Subrata Banik has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/45795 )
Change subject: soc/intel/skylake: Align PMC offset 0x31C name with CNL ......................................................................
As per EDS PMC BASE Offset 0x31C is known as CPPMVRIC hence rename CIR31C with CPPMVRIC.
Change-Id: Idaff62fb742e6c58b1d8e662b5e4087fa2da79a3 Signed-off-by: Subrata Banik subrata.banik@intel.com --- M src/soc/intel/skylake/finalize.c M src/soc/intel/skylake/include/soc/pmc.h 2 files changed, 3 insertions(+), 3 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/95/45795/1
diff --git a/src/soc/intel/skylake/finalize.c b/src/soc/intel/skylake/finalize.c index 98f12a5..0294a72 100644 --- a/src/soc/intel/skylake/finalize.c +++ b/src/soc/intel/skylake/finalize.c @@ -81,9 +81,9 @@
/* Disable XTAL shutdown qualification for low power idle. */ if (config->s0ix_enable) { - reg32 = read32(pmcbase + CIR31C); + reg32 = read32(pmcbase + CPPMVRIC); reg32 |= XTALSDQDIS; - write32(pmcbase + CIR31C, reg32); + write32(pmcbase + CPPMVRIC, reg32); }
/* we should disable Heci1 based on the devicetree policy */ diff --git a/src/soc/intel/skylake/include/soc/pmc.h b/src/soc/intel/skylake/include/soc/pmc.h index f4995a2..68d9eb3 100644 --- a/src/soc/intel/skylake/include/soc/pmc.h +++ b/src/soc/intel/skylake/include/soc/pmc.h @@ -82,6 +82,6 @@ #define GPE0_DW_SHIFT(x) (4*(x)) #define GBLRST_CAUSE0 0x124 #define GBLRST_CAUSE1 0x128 -#define CIR31C 0x31c +#define CPPMVRIC 0x31c #define XTALSDQDIS (1 << 22) #endif
Angel Pons has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/45795 )
Patch Set 2: Code-Review+2
Tim Wawrzynczak has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/45795 )
Patch Set 3: Code-Review+2
https://review.coreboot.org/c/coreboot/+/45795/3//COMMIT_MSG Commit Message:
https://review.coreboot.org/c/coreboot/+/45795/3//COMMIT_MSG@10 PS3, Line 10: rename CIR31C with CPPMVRIC. nit: you can fit more on the previous line.
Hello build bot (Jenkins), Furquan Shaikh, Tim Wawrzynczak, Angel Pons, Patrick Rudolph,
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/95/45795/4
Subrata Banik has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/45795 )
Patch Set 4:
done
Subrata Banik has submitted this change. ( https://review.coreboot.org/c/coreboot/+/45795 )
Change-Id: Idaff62fb742e6c58b1d8e662b5e4087fa2da79a3 Signed-off-by: Subrata Banik subrata.banik@intel.com Reviewed-on: https://review.coreboot.org/c/coreboot/+/45795 Reviewed-by: Tim Wawrzynczak twawrzynczak@chromium.org Reviewed-by: Angel Pons th3fanbus@gmail.com Tested-by: build bot (Jenkins) no-reply@coreboot.org --- M src/soc/intel/skylake/finalize.c M src/soc/intel/skylake/include/soc/pmc.h 2 files changed, 3 insertions(+), 3 deletions(-)
Approvals: build bot (Jenkins): Verified Angel Pons: Looks good to me, approved Tim Wawrzynczak: Looks good to me, approved
