Angel Pons has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/43195 )
Change subject: soc/intel/baytrail/lpss.c: Align with Braswell ......................................................................
This reduces the differences between Bay Trail and Braswell.
Tested with BUILD_TIMELESS=1, Google Ninja remains identical.
Change-Id: I98d17fc470149b181e8d92b8bcc5d99c68299212 Signed-off-by: Angel Pons th3fanbus@gmail.com --- M src/soc/intel/baytrail/lpss.c 1 file changed, 13 insertions(+), 13 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/95/43195/1
diff --git a/src/soc/intel/baytrail/lpss.c b/src/soc/intel/baytrail/lpss.c index cdf78b7..08c3c05 100644 --- a/src/soc/intel/baytrail/lpss.c +++ b/src/soc/intel/baytrail/lpss.c @@ -15,16 +15,15 @@
#include "chip.h"
-static void dev_enable_acpi_mode(struct device *dev, int iosf_reg, - int nvs_index) +static void dev_enable_acpi_mode(struct device *dev, int iosf_reg, int nvs_index) { struct reg_script ops[] = { /* Disable PCI interrupt, enable Memory and Bus Master */ - REG_PCI_OR16(PCI_COMMAND, - PCI_COMMAND_MEMORY | PCI_COMMAND_MASTER | (1<<10)), + REG_PCI_OR16(PCI_COMMAND, PCI_COMMAND_MEMORY | PCI_COMMAND_MASTER | (1 << 10)), /* Enable ACPI mode */ REG_IOSF_OR(IOSF_PORT_LPSS, iosf_reg, LPSS_CTL_PCI_CFG_DIS | LPSS_CTL_ACPI_INT_EN), + REG_SCRIPT_END }; struct resource *bar; @@ -63,14 +62,17 @@ reg_script_run_on_dev(dev, ops); }
+#define SET_IOSF_REG(name_) \ + case PCI_DEVFN(name_ ## _DEV, name_ ## _FUNC): \ + do { \ + *iosf_reg = LPSS_ ## name_ ## _CTL; \ + *nvs_index = LPSS_NVS_ ## name_; \ + } while (0) + static void dev_ctl_reg(struct device *dev, int *iosf_reg, int *nvs_index) { *iosf_reg = -1; *nvs_index = -1; -#define SET_IOSF_REG(name_) \ - case PCI_DEVFN(name_ ## _DEV, name_ ## _FUNC): \ - *iosf_reg = LPSS_ ## name_ ## _CTL; \ - *nvs_index = LPSS_NVS_ ## name_
switch (dev->path.pci.devfn) { SET_IOSF_REG(SIO_DMA1); @@ -104,6 +106,8 @@ } }
+#define CASE_I2C(name_) case PCI_DEVFN(name_ ## _DEV, name_ ## _FUNC) + static void i2c_disable_resets(struct device *dev) { /* Release the I2C devices from reset. */ @@ -112,9 +116,6 @@ REG_SCRIPT_END, };
-#define CASE_I2C(name_) \ - case PCI_DEVFN(name_ ## _DEV, name_ ## _FUNC) - switch (dev->path.pci.devfn) { CASE_I2C(I2C1): CASE_I2C(I2C2): @@ -141,8 +142,7 @@ if (iosf_reg < 0) { int slot = PCI_SLOT(dev->path.pci.devfn); int func = PCI_FUNC(dev->path.pci.devfn); - printk(BIOS_DEBUG, "Could not find iosf_reg for %02x.%01x\n", - slot, func); + printk(BIOS_DEBUG, "Could not find iosf_reg for %02x.%01x\n", slot, func); return; } dev_enable_snoop_and_pm(dev, iosf_reg);
build bot (Jenkins) has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/43195 )
Patch Set 1:
(2 comments)
https://review.coreboot.org/c/coreboot/+/43195/1/src/soc/intel/baytrail/lpss... File src/soc/intel/baytrail/lpss.c:
https://review.coreboot.org/c/coreboot/+/43195/1/src/soc/intel/baytrail/lpss... PS1, Line 65: #define SET_IOSF_REG(name_) \ Macros with complex values should be enclosed in parentheses
https://review.coreboot.org/c/coreboot/+/43195/1/src/soc/intel/baytrail/lpss... PS1, Line 109: #define CASE_I2C(name_) case PCI_DEVFN(name_ ## _DEV, name_ ## _FUNC) Macros with complex values should be enclosed in parentheses
Patch Set 2:
(2 comments)
https://review.coreboot.org/c/coreboot/+/43195/2/src/soc/intel/baytrail/lpss... File src/soc/intel/baytrail/lpss.c:
https://review.coreboot.org/c/coreboot/+/43195/2/src/soc/intel/baytrail/lpss... PS2, Line 65: #define SET_IOSF_REG(name_) \ Macros with complex values should be enclosed in parentheses
https://review.coreboot.org/c/coreboot/+/43195/2/src/soc/intel/baytrail/lpss... PS2, Line 109: #define CASE_I2C(name_) case PCI_DEVFN(name_ ## _DEV, name_ ## _FUNC) Macros with complex values should be enclosed in parentheses
Tim Wawrzynczak has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/43195 )
Patch Set 2:
https://review.coreboot.org/c/coreboot/+/43195/2/src/soc/intel/baytrail/lpss... PS2, Line 22: (1 << 10) how about change both to use PCI_COMMAND_INT_DISABLE ?
Angel Pons has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/43195 )
Patch Set 2:
Sounds good. I'll see if there are any other instances around.
Patch Set 2:
Handled in CB:43839
Patch Set 2: Code-Review+2
Angel Pons has submitted this change. ( https://review.coreboot.org/c/coreboot/+/43195 )
Change-Id: I98d17fc470149b181e8d92b8bcc5d99c68299212 Signed-off-by: Angel Pons th3fanbus@gmail.com Reviewed-on: https://review.coreboot.org/c/coreboot/+/43195 Reviewed-by: Tim Wawrzynczak twawrzynczak@chromium.org Tested-by: build bot (Jenkins) no-reply@coreboot.org --- M src/soc/intel/baytrail/lpss.c 1 file changed, 13 insertions(+), 13 deletions(-)
#include "chip.h"
