Felix Held has submitted this change. ( https://review.coreboot.org/c/coreboot/+/68537 )
Change subject: soc/amd/morgana/uart: introduce and use soc_get_uart_ctrlr_info ......................................................................
Introduce and use soc_get_uart_ctrlr_info to access the uart_info array to further decouple uart_info from the code as preparation to factor out most of the code to a common implementation. In order to slightly reduce the number of function calls, pass the size of and pointer to uart_info to get_uart_idx as a parameter instead of calling again soc_get_uart_ctrlr_info in get_uart_idx despite all callers already having the information form the soc_get_uart_ctrlr_info call.
Signed-off-by: Felix Held felix-coreboot@felixheld.de Change-Id: I80278f1a098b389d78f8e9a9fb875c4e466dc5db Reviewed-on: https://review.coreboot.org/c/coreboot/+/68537 Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: Fred Reitberger reitbergerfred@gmail.com --- M src/soc/amd/morgana/uart.c 1 file changed, 54 insertions(+), 14 deletions(-)
Approvals: build bot (Jenkins): Verified Fred Reitberger: Looks good to me, approved
diff --git a/src/soc/amd/morgana/uart.c b/src/soc/amd/morgana/uart.c index 8a77c87..f6c552c 100644 --- a/src/soc/amd/morgana/uart.c +++ b/src/soc/amd/morgana/uart.c @@ -39,19 +39,29 @@ } }, };
-uintptr_t get_uart_base(unsigned int idx) +static const struct soc_uart_ctrlr_info *soc_get_uart_ctrlr_info(size_t *num_ctrlrs) { - if (idx >= ARRAY_SIZE(uart_info)) - return 0; - - return uart_info[idx].base; + *num_ctrlrs = ARRAY_SIZE(uart_info); + return uart_info; }
-static enum cb_err get_uart_idx(uintptr_t base, unsigned int *idx) +uintptr_t get_uart_base(unsigned int idx) +{ + size_t num_ctrlrs; + const struct soc_uart_ctrlr_info *ctrlr = soc_get_uart_ctrlr_info(&num_ctrlrs); + + if (idx >= num_ctrlrs) + return 0; + + return ctrlr[idx].base; +} + +static enum cb_err get_uart_idx(uintptr_t base, const struct soc_uart_ctrlr_info *ctrlr, + size_t num_ctrlrs, unsigned int *idx) { unsigned int i; - for (i = 0; i < ARRAY_SIZE(uart_info); i++) { - if (base == uart_info[i].base) { + for (i = 0; i < num_ctrlrs; i++) { + if (base == ctrlr[i].base) { *idx = i; return CB_SUCCESS; } @@ -62,10 +72,13 @@ static enum cb_err get_uart_aoac_device(uintptr_t base, unsigned int *aoac_dev) { unsigned int idx; - if (get_uart_idx(base, &idx) == CB_ERR) + size_t num_ctrlrs; + const struct soc_uart_ctrlr_info *ctrlr = soc_get_uart_ctrlr_info(&num_ctrlrs); + + if (get_uart_idx(base, ctrlr, num_ctrlrs, &idx) == CB_ERR) return CB_ERR;
- *aoac_dev = uart_info[idx].aoac_device; + *aoac_dev = ctrlr[idx].aoac_device; return CB_SUCCESS; }
@@ -76,17 +89,23 @@
void set_uart_config(unsigned int idx) { - if (idx >= ARRAY_SIZE(uart_info)) + size_t num_ctrlrs; + const struct soc_uart_ctrlr_info *ctrlr = soc_get_uart_ctrlr_info(&num_ctrlrs); + + if (idx >= num_ctrlrs) return;
- gpio_configure_pads(uart_info[idx].mux, 2); + gpio_configure_pads(ctrlr[idx].mux, 2); }
static const char *uart_acpi_name(const struct device *dev) { unsigned int idx; - if (get_uart_idx(dev->path.mmio.addr, &idx) == CB_SUCCESS) - return uart_info[idx].acpi_name; + size_t num_ctrlrs; + const struct soc_uart_ctrlr_info *ctrlr = soc_get_uart_ctrlr_info(&num_ctrlrs); + + if (get_uart_idx(dev->path.mmio.addr, ctrlr, num_ctrlrs, &idx) == CB_SUCCESS) + return ctrlr[idx].acpi_name; else return NULL; }
