Martin Roth has submitted this change. ( https://review.coreboot.org/c/coreboot/+/52625 )
Change subject: soc/amd/picasso: move PSP_SRAM addrs to separate header ......................................................................
These addresses will be changed in cezanne. Before start working on cezanne, move these out to separate header as a clean-up.
TEST=emerge-zork coreboot
Signed-off-by: Kangheui Won khwon@chromium.org Change-Id: I2499281d250aae701f86bfcc87c7681e5b684b6a Reviewed-on: https://review.coreboot.org/c/coreboot/+/52625 Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: Raul Rangel rrangel@chromium.org --- M src/soc/amd/common/block/cpu/noncar/memlayout_psp_verstage.ld A src/soc/amd/picasso/include/soc/psp_verstage_addr.h 2 files changed, 32 insertions(+), 27 deletions(-)
Approvals: build bot (Jenkins): Verified Raul Rangel: Looks good to me, approved
diff --git a/src/soc/amd/common/block/cpu/noncar/memlayout_psp_verstage.ld b/src/soc/amd/common/block/cpu/noncar/memlayout_psp_verstage.ld index aa27bae..cc9ebc0 100644 --- a/src/soc/amd/common/block/cpu/noncar/memlayout_psp_verstage.ld +++ b/src/soc/amd/common/block/cpu/noncar/memlayout_psp_verstage.ld @@ -3,33 +3,7 @@ #include <memlayout.h> #include <soc/psp_transfer.h> #include <fmap_config.h> - -/* TODO: Move defines to SoC-specific header file to allow SoC specific values if needed. */ - -/* - * Start of available space is 0x15000 and this is where the - * header for the user app (verstage) must be mapped. - * Size is 0x28000 bytes - */ -#define PSP_SRAM_START 0x15000 -#define PSP_SRAM_SIZE 160K - -#define VERSTAGE_START 0x15000 - -/* - * The temp stack can be made much smaller if needed - even 256 bytes - * should be sufficient. This is just for the function mapping the - * actual stack. - */ -#define PSP_VERSTAGE_TEMP_STACK_START 0x32000 -#define PSP_VERSTAGE_TEMP_STACK_SIZE 4K - -/* - * The top of the stack must be 4k aligned, so set the bottom as 4k aligned - * and make the size a multiple of 4k - */ -#define PSP_VERSTAGE_STACK_START 0x33000 -#define PSP_VERSTAGE_STACK_SIZE 40K +#include <soc/psp_verstage_addr.h>
ENTRY(_psp_vs_start) SECTIONS diff --git a/src/soc/amd/picasso/include/soc/psp_verstage_addr.h b/src/soc/amd/picasso/include/soc/psp_verstage_addr.h new file mode 100644 index 0000000..61ae926 --- /dev/null +++ b/src/soc/amd/picasso/include/soc/psp_verstage_addr.h @@ -0,0 +1,31 @@ +/* SPDX-License-Identifier: GPL-2.0-only */ + +#ifndef AMD_PICASSO_PSP_VERSTAGE_ADDR_H +#define AMD_PICASSO_PSP_VERSTAGE_ADDR_H + +/* + * Start of available space is 0x15000 and this is where the + * header for the user app (verstage) must be mapped. + * Size is 0x28000 bytes + */ +#define PSP_SRAM_START 0x15000 +#define PSP_SRAM_SIZE (160K) +#define VERSTAGE_START PSP_SRAM_START + +/* + * The temp stack can be made much smaller if needed - even 256 bytes + * should be sufficient. This is just for the function mapping the + * actual stack. + */ +#define PSP_VERSTAGE_TEMP_STACK_START 0x32000 +#define PSP_VERSTAGE_TEMP_STACK_SIZE (4K) + +/* + * The top of the stack must be 4k aligned, so set the bottom as 4k aligned + * and make the size a multiple of 4k + */ + +#define PSP_VERSTAGE_STACK_START 0x33000 +#define PSP_VERSTAGE_STACK_SIZE (40K) + +#endif /* AMD_PICASSO_PSP_VERSTAGE_ADDR_H */
