Felix Held has submitted this change. ( https://review.coreboot.org/c/coreboot/+/54023 )
Change subject: mb/intel/adlrvp_m: Enable CR50 TPM support over SPI ......................................................................
Add Kconfig options and enable TPM device in devicetree
BUG=None TEST=Booted the image and checked the successful TPM communication in verstage,romstage & ramstage from coreboot logs.
Signed-off-by: Thejaswani Puta thejaswani.putta@intel.com thejaswani.putta@intel.com Change-Id: Icaedf9f17e35e82c35cbabd6d2938c167e42e9e8 Reviewed-on: https://review.coreboot.org/c/coreboot/+/54023 Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: Bora Guvendik bora.guvendik@intel.com --- M src/mainboard/intel/adlrvp/Kconfig M src/mainboard/intel/adlrvp/devicetree_m.cb M src/mainboard/intel/adlrvp/early_gpio_m.c M src/mainboard/intel/adlrvp/gpio_m.c 4 files changed, 51 insertions(+), 4 deletions(-)
Approvals: build bot (Jenkins): Verified Bora Guvendik: Looks good to me, approved Thejaswani Putta: Looks good to me, but someone else must approve
diff --git a/src/mainboard/intel/adlrvp/Kconfig b/src/mainboard/intel/adlrvp/Kconfig index f622921..eed3b30 100644 --- a/src/mainboard/intel/adlrvp/Kconfig +++ b/src/mainboard/intel/adlrvp/Kconfig @@ -22,6 +22,9 @@ select DRIVERS_I2C_MAX98373 select FW_CONFIG if BOARD_INTEL_ADLRVP_M_EXT_EC select FW_CONFIG_SOURCE_CHROMEEC_CBI if BOARD_INTEL_ADLRVP_M_EXT_EC + select MAINBOARD_HAS_TPM2 if BOARD_INTEL_ADLRVP_M_EXT_EC + select MAINBOARD_HAS_SPI_TPM_CR50 if BOARD_INTEL_ADLRVP_M_EXT_EC + select SPI_TPM if BOARD_INTEL_ADLRVP_M_EXT_EC
config CHROMEOS select GBB_FLAG_FORCE_DEV_SWITCH_ON @@ -91,11 +94,18 @@
config VBOOT select VBOOT_LID_SWITCH - select VBOOT_MOCK_SECDATA + select VBOOT_MOCK_SECDATA if BOARD_INTEL_ADLRVP_P_EXT_EC select EC_GOOGLE_CHROMEEC_SWITCHES if ADL_CHROME_EC select VBOOT_EARLY_EC_SYNC if BOARD_INTEL_ADLRVP_M_EXT_EC
config UART_FOR_CONSOLE int default 0 + +config DRIVER_TPM_SPI_BUS + default 0x2 if BOARD_INTEL_ADLRVP_M_EXT_EC + +config TPM_TIS_ACPI_INTERRUPT + int + default 67 if BOARD_INTEL_ADLRVP_M_EXT_EC # GPE0_DW2_3 (GPP_E3) endif diff --git a/src/mainboard/intel/adlrvp/devicetree_m.cb b/src/mainboard/intel/adlrvp/devicetree_m.cb index b28f387..65a6cac 100644 --- a/src/mainboard/intel/adlrvp/devicetree_m.cb +++ b/src/mainboard/intel/adlrvp/devicetree_m.cb @@ -6,6 +6,19 @@ end chip soc/intel/alderlake
+ device cpu_cluster 0 on + device lapic 0 on end + end + + # This disables autonomous GPIO power management, otherwise + # old cr50 FW only supports short pulses. + register "gpio_override_pm" = "1" + register "gpio_pm[COMM_0]" = "0" + register "gpio_pm[COMM_1]" = "0" + register "gpio_pm[COMM_2]" = "0" + register "gpio_pm[COMM_4]" = "0" + register "gpio_pm[COMM_5]" = "0" + # GPE configuration # Note that GPE events called out in ASL code rely on this # route. i.e. If this route changes then the affected GPE @@ -107,14 +120,14 @@
register "SerialIoGSpiMode" = "{ [PchSerialIoIndexGSPI0] = PchSerialIoPci, - [PchSerialIoIndexGSPI1] = PchSerialIoDisabled, + [PchSerialIoIndexGSPI1] = PchSerialIoPci, [PchSerialIoIndexGSPI2] = PchSerialIoDisabled, [PchSerialIoIndexGSPI3] = PchSerialIoDisabled, }"
register "SerialIoGSpiCsMode" = "{ [PchSerialIoIndexGSPI0] = 0, - [PchSerialIoIndexGSPI1] = 0, + [PchSerialIoIndexGSPI1] = 1, [PchSerialIoIndexGSPI2] = 0, [PchSerialIoIndexGSPI3] = 0, }" @@ -141,6 +154,10 @@ # Intel Common SoC Config register "common_soc_config" = "{ .chipset_lockdown = CHIPSET_LOCKDOWN_COREBOOT, + .gspi[1] = { + .speed_mhz = 1, + .early_init = 1, + }, .i2c[0] = { .speed = I2C_SPEED_FAST, }, @@ -353,6 +370,14 @@ device ref uart0 on end device ref gspi0 on end device ref p2sb on end + device pci 1e.3 on + chip drivers/spi/acpi + register "hid" = "ACPI_DT_NAMESPACE_HID" + register "compat_string" = ""google,cr50"" + register "irq" = "ACPI_IRQ_EDGE_LOW(GPP_E3_IRQ)" + device spi 0 on end + end + end # GSPI1 device ref hda on chip drivers/intel/soundwire device generic 0 on diff --git a/src/mainboard/intel/adlrvp/early_gpio_m.c b/src/mainboard/intel/adlrvp/early_gpio_m.c index 3b60e24..79349b1 100644 --- a/src/mainboard/intel/adlrvp/early_gpio_m.c +++ b/src/mainboard/intel/adlrvp/early_gpio_m.c @@ -99,6 +99,18 @@ PAD_CFG_NF_VWEN(GPP_vGPIO_PCIE_77, NONE, DEEP, NF1), PAD_CFG_NF_VWEN(GPP_vGPIO_PCIE_78, NONE, DEEP, NF1), PAD_CFG_NF_VWEN(GPP_vGPIO_PCIE_79, NONE, DEEP, NF1), + + /* H1_PCH_INT_ODL */ + PAD_CFG_GPI_APIC(GPP_E3, NONE, PLTRST, LEVEL, INVERT), + /* TPM */ + /* F16 : GSPI1_CS0N */ + PAD_CFG_NF(GPP_F16, NONE, DEEP, NF4), + /* F11 : GSPI1_CLK */ + PAD_CFG_NF(GPP_F11, NONE, DEEP, NF4), + /* F13 : GSPI1_MISO */ + PAD_CFG_NF(GPP_F13, NONE, DEEP, NF4), + /* F12 : GSPI1_MOSI */ + PAD_CFG_NF(GPP_F12, NONE, DEEP, NF4), };
static const struct pad_config early_uart_gpio_table[] = { diff --git a/src/mainboard/intel/adlrvp/gpio_m.c b/src/mainboard/intel/adlrvp/gpio_m.c index d5eeffa..11686be 100644 --- a/src/mainboard/intel/adlrvp/gpio_m.c +++ b/src/mainboard/intel/adlrvp/gpio_m.c @@ -159,7 +159,7 @@ PAD_CFG_NF(GPP_S6, NONE, DEEP, NF2),
/* S7 : SNDW4_DATA */ - PAD_CFG_NF(GPP_S7, NONE, DEEP, NF2) + PAD_CFG_NF(GPP_S7, NONE, DEEP, NF2), };
void variant_configure_gpio_pads(void)
