIMMS (0x077) -#define ERROR_DIFF_DIMMS (0x078) -#define ERROR_BAD_LATENCY (0x079) -#define ERROR_SET_PAGE (0x07A) -#define ERROR_DENSITY_DIMM (0x07B) -#define ERROR_UNSUPPORTED_DIMM (0x07C) -#define ERROR_BANK_SET (0x07D) -#define POST_MEM_SETUP_GOOD (0x07E) -#define POST_MEM_SETUP_FAIL (0x07F) - -#define POST_UserPreInit (0x080) -#define POST_UserPostInit (0x081) -#define POST_Equipment_check (0x082) -#define POST_InitNVRAMBX (0x083) -#define POST_NoPIRTable (0x084) -#define POST_ChipsetFingerPrintPass (0x085) -#define POST_ChipsetFingerPrintFail (0x086) -#define POST_CPU_IM_TAG_BIST_FAILURE (0x087) -#define POST_CPU_IM_DATA_BIST_FAILURE (0x088) -#define POST_CPU_FPU_BIST_FAILURE (0x089) -#define POST_CPU_BTB_BIST_FAILURE (0x08A) -#define POST_CPU_EX_BIST_FAILURE (0x08B) -#define POST_Chipset_PI_Test_Fail (0x08C) -#define POST_Chipset_SMBus_SDA_Test_Fail (0x08D) -#define POST_BIT_CLK_Fail (0x08E) - -#define POST_STACK_SETUP (0x090) -#define POST_CPU_PF_BIST_FAILURE (0x091) -#define POST_CPU_L2_BIST_FAILURE (0x092) -#define POST_CPU_GLCP_BIST_FAILURE (0x093) -#define POST_CPU_DF_BIST_FAILURE (0x094) -#define POST_CPU_VG_BIST_FAILURE (0x095) -#define POST_CPU_VIP_BIST_FAILURE (0x096) -#define POST_STACK_SETUP_PASS (0x09E) -#define POST_STACK_SETUP_FAIL (0x09F) - -#define POST_PLL_INIT (0x0A0) -#define POST_PLL_MANUAL (0x0A1) -#define POST_PLL_STRAP (0x0A2) -#define POST_PLL_RESET_FAIL (0x0A3) -#define POST_PLL_PCI_FAIL (0x0A4) -#define POST_PLL_MEM_FAIL (0x0A5) -#define POST_PLL_CPU_VER_FAIL (0x0A6) - -#define POST_MEM_TESTMEM (0x0B0) -#define POST_MEM_TESTMEM1 (0x0B1) -#define POST_MEM_TESTMEM2 (0x0B2) -#define POST_MEM_TESTMEM3 (0x0B3) -#define POST_MEM_TESTMEM4 (0x0B4) -#define POST_MEM_TESTMEM_PASS (0x0BE) -#define POST_MEM_TESTMEM_FAIL (0x0BF) - -#define POST_SECUROM_SECBOOT_START (0x0C0) -#define POST_SECUROM_BOOTSRCSETUP (0x0C1) -#define POST_SECUROM_REMAP_FAIL (0x0C2) -#define POST_SECUROM_BOOTSRCSETUP_FAIL (0x0C3) -#define POST_SECUROM_DCACHESETUP (0x0C4) -#define POST_SECUROM_DCACHESETUP_FAIL (0x0C5) -#define POST_SECUROM_ICACHESETUP (0x0C6) -#define POST_SECUROM_DESCRIPTORSETUP (0x0C7) -#define POST_SECUROM_DCACHESETUPBIOS (0x0C8) -#define POST_SECUROM_PLATFORMSETUP (0x0C9) -#define POST_SECUROM_SIGCHECKBIOS (0x0CA) -#define POST_SECUROM_ICACHESETUPBIOS (0x0CB) -#define POST_SECUROM_PASS (0x0CC) -#define POST_SECUROM_FAIL (0x0CD) - -#define POST_RCONFInitError (0x0CE) -#define POST_CacheInitError (0x0CF) - -#define POST_ROM_PREUNCOMPRESS (0x0D0) -#define POST_ROM_UNCOMPRESS (0x0D1) -#define POST_ROM_SMM_INIT (0x0D2) -#define POST_ROM_VID_BIOS (0x0D3) -#define POST_ROM_LCDINIT (0x0D4) -#define POST_ROM_SPLASH (0x0D5) -#define POST_ROM_HDDINIT (0x0D6) -#define POST_ROM_SYS_INIT (0x0D7) -#define POST_ROM_DMM_INIT (0x0D8) -#define POST_ROM_TVINIT (0x0D9) -#define POST_ROM_POSTUNCOMPRESS (0x0DE) - -#define P80_CHIPSET_INIT (0x0E0) -#define POST_PreChipsetInit (0x0E1) -#define POST_LateChipsetInit (0x0E2) -#define POST_NORTHB_INIT (0x0E8) - -#define POST_INTR_SEG_JUMP (0x0F0) - #endif /* POST_CODES_H */
Patrick Georgi has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/36215 )
Patch Set 1: Code-Review+2
Patrick Georgi has submitted this change. ( https://review.coreboot.org/c/coreboot/+/36215 )
Change-Id: Id577b7c1421e9ffc3f51e90fcc9330c8f3be9a56 Signed-off-by: Elyes HAOUAS ehaouas@noos.fr Reviewed-on: https://review.coreboot.org/c/coreboot/+/36215 Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: Patrick Georgi pgeorgi@google.com --- M src/include/console/post_codes.h 1 file changed, 0 insertions(+), 173 deletions(-)
