Felix Held has submitted this change. ( https://review.coreboot.org/c/coreboot/+/68076 )
Change subject: mb/google/skyrim/var/winterhold: Enable DPTC support ......................................................................
Enable DPTC support for Winterhold
BUG=b:232946420 TEST=emerge-skyrim coreboot
Signed-off-by: EricKY Cheng ericky_cheng@compal.corp-partner.google.com Change-Id: I97c2d3ee29687cd8a9c459e90a45cef05ac4436b Reviewed-on: https://review.coreboot.org/c/coreboot/+/68076 Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: Tim Van Patten timvp@google.com --- M src/mainboard/google/skyrim/Kconfig M src/mainboard/google/skyrim/Kconfig.name 2 files changed, 20 insertions(+), 1 deletion(-)
Approvals: build bot (Jenkins): Verified Tim Van Patten: Looks good to me, approved
diff --git a/src/mainboard/google/skyrim/Kconfig b/src/mainboard/google/skyrim/Kconfig index 3c07db5..7466fd6 100644 --- a/src/mainboard/google/skyrim/Kconfig +++ b/src/mainboard/google/skyrim/Kconfig @@ -36,7 +36,6 @@ select MAINBOARD_HAS_CHROMEOS select MAINBOARD_HAS_TPM2 select SOC_AMD_MENDOCINO - select SOC_AMD_COMMON_BLOCK_ACPI_DPTC if !BOARD_GOOGLE_WINTERHOLD && !BOARD_GOOGLE_MORTHAL select SOC_AMD_COMMON_BLOCK_USE_ESPI select TPM_GOOGLE_TI50 select PCIEXP_ASPM diff --git a/src/mainboard/google/skyrim/Kconfig.name b/src/mainboard/google/skyrim/Kconfig.name index 3d8f0f1..f7f8d7c 100644 --- a/src/mainboard/google/skyrim/Kconfig.name +++ b/src/mainboard/google/skyrim/Kconfig.name @@ -3,10 +3,12 @@ config BOARD_GOOGLE_SKYRIM bool "-> Skyrim" select BOARD_GOOGLE_BASEBOARD_SKYRIM + select SOC_AMD_COMMON_BLOCK_ACPI_DPTC
config BOARD_GOOGLE_WINTERHOLD bool "-> Winterhold" select BOARD_GOOGLE_BASEBOARD_SKYRIM + select SOC_AMD_COMMON_BLOCK_ACPI_DPTC
config BOARD_GOOGLE_MORTHAL bool "-> Morthal"
