Patrick Georgi (pgeorgi@google.com) just uploaded a new patch set to gerrit, which you can find at http://review.coreboot.org/9409
commit c33cf447f3ed4dcc39682b47aeb19ae426e87e28 Author: huang lin hl@rock-chips.com Date: Fri Nov 7 10:56:35 2014 +0800
rk3288: don't log LAST_TSHUT bit
Since the LAST_THSUT bit is uncertain value when it cold-reboot, we remove the printout about this status bit in coreboot.
BUG=chrome-os-partner:33521 TEST=Boot on veyron_pinky rev2
Change-Id: I3b9791ffdffeff0721e3d86378db6255c5abc9ea Signed-off-by: Patrick Georgi pgeorgi@chromium.org Original-Commit-Id: 16464d3229ad1001952ef1b50fe3e606d1583462 Original-Change-Id: I258750797e32c28f86e73a01eede005e890a6906 Original-Signed-off-by: huang lin hl@rock-chips.com Original-Reviewed-on: https://chromium-review.googlesource.com/228391 Original-Reviewed-by: Julius Werner jwerner@chromium.org --- src/soc/rockchip/rk3288/tsadc.c | 6 +----- 1 file changed, 1 insertion(+), 5 deletions(-)
diff --git a/src/soc/rockchip/rk3288/tsadc.c b/src/soc/rockchip/rk3288/tsadc.c index b7d8e9d..a2d6ec4 100644 --- a/src/soc/rockchip/rk3288/tsadc.c +++ b/src/soc/rockchip/rk3288/tsadc.c @@ -88,11 +88,7 @@ void tsadc_init(void) { rkclk_configure_tsadc(TSADC_CLOCK_HZ);
- if (readl(&rk3288_tsadc->auto_con) & LAST_TSHUT) { - printk(BIOS_WARNING, "last shutdown/rebot was caused " - "by over-temperature hardware trigger!\n"); - setbits_le32(&rk3288_tsadc->auto_con, LAST_TSHUT); - } + setbits_le32(&rk3288_tsadc->auto_con, LAST_TSHUT);
setbits_le32(&rk3288_tsadc->int_en, TSHUT_CRU_EN_SRC2 | TSHUT_CRU_EN_SRC1 |
