Kane Chen has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/44563 )
Change subject: UPSTREAM: soc/intel/jasperlake: Run pmc_set_acpi_mode() during .init in pmc_ops ......................................................................
pmc_set_acpi_mode will set EC SMI mask to 1 in the end. However google_chromeec_events_init will clear EC SMI mask. If google_chromeec_events_init is ran after pmc_set_acpi_mode, the EC SMI mask will be 0 in depthcharge and causes lidclose function not working. So, pmc_set_acpi_mode() should run after google_chromeec_events_init.
This code is mainly from CL:42677
BUG=b:16338215 TEST=Close lid in depthcharge and the dut can be shutdown on waddledoo.
Signed-off-by: Kane Chen kane.chen@intel.com Change-Id: I0f06e8b5da00eb05a34a6ce1de6d713005211c08 --- M src/soc/intel/jasperlake/pmc.c 1 file changed, 15 insertions(+), 0 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/63/44563/1
diff --git a/src/soc/intel/jasperlake/pmc.c b/src/soc/intel/jasperlake/pmc.c index 4443055..711b63c 100644 --- a/src/soc/intel/jasperlake/pmc.c +++ b/src/soc/intel/jasperlake/pmc.c @@ -98,8 +98,23 @@ res->flags = IORESOURCE_IO | IORESOURCE_ASSIGNED | IORESOURCE_FIXED; }
+static void soc_acpi_mode_init(struct device *dev) +{ + /* + * pmc_set_acpi_mode() should be delayed until BS_DEV_INIT in order + * to ensure the ordering does not break the assumptions that other + * drivers make about ACPI mode (e.g. Chrome EC). Since it disables + * ACPI mode, other drivers may take different actions based on this + * (e.g. Chrome EC will flush any pending hostevent bits). Because + * TGL has its PMC device available for device_operations, it can be + * done from the "ops->init" callback. + */ + pmc_set_acpi_mode(); +} + struct device_operations pmc_ops = { .read_resources = soc_pmc_read_resources, .set_resources = noop_set_resources, + .init = soc_acpi_mode_init, .enable = pmc_init, };
Hello Patrick Rudolph,
Change subject: soc/intel/jasperlake: Run pmc_set_acpi_mode() during .init in pmc_ops ......................................................................
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/63/44563/2
Hello build bot (Jenkins), Patrick Rudolph,
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/63/44563/3
Dtrain Hsu has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/44563 )
Patch Set 3: Code-Review+1
Aamir Bohra has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/44563 )
Patch Set 3:
https://review.coreboot.org/c/coreboot/+/44563/3/src/soc/intel/jasperlake/pm... File src/soc/intel/jasperlake/pmc.c:
https://review.coreboot.org/c/coreboot/+/44563/3/src/soc/intel/jasperlake/pm... PS3, Line 81: pmc_set_acpi_mode can be removed now.
Karthik Ramasubramanian has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/44563 )
Patch Set 3:
https://review.coreboot.org/c/coreboot/+/44563/3//COMMIT_MSG Commit Message:
https://review.coreboot.org/c/coreboot/+/44563/3//COMMIT_MSG@15 PS3, Line 15: CL:42677 Nit: CB:42677. That links to the correct coreboot CL.
Hello build bot (Jenkins), Dtrain Hsu, Maulik V Vaghela, Aamir Bohra, Patrick Rudolph, Karthik Ramasubramanian,
This code is mainly from CB:42677
Signed-off-by: Kane Chen kane.chen@intel.com Change-Id: I0f06e8b5da00eb05a34a6ce1de6d713005211c08 --- M src/soc/intel/jasperlake/pmc.c 1 file changed, 15 insertions(+), 2 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/63/44563/4
Kane Chen has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/44563 )
Patch Set 4:
(2 comments)
Done
can be removed now.
Done
Patch Set 4: Code-Review+2
Maulik V Vaghela has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/44563 )
Patch Set 4:
could we merge this? thanks
Subrata Banik has submitted this change. ( https://review.coreboot.org/c/coreboot/+/44563 )
Signed-off-by: Kane Chen kane.chen@intel.com Change-Id: I0f06e8b5da00eb05a34a6ce1de6d713005211c08 Reviewed-on: https://review.coreboot.org/c/coreboot/+/44563 Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: Aamir Bohra aamir.bohra@intel.com Reviewed-by: Karthik Ramasubramanian kramasub@google.com Reviewed-by: Maulik V Vaghela maulik.v.vaghela@intel.com --- M src/soc/intel/jasperlake/pmc.c 1 file changed, 15 insertions(+), 2 deletions(-)
Approvals: build bot (Jenkins): Verified Aamir Bohra: Looks good to me, approved Maulik V Vaghela: Looks good to me, approved Karthik Ramasubramanian: Looks good to me, approved
diff --git a/src/soc/intel/jasperlake/pmc.c b/src/soc/intel/jasperlake/pmc.c index 4443055..ed6a31d 100644 --- a/src/soc/intel/jasperlake/pmc.c +++ b/src/soc/intel/jasperlake/pmc.c @@ -78,8 +78,6 @@ pmc_set_power_failure_state(true); pmc_gpe_init();
- pmc_set_acpi_mode(); - config_deep_s3(config->deep_s3_enable_ac, config->deep_s3_enable_dc); config_deep_s5(config->deep_s5_enable_ac, config->deep_s5_enable_dc); config_deep_sx(config->deep_sx_config); @@ -98,8 +96,23 @@ res->flags = IORESOURCE_IO | IORESOURCE_ASSIGNED | IORESOURCE_FIXED; }
+static void soc_acpi_mode_init(struct device *dev) +{ + /* + * pmc_set_acpi_mode() should be delayed until BS_DEV_INIT in order + * to ensure the ordering does not break the assumptions that other + * drivers make about ACPI mode (e.g. Chrome EC). Since it disables + * ACPI mode, other drivers may take different actions based on this + * (e.g. Chrome EC will flush any pending hostevent bits). Because + * JSL has its PMC device available for device_operations, it can be + * done from the "ops->init" callback. + */ + pmc_set_acpi_mode(); +} + struct device_operations pmc_ops = { .read_resources = soc_pmc_read_resources, .set_resources = noop_set_resources, + .init = soc_acpi_mode_init, .enable = pmc_init, };
