Timothy Pearson (tpearson@raptorengineeringinc.com) just uploaded a new patch set to gerrit, which you can find at http://review.coreboot.org/8269
commit 4444ea56c86b557a5c2941fb98cd8e7a32c74f30 Author: Timothy Pearson tpearson@raptorengineeringinc.com Date: Fri Jan 23 20:29:46 2015 -0600
nvidia/ck804: Fix FTBFS with AMD Family 10h systems
Change-Id: I85d005edba44c503c49917d4b928e5c9c5900059 Signed-off-by: Timothy Pearson tpearson@raptorengineeringinc.com --- src/southbridge/nvidia/ck804/early_setup_car.c | 10 ++++++++++ 1 file changed, 10 insertions(+)
diff --git a/src/southbridge/nvidia/ck804/early_setup_car.c b/src/southbridge/nvidia/ck804/early_setup_car.c index 9ba98c9..adb2e05 100644 --- a/src/southbridge/nvidia/ck804/early_setup_car.c +++ b/src/southbridge/nvidia/ck804/early_setup_car.c @@ -1,6 +1,8 @@ /* * This file is part of the coreboot project. * + * Copyright (C) 2015 Timothy Pearson tpearson@raptorengineeringinc.com, Raptor Engineering + * * Copyright (C) 2004 Tyan Computer * Written by Yinghai Lu yhlu@tyan.com for Tyan Computer. * @@ -18,6 +20,7 @@ * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA */
+#if IS_ENABLED( CONFIG_NORTHBRIDGE_AMD_AMDK8 ) static int set_ht_link_ck804(u8 ht_c_num) { unsigned vendorid = 0x10de; @@ -46,6 +49,7 @@ static void setup_ss_table(unsigned index, unsigned where, unsigned control, val |= 1; outl(val, control); } +#endif
#define ANACTRL_IO_BASE 0x3000 #define ANACTRL_REG_POS 0x68 @@ -297,6 +301,7 @@ static void ck804_early_setup(unsigned ck804_num, unsigned *busn, PCI_DEV(busn[j], CK804B_DEVN_BASE, 0), io_base[j]); }
+#if IS_ENABLED( CONFIG_NORTHBRIDGE_AMD_AMDK8 ) for (j = 0; j < ck804_num; j++) { /* PCI-E (XSPLL) SS table 0x40, x044, 0x48 */ /* SATA (SPPLL) SS table 0xb0, 0xb4, 0xb8 */ @@ -314,6 +319,7 @@ static void ck804_early_setup(unsigned ck804_num, unsigned *busn, io_base[j] + ANACTRL_IO_BASE + 0xc8, cpu_ss_tbl, 64); } +#endif }
static int ck804_early_setup_x(void) @@ -340,7 +346,11 @@ static int ck804_early_setup_x(void) ck804_early_setup(ck804_num, busn, io_base); ck804_early_clear_port(ck804_num, busn, io_base);
+#if IS_ENABLED( CONFIG_NORTHBRIDGE_AMD_AMDK8 ) return set_ht_link_ck804(4); +#else + return 0 +#endif }
void hard_reset(void)
