Aaron Durbin has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/44641 )
Change subject: acpi: add more AML generation functions ......................................................................
Add the following functions to acpi AML generation code:
acpigen_write_to_integer_from_namestring() acpigen_write_create_byte_field() acpigen_write_create_word_field() acpigen_write_create_dword_field() acpigen_write_create_qword_field()
BUG=b:163583825
Change-Id: Ida151aff68f90012b16df2383fb96ddb87c3fb9c Signed-off-by: Aaron Durbin adurbin@chromium.org --- M src/acpi/acpigen.c M src/include/acpi/acpigen.h 2 files changed, 40 insertions(+), 0 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/41/44641/1
diff --git a/src/acpi/acpigen.c b/src/acpi/acpigen.c index f218706..a82a66e 100644 --- a/src/acpi/acpigen.c +++ b/src/acpi/acpigen.c @@ -1353,6 +1353,13 @@ acpigen_emit_byte(dst); }
+void acpigen_write_to_integer_from_namestring(const char *source, uint8_t dst_op) +{ + acpigen_emit_byte(TO_INTEGER_OP); + acpigen_emit_namestring(source); + acpigen_emit_byte(dst_op); +} + void acpigen_write_byte_buffer(uint8_t *arr, size_t size) { size_t i; @@ -1971,3 +1978,31 @@ acpigen_emit_namestring(namestr); acpigen_write_integer(value); } + +static void _create_field(uint8_t aml_op, uint8_t srcop, size_t byte_offset, const char *name) +{ + acpigen_emit_byte(aml_op); + acpigen_emit_byte(srcop); + acpigen_write_integer(byte_offset); + acpigen_emit_namestring(name); +} + +void acpigen_write_create_byte_field(uint8_t op, size_t byte_offset, const char *name) +{ + _create_field(CREATE_BYTE_OP, op, byte_offset, name); +} + +void acpigen_write_create_word_field(uint8_t op, size_t byte_offset, const char *name) +{ + _create_field(CREATE_WORD_OP, op, byte_offset, name); +} + +void acpigen_write_create_dword_field(uint8_t op, size_t byte_offset, const char *name) +{ + _create_field(CREATE_DWORD_OP, op, byte_offset, name); +} + +void acpigen_write_create_qword_field(uint8_t op, size_t byte_offset, const char *name) +{ + _create_field(CREATE_QWORD_OP, op, byte_offset, name); +} diff --git a/src/include/acpi/acpigen.h b/src/include/acpi/acpigen.h index 4525b6b..e44926f 100644 --- a/src/include/acpi/acpigen.h +++ b/src/include/acpi/acpigen.h @@ -368,6 +368,7 @@ void acpigen_write_else(void); void acpigen_write_to_buffer(uint8_t src, uint8_t dst); void acpigen_write_to_integer(uint8_t src, uint8_t dst); +void acpigen_write_to_integer_from_namestring(const char *source, uint8_t dst_op); void acpigen_write_byte_buffer(uint8_t *arr, size_t size); void acpigen_write_return_byte_buffer(uint8_t *arr, size_t size); void acpigen_write_return_singleton_buffer(uint8_t arg); @@ -380,6 +381,10 @@ void acpigen_write_ADR_pci_device(const struct device *dev); struct soundwire_address; void acpigen_write_ADR_soundwire_device(const struct soundwire_address *address); +void acpigen_write_create_byte_field(uint8_t op, size_t byte_offset, const char *name); +void acpigen_write_create_word_field(uint8_t op, size_t byte_offset, const char *name); +void acpigen_write_create_dword_field(uint8_t op, size_t byte_offset, const char *name); +void acpigen_write_create_qword_field(uint8_t op, size_t byte_offset, const char *name); /* * Generate ACPI AML code for _DSM method. * This function takes as input uuid for the device, set of callbacks and
Furquan Shaikh has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/44641 )
Patch Set 1: Code-Review+2
Aaron Durbin has submitted this change. ( https://review.coreboot.org/c/coreboot/+/44641 )
BUG=b:163583825
Change-Id: Ida151aff68f90012b16df2383fb96ddb87c3fb9c Signed-off-by: Aaron Durbin adurbin@chromium.org Reviewed-on: https://review.coreboot.org/c/coreboot/+/44641 Reviewed-by: Furquan Shaikh furquan@google.com Tested-by: build bot (Jenkins) no-reply@coreboot.org --- M src/acpi/acpigen.c M src/include/acpi/acpigen.h 2 files changed, 40 insertions(+), 0 deletions(-)
9elements QA has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/44641 )
Patch Set 2:
Automatic boot test returned (PASS/FAIL/TOTAL): 6/1/7 "QEMU x86 q35/ich9" (x86_32) using payload TianoCore : SUCCESS : https://lava.9esec.io/r/16083 "QEMU x86 q35/ich9" (x86_32) using payload SeaBIOS : SUCCESS : https://lava.9esec.io/r/16082 "QEMU x86 i440fx/piix4" (x86_64) using payload SeaBIOS : FAIL : https://lava.9esec.io/r/16081 "QEMU x86 i440fx/piix4" (x86_32) using payload SeaBIOS : SUCCESS : https://lava.9esec.io/r/16080 "QEMU AArch64" using payload LinuxBoot_u-root_kexec : SUCCESS : https://lava.9esec.io/r/16079 "HP Compaq 8200 Elite SFF PC" (x86_32) using payload TianoCore : SUCCESS : https://lava.9esec.io/r/16085 "HP Compaq 8200 Elite SFF PC" (x86_32) using payload SeaBIOS : SUCCESS : https://lava.9esec.io/r/16084
