build bot (Jenkins) has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/74577 )
Change subject: [Test] [Do not Merge] soc/intel/cse_lite: Backup PSR data during CSE FW downgrade ......................................................................
Patch Set 1:
(10 comments)
File src/soc/intel/common/block/cse/cse_lite.c:
Robot Comment from checkpatch (run ID jenkins-coreboot-checkpatch-174607): https://review.coreboot.org/c/coreboot/+/74577/comment/cd1c1040_2213afd8 PS1, Line 137: #if 0 Consider removing the code enclosed by this #if 0 and its #endif
Robot Comment from checkpatch (run ID jenkins-coreboot-checkpatch-174607): https://review.coreboot.org/c/coreboot/+/74577/comment/125e8562_754813ef PS1, Line 145: #if 0 Consider removing the code enclosed by this #if 0 and its #endif
Robot Comment from checkpatch (run ID jenkins-coreboot-checkpatch-174607): https://review.coreboot.org/c/coreboot/+/74577/comment/642a124c_b70096fc PS1, Line 765: #if 1 Consider removing the #if 1 and its #endif
Robot Comment from checkpatch (run ID jenkins-coreboot-checkpatch-174607): https://review.coreboot.org/c/coreboot/+/74577/comment/8da2ed45_17bd4bce PS1, Line 775: if (0x55 != cmos_read(PSR_BACKUP_STATUS_CMOS_OFFSET)) { Comparisons should place the constant on the right side of the test
Robot Comment from checkpatch (run ID jenkins-coreboot-checkpatch-174607): https://review.coreboot.org/c/coreboot/+/74577/comment/606133ae_baed56c0 PS1, Line 777: if (CB_SUCCESS == cse_boot_to_rw(cse_bp_info)) { suspect code indent for conditional statements (24, 40)
Robot Comment from checkpatch (run ID jenkins-coreboot-checkpatch-174607): https://review.coreboot.org/c/coreboot/+/74577/comment/119d2597_4b20764d PS1, Line 777: if (CB_SUCCESS == cse_boot_to_rw(cse_bp_info)) { Comparisons should place the constant on the right side of the test
Robot Comment from checkpatch (run ID jenkins-coreboot-checkpatch-174607): https://review.coreboot.org/c/coreboot/+/74577/comment/365af231_c6cba3ec PS1, Line 788: //} trailing whitespace
Robot Comment from checkpatch (run ID jenkins-coreboot-checkpatch-174607): https://review.coreboot.org/c/coreboot/+/74577/comment/e462683c_2d37893d PS1, Line 875: printk(BIOS_DEBUG, "cse_lite: Add elog event \n"); unnecessary whitespace before a quoted newline
File src/soc/intel/common/block/include/intelblocks/cse.h:
Robot Comment from checkpatch (run ID jenkins-coreboot-checkpatch-174607): https://review.coreboot.org/c/coreboot/+/74577/comment/d78d4a2b_e5a31dd5 PS1, Line 110: #if 1 Consider removing the #if 1 and its #endif
Robot Comment from checkpatch (run ID jenkins-coreboot-checkpatch-174607): https://review.coreboot.org/c/coreboot/+/74577/comment/309acad5_610c6894 PS1, Line 113: { open brace '{' following enum go on the same line
