Hello Arthur Heymans,
https://review.coreboot.org/c/libgfxinit/+/35784
Change subject: gma ilk hdmi: Add workaround for enable-bit quirk ......................................................................
The HDMI-enable bit is quirky, too. We are supposed to always set it twice.
Change-Id: I9d093ff9a3178e01638f65b0607bc8d08c009978 Signed-off-by: Nico Huber nico.h@gmx.de --- M common/ironlake/hw-gfx-gma-pch-hdmi.adb 1 file changed, 7 insertions(+), 0 deletions(-)
git pull ssh://review.coreboot.org:29418/libgfxinit refs/changes/84/35784/1
diff --git a/common/ironlake/hw-gfx-gma-pch-hdmi.adb b/common/ironlake/hw-gfx-gma-pch-hdmi.adb index 4ca9ecd..7210a95 100644 --- a/common/ironlake/hw-gfx-gma-pch-hdmi.adb +++ b/common/ironlake/hw-gfx-gma-pch-hdmi.adb @@ -66,6 +66,10 @@ PCH_TRANSCODER_SELECT (FDI_Port) or PCH_HDMI_SDVO_ENCODING_HDMI or Polarity); + Registers.Posting_Read (PCH_HDMI (Port_Cfg.PCH_Port)); + -- Set enable a second time, hardware may miss the first. + Registers.Set_Mask (PCH_HDMI (Port_Cfg.PCH_Port), PCH_HDMI_ENABLE); + Registers.Posting_Read (PCH_HDMI (Port_Cfg.PCH_Port)); end On;
---------------------------------------------------------------------------- @@ -97,6 +101,9 @@ -- Reenable with transcoder A selected to switch. Registers.Set_Mask (PCH_HDMI (Port), PCH_HDMI_ENABLE); Registers.Posting_Read (PCH_HDMI (Port)); + -- Set enable a second time, hardware may miss the first. + Registers.Set_Mask (PCH_HDMI (Port), PCH_HDMI_ENABLE); + Registers.Posting_Read (PCH_HDMI (Port)); Registers.Unset_Mask (PCH_HDMI (Port), PCH_HDMI_ENABLE); Registers.Posting_Read (PCH_HDMI (Port)); end if;
Arthur Heymans has posted comments on this change. ( https://review.coreboot.org/c/libgfxinit/+/35784 )
Patch Set 1: Code-Review+2
Checked in Linux.
Nico Huber has submitted this change. ( https://review.coreboot.org/c/libgfxinit/+/35784 )
Change-Id: I9d093ff9a3178e01638f65b0607bc8d08c009978 Signed-off-by: Nico Huber nico.h@gmx.de Reviewed-on: https://review.coreboot.org/c/libgfxinit/+/35784 Reviewed-by: Arthur Heymans arthur@aheymans.xyz --- M common/ironlake/hw-gfx-gma-pch-hdmi.adb 1 file changed, 7 insertions(+), 0 deletions(-)
Approvals: Nico Huber: Verified Arthur Heymans: Looks good to me, approved
diff --git a/common/ironlake/hw-gfx-gma-pch-hdmi.adb b/common/ironlake/hw-gfx-gma-pch-hdmi.adb index 9426a86..15d4e9f 100644 --- a/common/ironlake/hw-gfx-gma-pch-hdmi.adb +++ b/common/ironlake/hw-gfx-gma-pch-hdmi.adb @@ -66,6 +66,10 @@ PCH_TRANSCODER_SELECT (FDI_Port) or PCH_HDMI_SDVO_ENCODING_HDMI or Polarity); + Registers.Posting_Read (PCH_HDMI (Port_Cfg.PCH_Port)); + -- Set enable a second time, hardware may miss the first. + Registers.Set_Mask (PCH_HDMI (Port_Cfg.PCH_Port), PCH_HDMI_ENABLE); + Registers.Posting_Read (PCH_HDMI (Port_Cfg.PCH_Port)); end On;
