Paul Menzel (paulepanter@users.sourceforge.net) just uploaded a new patch set to gerrit, which you can find at https://review.coreboot.org/17644
commit cc9395d6cc9985e8183a3ae3cb3bdb4f6876b267 Author: Paul Menzel paulepanter@users.sourceforge.net Date: Tue Nov 29 21:02:04 2016 +0100
lib/edid.c: Remove trailing space from detailed mode output
When the bit for interlaced mode is not set, a trailing space is added to the end.
As the space is already accounted for in `" interlaced"`, remove that space.
TEST=Boot on Lenovo X60t, and verify the trailing space in the detailed mode is gone.
Change-Id: I4114c9e61a040fa005c806404ec51c12e2f02f4d Signed-off-by: Paul Menzel paulepanter@users.sourceforge.net --- src/lib/edid.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/src/lib/edid.c b/src/lib/edid.c index 23b6503..edc2af1 100644 --- a/src/lib/edid.c +++ b/src/lib/edid.c @@ -585,7 +585,7 @@ detailed_block(struct edid *result_edid, unsigned char *x, int in_extension, "Detailed mode (IN HEX): Clock %d KHz, %x mm x %x mm\n" " %04x %04x %04x %04x hborder %x\n" " %04x %04x %04x %04x vborder %x\n" - " %chsync %cvsync%s%s %s\n", out->mode.pixel_clock, + " %chsync %cvsync%s%s%s\n", out->mode.pixel_clock, extra_info.x_mm, extra_info.y_mm, out->mode.ha, out->mode.ha + out->mode.hso, out->mode.ha + out->mode.hso + out->mode.hspw,
