Attention is currently required from: Hung-Te Lin, Knox Chiou, Paul Menzel, Xinxiong Xu, Yang Wu, Yidi Lin.
Yu-Ping Wu has posted comments on this change by Yang Wu. ( https://review.coreboot.org/c/coreboot/+/84342?usp=email )
Change subject: mb/google/corsola: Distinguish MT8186T's SKU ID from MT8186 ......................................................................
Patch Set 8:
(3 comments)
File src/mainboard/google/corsola/boardid.c:
https://review.coreboot.org/c/coreboot/+/84342/comment/291a24a0_7686c458?usp... : PS6, Line 118: if (cached_sku_code == CROS_SKU_UNPROVISIONED || : cached_sku_code == CROS_SKU_UNKNOWN) { : printk(BIOS_WARNING, "SKU code from EC: 0x%x\n", cached_sku_code); : : if (CONFIG(BOARD_GOOGLE_STARYU_COMMON)) { : if (get_cpu_id() == MTK_CPU_ID_MT8186T) { : /* Reserve last 4 bits to report PANEL_ID */ : cached_sku_code = 0x7FFFFEF0UL | panel_id(); : } else { : cached_sku_code = 0x7FFFFFF0UL | panel_id(); : } : } else if (get_cpu_id() == MTK_CPU_ID_MT8186T && : !CONFIG(BOARD_GOOGLE_VOLTORB) && : !CONFIG(BOARD_GOOGLE_SQUIRTLE)) { : /* : * Distinguish MT8186T from MT8186 to select different device trees : * in the payload. Voltorb/Squirtle are exception here, because right now : * they use 0x7FFFFFFF in the DTS compatible string. We'll need to change : * that to 0x7FFFFEFF in kernel before the exception can be dropped. : */ : cached_sku_code = CROS_SKU_UNPROVISIONED_MT8186T; : } : }
or […]
That also works. Given that we've decided to drop the exception for voltorb and squirtle here, I think PS8 looks clean enough.
https://review.coreboot.org/c/coreboot/+/84342/comment/fde96ee4_42af43b9?usp... : PS8, Line 119: cached_sku_code Align with `cached_sku_code` above.
https://review.coreboot.org/c/coreboot/+/84342/comment/09ce8001_61a55284?usp... : PS8, Line 125: if (CONFIG(BOARD_GOOGLE_STARYU_COMMON)) { Keep the `/* Reserve last 4 bits to report PANEL_ID */` comment.
