Attention is currently required from: Angel Pons, Benjamin Doron, Jean Lucas, Lean Sheng Tan, Martin L Roth, Nico Huber, Sean Rhodes.
Hello Angel Pons, Benjamin Doron, Lean Sheng Tan, Martin L Roth, Matt DeVillier, Nico Huber, Sean Rhodes, build bot (Jenkins),
https://review.coreboot.org/c/coreboot/+/82000?usp=email
The following approvals got outdated and were removed: Code-Review+1 by Angel Pons, Code-Review+1 by Nico Huber, Verified+1 by build bot (Jenkins)
Change subject: payloads/edk2: Add Kconfig to use LAPIC timer ......................................................................
Core 2 Duo platforms have issues with HPET. Enable support to use the LAPIC driver so machines actually boot and don't hang. Tested on a Lenovo X200.
Change-Id: I33144d6c1c120e7faa47b99e8262b0997c45c9b9 Signed-off-by: Jean Lucas jean@4ray.co --- M payloads/external/Makefile.mk M payloads/external/edk2/Kconfig M payloads/external/edk2/Makefile M src/northbridge/intel/gm45/Kconfig M src/northbridge/intel/i945/Kconfig M src/northbridge/intel/x4x/Kconfig 6 files changed, 24 insertions(+), 0 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/00/82000/5
