Marc Jones (marc@marcjonesconsulting.com) just uploaded a new patch set to gerrit, which you can find at https://review.coreboot.org/18441
commit dc75cfd025c0002576624bcdf707f996ea6796fd Author: Marshall Dawson marshalldawson3rd@gmail.com Date: Sun Jan 29 17:29:46 2017 -0700
amd/pi/hudson: Add SPI definitions to header
Add defines that will be used later for setting the fastest settings in the SPI controller.
Original-Signed-off-by: Marshall Dawson marshalldawson3rd@gmail.com Original-Reviewed-by: Marc Jones marcj303@gmail.com (cherry picked from commit 0d2c28b8156dcc1f3dc925b3c3ba15b6b07f202c)
Change-Id: I660cc9ed6910c33042321c80453c7f74912455d9 Signed-off-by: Marc Jones marcj303@gmail.com --- src/southbridge/amd/pi/hudson/hudson.h | 38 ++++++++++++++++++++++++++++++++++ 1 file changed, 38 insertions(+)
diff --git a/src/southbridge/amd/pi/hudson/hudson.h b/src/southbridge/amd/pi/hudson/hudson.h index 7835f68..73dd0e9 100644 --- a/src/southbridge/amd/pi/hudson/hudson.h +++ b/src/southbridge/amd/pi/hudson/hudson.h @@ -120,6 +120,44 @@ #define DECODE_ENABLE_ACPIUC_PORT (BIT30) #define DECODE_ENABLE_ADLIB_PORT (BIT31)
+#define SPI_CNTRL0 ((void *)(SPI_BASE_ADDRESS + 0x00)) +#define SPI_READ_MODE_MASK (BIT30 | BIT29 | BIT18) +/* Nominal is 16.7MHz on older devices, 33MHz on newer */ +#define SPI_READ_MODE_NOM 0x00000000 +#define SPI_READ_MODE_DUAL112 ( BIT29 ) +#define SPI_READ_MODE_QUAD114 ( BIT29 | BIT18) +#define SPI_READ_MODE_DUAL122 (BIT30 ) +#define SPI_READ_MODE_QUAD144 (BIT30 | BIT18) +#define SPI_READ_MODE_NORMAL66 (BIT30 | BIT29 ) +/* Nominal and SPI_READ_MODE_FAST_HUDSON1 are the only valid choices for H1 */ +#define SPI_READ_MODE_FAST_HUDSON1 ( BIT18) +#define SPI_READ_MODE_FAST (BIT30 | BIT29 | BIT18) +#define SPI_ARB_ENABLE BIT19 + +#define SPI_CNTRL1 ((void *)(SPI_BASE_ADDRESS + 0x0c)) +/* Use SPI_SPEED_16M-SPI_SPEED_66M below for hudson and bolton */ +#define SPI_CNTRL1_SPEED_MASK (BIT15 | BIT14 | BIT13 | BIT12) +#define SPI_NORM_SPEED_SH 12 +#define SPI_FAST_SPEED_SH 8 + +#define SPI100_ENABLE ((void *)(SPI_BASE_ADDRESS + 0x20)) +#define SPI_USE_SPI100 (BIT0) + +#define SPI100_SPEED_CONFIG ((void *)(SPI_BASE_ADDRESS + 0x22)) +#define SPI_SPEED_66M (0x0) +#define SPI_SPEED_33M ( BIT0) +#define SPI_SPEED_22M ( BIT1 ) +#define SPI_SPEED_16M ( BIT1 | BIT0) +#define SPI_SPEED_100M (BIT2 ) +#define SPI_SPEED_800K (BIT2 | BIT0) +#define SPI_NORM_SPEED_NEW_SH 12 +#define SPI_FAST_SPEED_NEW_SH 8 +#define SPI_ALT_SPEED_NEW_SH 4 +#define SPI_TPM_SPEED_NEW_SH 0 + +#define SPI100_HOST_PREF_CONFIG ((void *)(SPI_BASE_ADDRESS + 0x2c)) +#define SPI_RD4DW_EN_HOST BIT15 + static inline int hudson_sata_enable(void) { /* True if IDE or AHCI. */
