Hello Felix Singer, build bot (Jenkins), Matt Delco, Nico Huber, Furquan Shaikh, Paul Menzel, Tim Wawrzynczak, Subrata Banik, Andrey Petrov, Patrick Rudolph,
https://review.coreboot.org/c/coreboot/+/47542
Change subject: [UNTESTED] soc/intel/apl: enable ACPI CPPC entries ......................................................................
Enable CPPC entries generation, needed for Intel SpeedShift.
This can be tested by checking sysfs in Linux: $ grep . /sys/devices/system/cpu/cpu?/acpi_cppc/*perf
The output should look like this, while the values may differ:
/sys/devices/system/cpu/cpu0/acpi_cppc/highest_perf:28 /sys/devices/system/cpu/cpu0/acpi_cppc/lowest_nonlinear_perf:5 /sys/devices/system/cpu/cpu0/acpi_cppc/lowest_perf:1 /sys/devices/system/cpu/cpu0/acpi_cppc/nominal_perf:24 /sys/devices/system/cpu/cpu1/acpi_cppc/highest_perf:28 /sys/devices/system/cpu/cpu1/acpi_cppc/lowest_nonlinear_perf:5 ...
Change-Id: Ic94d95413d2f7f6743507824d47d5afd9fdfbbb9 Signed-off-by: Michael Niewöhner foss@mniewoehner.de --- M src/soc/intel/apollolake/Kconfig 1 file changed, 1 insertion(+), 0 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/42/47542/8
