Attention is currently required from: Tarun Tuli, Kapil Porwal, Ivy Jian.
Hello build bot (Jenkins), Tarun Tuli, Subrata Banik, Kapil Porwal, Eric Lai,
https://review.coreboot.org/c/coreboot/+/67530
Change subject: soc/intel/meteorlake: Enable tbtPcie2/3 ......................................................................
Adding support enables/disables tbtPcie2/3 by usb4_params.
BUG=b:244687646 TEST= TRP2/3 are enabled as expected. before patch [INFO ] PCI: Static device PCI: 00:07.2 not found, disabling it. [INFO ] PCI: Static device PCI: 00:07.3 not found, disabling it. after patch [DEBUG] PCI: 00:07.2 subordinate bus PCI Express [DEBUG] PCI: 00:07.2 [8086/7ec6] enabled [DEBUG] PCI: 00:07.3 subordinate bus PCI Express [DEBUG] PCI: 00:07.3 [8086/7ec7] enabled
Signed-off-by: Ivy Jian ivy.jian@quanta.corp-partner.google.com Change-Id: Ia1bdc9b5c0533bdddae67b8039103162a57fdc39 --- M src/soc/intel/meteorlake/romstage/fsp_params.c 1 file changed, 25 insertions(+), 0 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/30/67530/3
