Subrata Banik has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/40224 )
Change subject: drivers/intel/wifi: Add support for Intel Wi-Fi 6 Series ......................................................................
Add all Intel WIFI 6 series PCI ids into device/pci_ids.h file.
TEST=HrP Wi-Fi module is getting detected during PCI enumeration.
Change-Id: Id5452c5c02b58e84d8e5768653b18c9d1246c1bb Signed-off-by: Subrata Banik subrata.banik@intel.com --- M src/drivers/intel/wifi/wifi.c M src/include/device/pci_ids.h 2 files changed, 13 insertions(+), 0 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/24/40224/1
diff --git a/src/drivers/intel/wifi/wifi.c b/src/drivers/intel/wifi/wifi.c index af7407d..c3e551a 100644 --- a/src/drivers/intel/wifi/wifi.c +++ b/src/drivers/intel/wifi/wifi.c @@ -145,6 +145,14 @@ PCI_DEVICE_ID_HrP_9560_SERIES_2_WIFI, PCI_DEVICE_ID_HrP_9560_SERIES_3_WIFI, PCI_DEVICE_ID_HrP_9560_SERIES_4_WIFI, + PCI_DEVICE_ID_HrP_6SERIES_WIFI, + /* Cyclone Peak */ + PCI_DEVICE_ID_CyP_6SERIES_WIFI, + /* Typhoon Peak */ + PCI_DEVICE_ID_TyP_6SERIES_WIFI, + /* Garfiled Peak */ + PCI_DEVICE_ID_GrP_6SERIES_1_WIFI, + PCI_DEVICE_ID_GrP_6SERIES_2_WIFI, 0 };
diff --git a/src/include/device/pci_ids.h b/src/include/device/pci_ids.h index 13004db..4898a91 100644 --- a/src/include/device/pci_ids.h +++ b/src/include/device/pci_ids.h @@ -3676,6 +3676,11 @@ #define PCI_DEVICE_ID_HrP_9560_SERIES_2_WIFI 0xa0f0 #define PCI_DEVICE_ID_HrP_9560_SERIES_3_WIFI 0x02f0 #define PCI_DEVICE_ID_HrP_9560_SERIES_4_WIFI 0x06f0 +#define PCI_DEVICE_ID_CyP_6SERIES_WIFI 0x2723 +#define PCI_DEVICE_ID_HrP_6SERIES_WIFI 0x2720 +#define PCI_DEVICE_ID_TyP_6SERIES_WIFI 0x2725 +#define PCI_DEVICE_ID_GrP_6SERIES_1_WIFI 0x51f0 +#define PCI_DEVICE_ID_GrP_6SERIES_2_WIFI 0x7af0
#define PCI_VENDOR_ID_COMPUTONE 0x8e0e #define PCI_DEVICE_ID_COMPUTONE_IP2EX 0x0291
Paul Menzel has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/40224 )
Patch Set 1: Code-Review+1
(2 comments)
https://review.coreboot.org/c/coreboot/+/40224/1//COMMIT_MSG Commit Message:
https://review.coreboot.org/c/coreboot/+/40224/1//COMMIT_MSG@9 PS1, Line 9: into to
https://review.coreboot.org/c/coreboot/+/40224/1//COMMIT_MSG@11 PS1, Line 11: HrP What is HrP?
Hello build bot (Jenkins), Furquan Shaikh, Paul Menzel, Duncan Laurie, Aaron Durbin, Patrick Rudolph,
Add all Intel WIFI 6 series PCI ids to device/pci_ids.h file.
TEST=Harrison Peak (HrP) Wi-Fi module is getting detected during PCI enumeration.
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/24/40224/2
Subrata Banik has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/40224 )
Patch Set 2:
(2 comments)
to
Ack
What is HrP?
Ack
Duncan Laurie has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/40224 )
Patch Set 2: Code-Review+2
Angel Pons has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/40224 )
Subrata Banik has submitted this change. ( https://review.coreboot.org/c/coreboot/+/40224 )
Change-Id: Id5452c5c02b58e84d8e5768653b18c9d1246c1bb Signed-off-by: Subrata Banik subrata.banik@intel.com Reviewed-on: https://review.coreboot.org/c/coreboot/+/40224 Reviewed-by: Duncan Laurie dlaurie@chromium.org Reviewed-by: Angel Pons th3fanbus@gmail.com Reviewed-by: Paul Menzel paulepanter@users.sourceforge.net Tested-by: build bot (Jenkins) no-reply@coreboot.org --- M src/drivers/intel/wifi/wifi.c M src/include/device/pci_ids.h 2 files changed, 13 insertions(+), 0 deletions(-)
Approvals: build bot (Jenkins): Verified Duncan Laurie: Looks good to me, approved Paul Menzel: Looks good to me, but someone else must approve Angel Pons: Looks good to me, approved
9elements QA has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/40224 )
Patch Set 3:
Automatic boot test returned (PASS/FAIL/TOTAL): 3/0/3 Emulation targets: EMULATION_QEMU_X86_Q35 using payload TianoCore : SUCCESS : https://lava.9esec.io/r/2170 EMULATION_QEMU_X86_Q35 using payload SeaBIOS : SUCCESS : https://lava.9esec.io/r/2169 EMULATION_QEMU_X86_I440FX using payload SeaBIOS : SUCCESS : https://lava.9esec.io/r/2168
