Stefan Reinauer (stefan.reinauer@coreboot.org) just uploaded a new patch set to gerrit, which you can find at http://review.coreboot.org/9495
commit 83dccf2e9343283f7df9077534988a207a9275f8 Author: Duncan Laurie dlaurie@chromium.org Date: Sun Jan 18 14:06:42 2015 -0800
broadwell: Preserve VbNv around cmos_init
To ensure that boot flags (legacy, usb, signed-only) are properly restored from CMOS and used in the first boot after a battery removal or RTC reset then the VbNv region needs to be preserved around the cmos_init call.
When using vboot firmware selection and VbNv is stored in CMOS then that region of CMOS will have been re-initialized by the time we call cmos_init and reset CMOS if the chipset flag was set indicating a problem.
BUG=chrome-os-partner:35240 BRANCH=broadwell TEST=manual testing on samus: 1) boot in dev mode, enable dev_boot_legacy and ensure it works 2) on EC console pulse PCH_RTCRST_L low for a second 3) ensure first boot after RTC reset will still boot legacy mode 4) remove battery for a time 5) ensure first boot after battery is re-inserted will still boot legacy mode
Change-Id: Ica256bbdcba6d4616957ff38e63914dd15f645c6 Signed-off-by: Stefan Reinauer reinauer@chromium.org Original-Commit-Id: 881c7841c95dec392a66eef38a7112c1f385fdfa Original-Change-Id: I4c33f183ba4b301d68ae31c41fc6663f3be857b0 Original-Signed-off-by: Duncan Laurie dlaurie@chromium.org Original-Reviewed-on: https://chromium-review.googlesource.com/241529 Original-Reviewed-by: Aaron Durbin adurbin@chromium.org --- src/soc/intel/broadwell/lpc.c | 27 +++++++++++++++++++++++++++ 1 file changed, 27 insertions(+)
diff --git a/src/soc/intel/broadwell/lpc.c b/src/soc/intel/broadwell/lpc.c index 6ebc758..9a4c65c 100644 --- a/src/soc/intel/broadwell/lpc.c +++ b/src/soc/intel/broadwell/lpc.c @@ -49,6 +49,10 @@ #include <arch/acpigen.h> #include <cpu/cpu.h>
+#if IS_ENABLED(CONFIG_CHROMEOS) +#include <vendorcode/google/chromeos/chromeos.h> +#endif + static void pch_enable_ioapic(struct device *dev) { u32 reg32; @@ -174,6 +178,25 @@ static void pch_power_options(device_t dev) enable_alt_smi(config->alt_gp_smi_en); }
+#if IS_ENABLED(CONFIG_CHROMEOS_VBNV_CMOS) +/* + * Preserve Vboot NV data when clearing CMOS as it will + * have been re-initialized already by Vboot firmware init. + */ +static void pch_cmos_init_preserve(int reset) +{ + uint8_t vbnv[CONFIG_VBNV_SIZE]; + + if (reset) + read_vbnv(vbnv); + + cmos_init(reset); + + if (reset) + save_vbnv(vbnv); +} +#endif + static void pch_rtc_init(struct device *dev) { u8 reg8; @@ -187,7 +210,11 @@ static void pch_rtc_init(struct device *dev) printk(BIOS_DEBUG, "rtc_failed = 0x%x\n", rtc_failed); }
+#if IS_ENABLED(CONFIG_CHROMEOS_VBNV_CMOS) + pch_cmos_init_preserve(rtc_failed); +#else cmos_init(rtc_failed); +#endif }
static const struct reg_script pch_misc_init_script[] = {
