Hello build bot (Jenkins),
https://review.coreboot.org/24970
Change subject: arch/arm64/armv8/mmu: Add support for 48bit VA ......................................................................
The VA space needs to be extended to support 48bit, as on Cavium SoCs the MMIO starts at 1 << 47.
The following changes were done: * Add a Kconfig to define the VA space on platform level and support 64KB granular size for VA > 39. * Decide to use either 4KB granule or 64KB granule depending on supported VA space. * Add helper functions for different page level sizes * Add asserts to make sure that the address is withing the VA * Don't use BLOCK in level1 if not on 4KB granule
Tested on Cavium SoC. Needs tests on other platforms.
Change-Id: I89e6a4809b6b725c3945bad7fce82b0dfee7c262 Signed-off-by: Patrick Rudolph patrick.rudolph@9elements.com --- M src/arch/arm64/armv8/Kconfig M src/arch/arm64/armv8/mmu.c M src/arch/arm64/include/armv8/arch/mmu.h 3 files changed, 121 insertions(+), 34 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/70/24970/2
