Patrick Georgi (pgeorgi@google.com) just uploaded a new patch set to gerrit, which you can find at http://review.coreboot.org/11039
commit e92b69e151717fc148b58f2b8e773a84d6bf331b Author: Yen Lin yelin@nvidia.com Date: Wed May 6 18:08:22 2015 -0700
t210: implement MBIST workaround
MBIST has left some registers in non-suggested states. This CL restores CAR CE's, SLCG overrides & PLLD settings.
BUG=None BRANCH=None TEST=tested on Smaug, still boot to kernel
Change-Id: I1ddb19dd9fb6d8fb4d36e67eedeb847c6fd9f774 Signed-off-by: Patrick Georgi pgeorgi@chromium.org Original-Commit-Id: 37a1c90c6deb351b2ae2caa03e5076553126744b Original-Change-Id: I613b4ef622d64305d436cb8379a5170b0fe1c9af Original-Signed-off-by: Yen Lin yelin@nvidia.com Original-Reviewed-on: https://chromium-review.googlesource.com/282417 Original-Reviewed-by: Tom Warren twarren@nvidia.com Original-Reviewed-by: Furquan Shaikh furquan@chromium.org --- src/soc/nvidia/tegra210/bootblock.c | 104 ++++++++++++++++++++++++++++++++++++ 1 file changed, 104 insertions(+)
diff --git a/src/soc/nvidia/tegra210/bootblock.c b/src/soc/nvidia/tegra210/bootblock.c index a6aa584..0469320 100644 --- a/src/soc/nvidia/tegra210/bootblock.c +++ b/src/soc/nvidia/tegra210/bootblock.c @@ -22,6 +22,7 @@ #include <arch/stages.h> #include <bootblock_common.h> #include <console/console.h> +#include <delay.h> #include <program_loading.h> #include <soc/addressmap.h> #include <soc/clock.h> @@ -58,11 +59,113 @@ void __attribute__((weak)) bootblock_mainboard_early_init(void) /* Empty default implementation. */ }
+/* + * Define operations for the workaround: + * OP_SET : [reg] = val; + * OP_OR : [reg] |= val; + * OP_AND : [reg] &= val; + * OP_UDELAY : udelay(val); + */ +typedef enum { + OP_SET, + OP_OR, + OP_AND, + OP_UDELAY, /* use val field as usec delay */ +} WAR_OP; + +struct workaround_op { + WAR_OP op; + u32 reg; + u32 val; +}; + +/* + * An array defines the sequence to perform the workaround + */ +static struct workaround_op workaround_sequence[] = { + {OP_OR, 0x60006410, (1 << 15)}, /* CLK_SOURCE_SOR1: */ + {OP_AND, 0x60006410, ~(1 << 14)}, /* CLK_SEL1=1, CLK_SEL0=0 */ + {OP_OR, 0x600060d0, 0x40800000}, /* PLLD_BASE */ + {OP_SET, 0x600062ac, 0x40}, /* clear APE reset */ + {OP_SET, 0x60006294, 0x40000}, /* clear VIC reset */ + {OP_SET, 0x60006304, 0x18000000}, /* clear HOST1X & DISP1 reset */ + {OP_UDELAY, 0, 2}, + {OP_OR, 0x702d10a0, 0x400}, /* I2S0: I2S_CTRL.MASTER=1 */ + {OP_AND, 0x702d1088, ~1}, /* I2S0: I2S_CG.SLCG_ENABLE=0 */ + {OP_OR, 0x702d11a0, 0x400}, /* I2S1: I2S_CTRL.MASTER=1 */ + {OP_AND, 0x702d1188, ~1}, /* I2S1: I2S_CG.SLCG_ENABLE=0 */ + {OP_OR, 0x702d12a0, 0x400}, /* I2S2: I2S_CTRL.MASTER=1 */ + {OP_AND, 0x702d1288, ~1}, /* I2S2: I2S_CG.SLCG_ENABLE=0 */ + {OP_OR, 0x702d13a0, 0x400}, /* I2S3: I2S_CTRL.MASTER=1 */ + {OP_AND, 0x702d1388, ~1}, /* I2S3: I2S_CG.SLCG_ENABLE=0 */ + {OP_OR, 0x702d14a0, 0x400}, /* I2S4: I2S_CTRL.MASTER=1 */ + {OP_AND, 0x702d1488, ~1}, /* I2S4: I2S_CG.SLCG_ENABLE=0 */ + {OP_OR, 0x54200cf8, 4}, /* DC_COM_DSC_TOP_CTL[DSC_SLCG_OVERRIDE]=1 */ + {OP_SET, 0x543400c8, 0xffffffff}, /* NV_PVIC_THI_SLCG_OVERRIDE_LOW_A = 0xFFFF_FFFF */ + {OP_UDELAY, 0, 2}, + {OP_SET, 0x600062a8, 0x40}, /* set APE reset */ + {OP_SET, 0x60006300, 0x18000000}, /* set HOST1X & DISP1 reset */ + {OP_SET, 0x60006290, 0x40000}, /* set VIC reset */ + {OP_SET, 0x60006014, 0x020000c1}, /* CLK_ENB_H */ + {OP_SET, 0x60006010, 0x80400130}, /* CLK_ENB_L */ + {OP_SET, 0x60006018, 0x01f00200}, /* CLK_ENB_U */ + {OP_SET, 0x60006360, 0x80400808}, /* CLK_ENB_V */ + {OP_SET, 0x60006364, 0x402000fc}, /* CLK_ENB_W */ + {OP_SET, 0x60006280, 0x23000780}, /* CLK_ENB_X */ + {OP_SET, 0x60006298, 0x00000340}, /* CLK_ENB_Y */ + {OP_SET, 0x600060f8, 0x00000000}, /* LVL2_CLK_GATE_OVRA */ + {OP_SET, 0x600060fc, 0x00000000}, /* LVL2_CLK_GATE_OVRB */ + {OP_SET, 0x600063a0, 0x00000000}, /* LVL2_CLK_GATE_OVRC */ + {OP_SET, 0x600063a4, 0x01000000}, /* LVL2_CLK_GATE_OVRD, QSPI_CLK_OVR_ON=1 */ + {OP_SET, 0x60006554, 0x00000000}, /* LVL2_CLK_GATE_OVRE */ + {OP_AND, 0x600060d0, 0x1f7fffff}, /* PLLD_BASE: 31,30,29,23 = 0 */ + {OP_AND, 0x60006410, 0xffff3fff}, /* CLK_SOURCE_SOR1 15,14 = 0 */ + {OP_AND, 0x60006148, ~(7 << 29)}, /* CLK_SOURCE_VI: */ + {OP_OR, 0x60006148, (4 << 29)}, /* SRC=PLLP_OUT0 (4) */ + {OP_AND, 0x60006180, ~(7 << 29)}, /* CLK_SOURCE_HOST1X: */ + {OP_OR, 0x60006180, (4 << 29)}, /* SRC=PLLP_OUT0 (4) */ + {OP_AND, 0x600066a0, ~(7 << 29)}, /* CLK_SOURCE_NVENC: */ + {OP_OR, 0x600066a0, (4 << 29)} /* SRC=PLLP_OUT0 (4) */ +}; + +/* + * This workaround is to restore CAR CE's, SLCG overrides & PLLD settings + */ +static void mbist_workaround(void) +{ + int i; + u32 val; + struct workaround_op *wa_op; + + for (i = 0; i < ARRAY_SIZE(workaround_sequence); ++i) { + wa_op = &workaround_sequence[i]; + switch (wa_op->op) { + case OP_SET: + val = wa_op->val; + break; + case OP_OR: + val = read32((void *)wa_op->reg) | wa_op->val; + break; + case OP_AND: + val = read32((void *)wa_op->reg) & wa_op->val; + break; + case OP_UDELAY: + udelay(wa_op->val); + /* fall thru */ + default: + continue; + } + write32((void *)wa_op->reg, val); + } +} + void main(void) { // enable JTAG at the earliest stage enable_jtag();
+ mbist_workaround(); + clock_early_uart();
/* Configure mselect clock. */ @@ -90,6 +193,7 @@ void main(void)
pmc_print_rst_status();
+ bootblock_mainboard_init();
printk(BIOS_INFO, "T210 bootblock: Mainboard bootblock init done\n");
