Timothy Pearson (tpearson@raptorengineeringinc.com) just uploaded a new patch set to gerrit, which you can find at http://review.coreboot.org/12289
commit 960caf3775e1eb2da79260cdab65be667a6ccf0b Author: Timothy Pearson tpearson@raptorengineeringinc.com Date: Sun Nov 1 02:13:17 2015 -0600
drivers/pc80: Rework normal / fallback selector code
Per IRC and Gerrit discussion, the normal / fallback selector code is a rather weak spot in coreboot, and did not function correctly for certain use cases.
Rework the selector to more clearly indicate proper operation, and also remove dead code. Also tentatively abandon use of RTC bit 385; a follow-up patch will remove said bit from all affected mainboards.
The correct operation of the fallback code selector approximates that of a power line recloser, with a user option to attempt normal boot that can be cleared by firmware, but never set by firmware. Additionally, if cleared by user, the fallback path should always be used on the next reboot.
Change-Id: I753ae9f0710c524875a85354ac2547df0c305569 Signed-off-by: Timothy Pearson tpearson@raptorengineeringinc.com --- src/drivers/pc80/mc146818rtc_early.c | 49 +++++++++++++++++++++--------------- 1 file changed, 29 insertions(+), 20 deletions(-)
diff --git a/src/drivers/pc80/mc146818rtc_early.c b/src/drivers/pc80/mc146818rtc_early.c index 421af2f..2eb4a15 100644 --- a/src/drivers/pc80/mc146818rtc_early.c +++ b/src/drivers/pc80/mc146818rtc_early.c @@ -12,6 +12,8 @@ #error "CONFIG_MAX_REBOOT_CNT too high" #endif
+#define RTC_BOOT_NORMAL 0x1 + static int cmos_error(void) { unsigned char reg_d; @@ -41,12 +43,28 @@ static int cmos_chksum_valid(void) #endif }
+static inline __attribute__((unused)) int boot_count(void) +{ + unsigned char byte; + byte = cmos_read(RTC_BOOT_BYTE); + return byte >> 4; +} + +static inline __attribute__((unused)) uint8_t increment_boot_count(uint8_t rtc_byte) +{ + return rtc_byte + (1 << 4); +} + +static inline __attribute__((unused)) uint8_t boot_use_fallback(uint8_t rtc_byte) +{ + return rtc_byte & ~RTC_BOOT_NORMAL; +}
static inline __attribute__((unused)) int last_boot_normal(void) { unsigned char byte; byte = cmos_read(RTC_BOOT_BYTE); - return (byte & (1 << 1)); + return (byte & RTC_BOOT_NORMAL); }
static inline __attribute__((unused)) int do_normal_boot(void) @@ -59,7 +77,7 @@ static inline __attribute__((unused)) int do_normal_boot(void) * but clear the fallback bit. */ byte = cmos_read(RTC_BOOT_BYTE); - byte &= 0x0c; + byte &= RTC_BOOT_NORMAL; byte |= CONFIG_MAX_REBOOT_CNT << 4; cmos_write(byte, RTC_BOOT_BYTE); } @@ -67,29 +85,20 @@ static inline __attribute__((unused)) int do_normal_boot(void) /* The RTC_BOOT_BYTE is now o.k. see where to go. */ byte = cmos_read(RTC_BOOT_BYTE);
- if (!IS_ENABLED(CONFIG_SKIP_MAX_REBOOT_CNT_CLEAR)) - /* Are we in normal mode? */ - if (byte & 1) - byte &= 0x0f; /* yes, clear the boot count */ - - /* Properly set the last boot flag */ - byte &= 0xfc; - if ((byte >> 4) < CONFIG_MAX_REBOOT_CNT) { - byte |= (1<<1); - } - - /* Are we already at the max count? */ - if ((byte >> 4) < CONFIG_MAX_REBOOT_CNT) { - byte += 1 << 4; /* No, add 1 to the count */ - } - else { - byte &= 0xfc; /* Yes, put in fallback mode */ + /* Are we attempting to boot normally? */ + if (byte & RTC_BOOT_NORMAL) { + /* Are we already at the max count? */ + if (boot_count() < CONFIG_MAX_REBOOT_CNT) + byte = increment_boot_count(byte); + else + byte = boot_use_fallback(byte); }
/* Save the boot byte */ cmos_write(byte, RTC_BOOT_BYTE);
- return (byte & (1<<1)); + /* Return selected code path for this boot attempt */ + return (byte & RTC_BOOT_NORMAL); }
unsigned read_option_lowlevel(unsigned start, unsigned size, unsigned def)
