Vaibhav Shankar (vaibhav.shankar@intel.com) just uploaded a new patch set to gerrit, which you can find at https://review.coreboot.org/18251
commit 444de9b452a6e4d6a32e362f3d3f4daa1e6def8f Author: Vaibhav Shankar vaibhav.shankar@intel.com Date: Fri Jan 27 11:37:30 2017 -0800
mainboard/google/reef: Set IOSSTATE for trackpad I2C GPIOs
I2C data (GPIO_132) and Clk (GPIO_133) lines are pulled low during standby states S3/S0ix. This causes leakage of power. To reduce the leakage, we have to pull these lines high during S3/S0ix. This is done by programming the IOSSTATE to HIz. Also note that we are using the internal pull ups to keep at SOC at 1.8V and the I2C lines are not floating.
BUG=chrome-os-partner:62428 TEST=Enter S3/S0ix. Measure trackpad power. It should be less than 4mW. Also I2c lines should be pulled high in S3/S0ix.
Change-Id: I5570ac37ec3cc41f6463dd6b858fdb56a20a1733 Signed-off-by: Vaibhav Shankar vaibhav.shankar@intel.com --- src/mainboard/google/reef/variants/baseboard/gpio.c | 6 ++++-- 1 file changed, 4 insertions(+), 2 deletions(-)
diff --git a/src/mainboard/google/reef/variants/baseboard/gpio.c b/src/mainboard/google/reef/variants/baseboard/gpio.c index 390ef0f..3bb9a5f 100644 --- a/src/mainboard/google/reef/variants/baseboard/gpio.c +++ b/src/mainboard/google/reef/variants/baseboard/gpio.c @@ -101,8 +101,10 @@ static const struct pad_config gpio_table[] = { PAD_CFG_NF(GPIO_131, UP_2K, DEEP, NF1), /* LPSS_I2C3_SCL */
/* I2C4 - trackpad */ - PAD_CFG_NF(GPIO_132, UP_2K, DEEP, NF1), /* LPSS_I2C4_SDA */ - PAD_CFG_NF(GPIO_133, UP_2K, DEEP, NF1), /* LPSS_I2C4_SCL */ + /* LPSS_I2C4_SDA */ + PAD_CFG_NF_IOSSTATE(GPIO_132, UP_2K, DEEP, NF1, HIZCRx1), + /* LPSS_I2C4_SCL */ + PAD_CFG_NF_IOSSTATE(GPIO_133, UP_2K, DEEP, NF1, HIZCRx1),
/* I2C5 -- pen with external pulls */ PAD_CFG_NF(GPIO_134, NONE, DEEP, NF1), /* LPSS_I2C5_SDA */
