Felix Held has submitted this change. ( https://review.coreboot.org/c/coreboot/+/61079 )
Change subject: mb/amd/chausie: add mainboard as copy of mb/amd/majolica ......................................................................
To have the new AMD Sabrina SoC code tested, add the AMD Chausie mainboard as a copy of Majolica. This patch also changes the name from Majolica to Chausie, selects the Sabrina SoC instead of the Cezanne SoC and comments out the APCB_SOURCES since those aren't available in the 3rdparty/blobs repository yet.
Signed-off-by: Felix Held felix-coreboot@felixheld.de Change-Id: Ic7b18f7a6ae5b8365234dd1227e0b1f7f37279da Reviewed-on: https://review.coreboot.org/c/coreboot/+/61079 Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: Marshall Dawson marshalldawson3rd@gmail.com --- A src/mainboard/amd/chausie/Kconfig A src/mainboard/amd/chausie/Kconfig.name A src/mainboard/amd/chausie/Makefile.inc A src/mainboard/amd/chausie/board.fmd A src/mainboard/amd/chausie/board_info.txt A src/mainboard/amd/chausie/bootblock.c A src/mainboard/amd/chausie/chromeos.c A src/mainboard/amd/chausie/chromeos.fmd A src/mainboard/amd/chausie/devicetree.cb A src/mainboard/amd/chausie/dsdt.asl A src/mainboard/amd/chausie/early_gpio.c A src/mainboard/amd/chausie/gpio.h A src/mainboard/amd/chausie/mainboard.c A src/mainboard/amd/chausie/port_descriptors.c 14 files changed, 550 insertions(+), 0 deletions(-)
Approvals: build bot (Jenkins): Verified Marshall Dawson: Looks good to me, approved
diff --git a/src/mainboard/amd/chausie/Kconfig b/src/mainboard/amd/chausie/Kconfig new file mode 100644 index 0000000..dc6e090 --- /dev/null +++ b/src/mainboard/amd/chausie/Kconfig @@ -0,0 +1,77 @@ +# SPDX-License-Identifier: GPL-2.0-only + +if BOARD_AMD_CHAUSIE + +config BOARD_SPECIFIC_OPTIONS + def_bool y + select BOARD_ROMSIZE_KB_16384 + select HAVE_ACPI_RESUME + select SOC_AMD_SABRINA + select SOC_AMD_COMMON_BLOCK_USE_ESPI + select AMD_SOC_CONSOLE_UART + select MAINBOARD_HAS_CHROMEOS + +config FMDFILE + default "src/mainboard/amd/chausie/chromeos.fmd" if CHROMEOS + default "src/mainboard/amd/chausie/board.fmd" + +config MAINBOARD_DIR + default "amd/chausie" + +config MAINBOARD_PART_NUMBER + default "CHAUSIE" + +config AMD_FWM_POSITION_INDEX + int + default 3 if CHROMEOS + default 4 + help + TODO: might need to be adapted for better placement of files in cbfs + +config CHAUSIE_HAVE_MCHP_FW + bool "Have Microchip EC firmware?" + default n + +config CHAUSIE_MCHP_FW_FILE + string + depends on CHAUSIE_HAVE_MCHP_FW + default "3rdparty/blobs/mainboard/amd/chausie/EC_chausie.bin" + help + The EC firmware blob is usually the first 128kByte of the stock + firmware image. + +config VBOOT + select VBOOT_NO_BOARD_SUPPORT + select VBOOT_SEPARATE_VERSTAGE + select VBOOT_STARTS_IN_BOOTBLOCK + +config VBOOT_VBNV_OFFSET + hex + default 0x2A + +config CHROMEOS + # Use default libpayload config + select LP_DEFCONFIG_OVERRIDE if PAYLOAD_DEPTHCHARGE + +if !EM100 # EM100 defaults in soc/amd/common/blocks/spi/Kconfig +config EFS_SPI_READ_MODE + default 3 # Quad IO (1-1-4) + +config EFS_SPI_SPEED + default 0 # 66MHz + +config EFS_SPI_MICRON_FLAG + default 0 + +config NORMAL_READ_SPI_SPEED + default 1 # 33MHz + +config ALT_SPI_SPEED + default 1 # 33MHz + +config TPM_SPI_SPEED + default 1 # 33MHz + +endif # !EM100 + +endif # BOARD_AMD_CHAUSIE diff --git a/src/mainboard/amd/chausie/Kconfig.name b/src/mainboard/amd/chausie/Kconfig.name new file mode 100644 index 0000000..d9d8d40 --- /dev/null +++ b/src/mainboard/amd/chausie/Kconfig.name @@ -0,0 +1,2 @@ +config BOARD_AMD_CHAUSIE + bool "Chausie" diff --git a/src/mainboard/amd/chausie/Makefile.inc b/src/mainboard/amd/chausie/Makefile.inc new file mode 100644 index 0000000..bb74270 --- /dev/null +++ b/src/mainboard/amd/chausie/Makefile.inc @@ -0,0 +1,26 @@ +# SPDX-License-Identifier: GPL-2.0-only + +bootblock-y += bootblock.c +bootblock-y += early_gpio.c + +romstage-y += port_descriptors.c + +ramstage-y += chromeos.c + +#TODO: add APCB binaries +#APCB_SOURCES = $(MAINBOARD_BLOBS_DIR)/APCB_CZN_D4.bin +#APCB_SOURCES_RECOVERY = $(MAINBOARD_BLOBS_DIR)/APCB_CZN_D4_DefaultRecovery.bin + +ifeq ($(CONFIG_CHAUSIE_HAVE_MCHP_FW),y) +$(call add_intermediate, add_mchp_fw) + $(CBFSTOOL) $(obj)/coreboot.pre write -r EC -f $(CONFIG_CHAUSIE_MCHP_FW_FILE) --fill-upward +else +files_added:: warn_no_mchp +endif # CONFIG_CHAUSIE_HAVE_MCHP_FW + +PHONY+=warn_no_mchp +warn_no_mchp: + printf "\n\t** WARNING **\n" + printf "coreboot has been built without the Microchip EC FW.\n" + printf "Do not flash this image. Your Chausie's power button\n" + printf "will not respond when you press it.\n\n" diff --git a/src/mainboard/amd/chausie/board.fmd b/src/mainboard/amd/chausie/board.fmd new file mode 100644 index 0000000..442d80f --- /dev/null +++ b/src/mainboard/amd/chausie/board.fmd @@ -0,0 +1,8 @@ +FLASH@0xFF000000 16M { + BIOS { + EC 128K + RW_MRC_CACHE 64K + FMAP 4K + COREBOOT(CBFS) + } +} diff --git a/src/mainboard/amd/chausie/board_info.txt b/src/mainboard/amd/chausie/board_info.txt new file mode 100644 index 0000000..b351b8e --- /dev/null +++ b/src/mainboard/amd/chausie/board_info.txt @@ -0,0 +1 @@ +Category: eval diff --git a/src/mainboard/amd/chausie/bootblock.c b/src/mainboard/amd/chausie/bootblock.c new file mode 100644 index 0000000..f768f3f --- /dev/null +++ b/src/mainboard/amd/chausie/bootblock.c @@ -0,0 +1,9 @@ +/* SPDX-License-Identifier: GPL-2.0-only */ + +#include <bootblock_common.h> +#include "gpio.h" + +void bootblock_mainboard_early_init(void) +{ + mainboard_program_early_gpios(); +} diff --git a/src/mainboard/amd/chausie/chromeos.c b/src/mainboard/amd/chausie/chromeos.c new file mode 100644 index 0000000..062fdad --- /dev/null +++ b/src/mainboard/amd/chausie/chromeos.c @@ -0,0 +1,28 @@ +/* SPDX-License-Identifier: GPL-2.0-or-later */ + +#include <bootmode.h> +#include <boot/coreboot_tables.h> +#include <gpio.h> +#include <types.h> +#include <vendorcode/google/chromeos/chromeos.h> + +void fill_lb_gpios(struct lb_gpios *gpios) +{ + struct lb_gpio chromeos_gpios[] = {}; + lb_add_gpios(gpios, chromeos_gpios, ARRAY_SIZE(chromeos_gpios)); +} + +int get_write_protect_state(void) +{ + /* Chausie doesn't have a write protect pin */ + return 0; +} + +static const struct cros_gpio cros_gpios[] = { + /* No ChromeOS GPIOs */ +}; + +void mainboard_chromeos_acpi_generate(void) +{ + chromeos_acpi_gpio_generate(cros_gpios, ARRAY_SIZE(cros_gpios)); +} diff --git a/src/mainboard/amd/chausie/chromeos.fmd b/src/mainboard/amd/chausie/chromeos.fmd new file mode 100644 index 0000000..bb21767 --- /dev/null +++ b/src/mainboard/amd/chausie/chromeos.fmd @@ -0,0 +1,34 @@ +FLASH@0xFF000000 16M { + SI_BIOS { + EC 128K + RW_MRC_CACHE(PRESERVE) 64K + RW_SECTION_A 3M { + VBLOCK_A 8K + FW_MAIN_A(CBFS) + RW_FWID_A 256 + } + RW_SECTION_B 3M { + VBLOCK_B 8K + FW_MAIN_B(CBFS) + RW_FWID_B 256 + } + RW_ELOG(PRESERVE) 4K + RW_SHARED 16K { + SHARED_DATA 8K + VBLOCK_DEV 8K + } + RW_VPD(PRESERVE) 8K + RW_NVRAM(PRESERVE) 20K + SMMSTORE(PRESERVE) 4K + RW_LEGACY(CBFS) + WP_RO@8M 8M { + RO_VPD(PRESERVE) 16K + RO_SECTION { + FMAP 2K + RO_FRID 64 + GBB@4K 448K + COREBOOT(CBFS) + } + } + } +} diff --git a/src/mainboard/amd/chausie/devicetree.cb b/src/mainboard/amd/chausie/devicetree.cb new file mode 100644 index 0000000..0494f5b --- /dev/null +++ b/src/mainboard/amd/chausie/devicetree.cb @@ -0,0 +1,91 @@ +# SPDX-License-Identifier: GPL-2.0-only + +chip soc/amd/sabrina + register "common_config.espi_config" = "{ + .std_io_decode_bitmap = ESPI_DECODE_IO_0x80_EN | ESPI_DECODE_IO_0X2E_0X2F_EN, + .io_mode = ESPI_IO_MODE_QUAD, + .op_freq_mhz = ESPI_OP_FREQ_16_MHZ, + .crc_check_enable = 1, + .alert_pin = ESPI_ALERT_PIN_PUSH_PULL, + .periph_ch_en = 1, + .vw_ch_en = 1, + .oob_ch_en = 1, + .flash_ch_en = 0, + }" + + # I2C Pad Control RX Select Configuration + register "i2c_pad_ctrl_rx_sel[0]" = "I2C_PAD_CTRL_RX_SEL_3_3V" + register "i2c_pad_ctrl_rx_sel[1]" = "I2C_PAD_CTRL_RX_SEL_3_3V" + register "i2c_pad_ctrl_rx_sel[2]" = "I2C_PAD_CTRL_RX_SEL_3_3V" + register "i2c_pad_ctrl_rx_sel[3]" = "I2C_PAD_CTRL_RX_SEL_3_3V" + + register "s0ix_enable" = "true" + + register "pspp_policy" = "DXIO_PSPP_BALANCED" + + device domain 0 on + device ref iommu on end + device ref gpp_gfx_bridge_0 on end # MXM + device ref gpp_bridge_0 on end # NVMe + device ref gpp_bridge_1 on end + device ref gpp_bridge_2 on end # WWAN + device ref gpp_bridge_3 on end # LAN + device ref gpp_bridge_4 on end # WLAN + device ref gpp_bridge_5 on end + device ref gpp_bridge_a on # Internal GPP Bridge 0 to Bus A + device ref gfx on end # Internal GPU (GFX) + device ref crypto on end # Crypto Coprocessor + device ref xhci_0 on # USB 3.1 (USB0) + chip drivers/usb/acpi + device ref xhci_0_root_hub on + chip drivers/usb/acpi + device ref usb3_port0 on end + end + chip drivers/usb/acpi + device ref usb3_port1 on end + end + chip drivers/usb/acpi + device ref usb2_port0 on end + end + chip drivers/usb/acpi + device ref usb2_port1 on end + end + chip drivers/usb/acpi + device ref usb2_port2 on end + end + chip drivers/usb/acpi + device ref usb2_port3 on end + end + end + end + end + device ref xhci_1 on # USB 3.1 (USB1) + chip drivers/usb/acpi + device ref xhci_1_root_hub on + chip drivers/usb/acpi + device ref usb3_port4 on end + end + chip drivers/usb/acpi + device ref usb3_port5 on end + end + chip drivers/usb/acpi + device ref usb2_port4 on end + end + chip drivers/usb/acpi + device ref usb2_port5 on end + end + chip drivers/usb/acpi + device ref usb2_port6 on end + end + chip drivers/usb/acpi + device ref usb2_port7 on end + end + end + end + end + end + end + + device ref uart_0 on end # UART0 + +end diff --git a/src/mainboard/amd/chausie/dsdt.asl b/src/mainboard/amd/chausie/dsdt.asl new file mode 100644 index 0000000..7b8982a --- /dev/null +++ b/src/mainboard/amd/chausie/dsdt.asl @@ -0,0 +1,16 @@ +/* SPDX-License-Identifier: GPL-2.0-only */ + +#include <acpi/acpi.h> +DefinitionBlock ( + "dsdt.aml", + "DSDT", + ACPI_DSDT_REV_2, + OEM_ID, + ACPI_TABLE_CREATOR, + 0x00010001 /* OEM Revision */ + ) +{ + #include <acpi/dsdt_top.asl> + + #include <soc.asl> +} diff --git a/src/mainboard/amd/chausie/early_gpio.c b/src/mainboard/amd/chausie/early_gpio.c new file mode 100644 index 0000000..cd5028a --- /dev/null +++ b/src/mainboard/amd/chausie/early_gpio.c @@ -0,0 +1,18 @@ +/* SPDX-License-Identifier: GPL-2.0-only */ + +#include <soc/gpio.h> +#include "gpio.h" + +/* GPIO pins used by coreboot should be initialized in bootblock */ + +static const struct soc_amd_gpio gpio_set_stage_reset[] = { + PAD_NF(GPIO_113, I2C2_SCL, PULL_NONE), + PAD_NF(GPIO_114, I2C2_SDA, PULL_NONE), + PAD_NF(GPIO_19, I2C3_SCL, PULL_NONE), + PAD_NF(GPIO_20, I2C3_SDA, PULL_NONE), +}; + +void mainboard_program_early_gpios(void) +{ + gpio_configure_pads(gpio_set_stage_reset, ARRAY_SIZE(gpio_set_stage_reset)); +} diff --git a/src/mainboard/amd/chausie/gpio.h b/src/mainboard/amd/chausie/gpio.h new file mode 100644 index 0000000..2143368 --- /dev/null +++ b/src/mainboard/amd/chausie/gpio.h @@ -0,0 +1,8 @@ +/* SPDX-License-Identifier: GPL-2.0-only */ + +#ifndef MAINBOARD_GPIO_H +#define MAINBOARD_GPIO_H + +void mainboard_program_early_gpios(void); /* bootblock GPIO configuration */ + +#endif /* MAINBOARD_GPIO_H */ diff --git a/src/mainboard/amd/chausie/mainboard.c b/src/mainboard/amd/chausie/mainboard.c new file mode 100644 index 0000000..d667f5a --- /dev/null +++ b/src/mainboard/amd/chausie/mainboard.c @@ -0,0 +1,101 @@ +/* SPDX-License-Identifier: GPL-2.0-only */ + +#include <amdblocks/amd_pci_util.h> +#include <commonlib/helpers.h> +#include <device/device.h> +#include <soc/acpi.h> +#include <string.h> +#include <types.h> + +/* + * These arrays set up the FCH PCI_INTR registers 0xC00/0xC01. + * This table is responsible for physically routing the PIC and + * IOAPIC IRQs to the different PCI devices on the system. It + * is read and written via registers 0xC00/0xC01 as an + * Index/Data pair. These values are chipset and mainboard + * dependent and should be updated accordingly. + */ +static uint8_t fch_pic_routing[0x80]; +static uint8_t fch_apic_routing[0x80]; + +_Static_assert(sizeof(fch_pic_routing) == sizeof(fch_apic_routing), + "PIC and APIC FCH interrupt tables must be the same size"); + +/* + * This controls the device -> IRQ routing. + * + * Hardcoded IRQs: + * 0: timer < soc/amd/common/acpi/lpc.asl + * 1: i8042 - Keyboard + * 2: cascade + * 8: rtc0 <- soc/amd/common/acpi/lpc.asl + * 9: acpi <- soc/amd/common/acpi/lpc.asl + */ +static const struct fch_irq_routing { + uint8_t intr_index; + uint8_t pic_irq_num; + uint8_t apic_irq_num; +} chausie_fch[] = { + { PIRQ_A, PIRQ_NC, PIRQ_NC }, + { PIRQ_B, PIRQ_NC, PIRQ_NC }, + { PIRQ_C, PIRQ_NC, PIRQ_NC }, + { PIRQ_D, PIRQ_NC, PIRQ_NC }, + { PIRQ_E, PIRQ_NC, PIRQ_NC }, + { PIRQ_F, PIRQ_NC, PIRQ_NC }, + { PIRQ_G, PIRQ_NC, PIRQ_NC }, + { PIRQ_H, PIRQ_NC, PIRQ_NC }, + + { PIRQ_SCI, ACPI_SCI_IRQ, ACPI_SCI_IRQ }, + { PIRQ_SD, PIRQ_NC, PIRQ_NC }, + { PIRQ_SDIO, PIRQ_NC, PIRQ_NC }, + { PIRQ_SATA, PIRQ_NC, PIRQ_NC }, + { PIRQ_EMMC, PIRQ_NC, PIRQ_NC }, + { PIRQ_GPIO, 7, 7 }, + { PIRQ_I2C2, PIRQ_NC, PIRQ_NC }, + { PIRQ_I2C3, PIRQ_NC, PIRQ_NC }, + { PIRQ_UART0, 4, 4 }, + { PIRQ_UART1, 3, 3 }, + + /* The MISC registers are not interrupt numbers */ + { PIRQ_MISC, 0xfa, 0x00 }, + { PIRQ_MISC0, 0x91, 0x00 }, + { PIRQ_HPET_L, 0x00, 0x00 }, + { PIRQ_HPET_H, 0x00, 0x00 }, +}; + +static void init_tables(void) +{ + const struct fch_irq_routing *entry; + int i; + + memset(fch_pic_routing, PIRQ_NC, sizeof(fch_pic_routing)); + memset(fch_apic_routing, PIRQ_NC, sizeof(fch_apic_routing)); + + for (i = 0; i < ARRAY_SIZE(chausie_fch); i++) { + entry = chausie_fch + i; + fch_pic_routing[entry->intr_index] = entry->pic_irq_num; + fch_apic_routing[entry->intr_index] = entry->apic_irq_num; + } +} + +static void pirq_setup(void) +{ + intr_data_ptr = fch_apic_routing; + picr_data_ptr = fch_pic_routing; +} + +static void mainboard_init(void *chip_info) +{ +} + +static void mainboard_enable(struct device *dev) +{ + init_tables(); + /* Initialize the PIRQ data structures for consumption */ + pirq_setup(); +} + +struct chip_operations mainboard_ops = { + .init = mainboard_init, + .enable_dev = mainboard_enable, +}; diff --git a/src/mainboard/amd/chausie/port_descriptors.c b/src/mainboard/amd/chausie/port_descriptors.c new file mode 100644 index 0000000..46afa77 --- /dev/null +++ b/src/mainboard/amd/chausie/port_descriptors.c @@ -0,0 +1,131 @@ +/* SPDX-License-Identifier: GPL-2.0-only */ + +#include <soc/gpio.h> +#include <soc/platform_descriptors.h> +#include <types.h> + +static const fsp_dxio_descriptor chausie_czn_dxio_descriptors[] = { + { /* MXM */ + .engine_type = PCIE_ENGINE, + .port_present = true, + .start_logical_lane = 16, + .end_logical_lane = 23, + .device_number = 1, + .function_number = 1, + .turn_off_unused_lanes = true, + .clk_req = CLK_REQ0, + .port_params = {PP_PSPP_AC, 0x133, PP_PSPP_DC, 0x122} + }, + { /* SSD */ + .engine_type = PCIE_ENGINE, + .port_present = true, + .start_logical_lane = 0, + .end_logical_lane = 1, + .device_number = 2, + .function_number = 1, + .turn_off_unused_lanes = true, + .clk_req = CLK_REQ5, + .gpio_group_id = GPIO_40, + .port_params = {PP_PSPP_AC, 0x133, PP_PSPP_DC, 0x122} + }, + { /* DT */ + .engine_type = PCIE_ENGINE, + .port_present = true, + .start_logical_lane = 4, + .end_logical_lane = 4, + .device_number = 2, + .function_number = 2, + .turn_off_unused_lanes = true, + .clk_req = CLK_REQ4_GFX, + .port_params = {PP_PSPP_AC, 0x133, PP_PSPP_DC, 0x122} + }, + { /* WWAN */ + .engine_type = PCIE_ENGINE, + .port_present = true, + .start_logical_lane = 5, + .end_logical_lane = 5, + .device_number = 2, + .function_number = 3, + .turn_off_unused_lanes = true, + .clk_req = CLK_REQ2, + .port_params = {PP_PSPP_AC, 0x133, PP_PSPP_DC, 0x122} + }, + { /* LAN */ + .engine_type = PCIE_ENGINE, + .port_present = true, + .start_logical_lane = 6, + .end_logical_lane = 6, + .device_number = 2, + .function_number = 4, + .turn_off_unused_lanes = true, + .clk_req = CLK_REQ1, + .port_params = {PP_PSPP_AC, 0x133, PP_PSPP_DC, 0x122} + }, + { /* WLAN */ + .engine_type = PCIE_ENGINE, + .port_present = true, + .start_logical_lane = 7, + .end_logical_lane = 7, + .device_number = 2, + .function_number = 5, + .turn_off_unused_lanes = true, + .clk_req = CLK_REQ6, + .port_params = {PP_PSPP_AC, 0x133, PP_PSPP_DC, 0x122} + }, + { /* TB */ + .engine_type = PCIE_ENGINE, + .port_present = true, + .start_logical_lane = 8, + .end_logical_lane = 11, + .device_number = 2, + .function_number = 6, + .turn_off_unused_lanes = true, + .clk_req = CLK_REQ3, + .port_params = {PP_PSPP_AC, 0x133, PP_PSPP_DC, 0x122} + }, + { /* SATA */ + .engine_type = SATA_ENGINE, + .port_present = true, + .start_logical_lane = 2, + .end_logical_lane = 3, + .channel_type = SATA_CHANNEL_LONG, + } +}; + +static const fsp_ddi_descriptor chausie_czn_ddi_descriptors[] = { + { /* DDI0 - DP */ + .connector_type = DDI_DP, + .aux_index = DDI_AUX1, + .hdp_index = DDI_HDP1 + }, + { /* DDI1 - HDMI */ + .connector_type = DDI_HDMI, + .aux_index = DDI_AUX2, + .hdp_index = DDI_HDP2 + }, + { /* DDI2 */ + .connector_type = DDI_UNUSED_TYPE, + .aux_index = DDI_AUX3, + .hdp_index = DDI_HDP3, + }, + { /* DDI3 - DP (type C) */ + .connector_type = DDI_DP, + .aux_index = DDI_AUX3, + .hdp_index = DDI_HDP3, + }, + { /* DDI4 - DP (type C) */ + .connector_type = DDI_DP, + .aux_index = DDI_AUX4, + .hdp_index = DDI_HDP4, + } +}; + +void mainboard_get_dxio_ddi_descriptors( + const fsp_dxio_descriptor **dxio_descs, size_t *dxio_num, + const fsp_ddi_descriptor **ddi_descs, size_t *ddi_num) +{ + *dxio_descs = chausie_czn_dxio_descriptors; + *dxio_num = ARRAY_SIZE(chausie_czn_dxio_descriptors); + *ddi_descs = chausie_czn_ddi_descriptors; + *ddi_num = ARRAY_SIZE(chausie_czn_ddi_descriptors); +}
