Attention is currently required from: Michał Żygowski, Piotr Król. Hello build bot (Jenkins), Michał Żygowski, Piotr Król,
https://review.coreboot.org/c/coreboot/+/56836
Change subject: mb/pcengines/apu2: add and use IOMUX defines ......................................................................
Add GPIO IOMUX defines for the pins that are used in the mainboard code which enables using the PAD_GPI and PAD_GPO macros.
TEST=Timeless build for APU2/3/4/5 results in identical binary.
Signed-off-by: Felix Held felix-coreboot@felixheld.de Change-Id: Ie32df9ed2cb6a5670a29cff91e085a3585c8bcf7 --- M src/mainboard/pcengines/apu2/gpio_ftns.h M src/mainboard/pcengines/apu2/romstage.c 2 files changed, 30 insertions(+), 24 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/36/56836/2
